Question about Frigidaire FEF355 Electric Kitchen Range
FRIGIDAIRE STOVE NOT SURE OF MODEL NUMBER...FOUND AN F1 ERROR ON STOVE, TRIED TURNING OFF BREAKER FOR A COUPLE MINUTES, STILL POPS UP WITH F1 ON CLOCK DISPLAY.....OVEN WILL NOT TURN ON.....ANY ASSISTANCE APPRECIATED....
  • 725 Answers
F1 is a EOC (electronic Oven Control) failure... you will need to repace EOC
Posted on Sep 29, 2008
When turning oven on there is a beeping sound and error code F1
Most of the answers are correct, the EOC (Electronic Oven Control) is either damaged or shorted. I've also seen the F1 code come up on the version 2 and 3 units when the temperature probe was shorted. But most likely your EOC is damaged and needs to be replaced. Since you didn't give us a model number we can't give you any more info. Good luck
Mar 14, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
What does error code f 1 mean on an electic range if i hit clear the beeping stops but comes back on in a few seconds
Copied from another website:
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part
Jul 26, 2009 | Frigidaire Gallery GLGF389GS Kitchen Range
F1 on Clock
Your ERC is bad(clock).
No repair, must be replaced.
Apr 15, 2009 | Frigidaire Ovens
Stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
F1 signal started today can't turn the alarm off.model kenmore 9114832593
  • Disconnect power to stove
  • Gain access to the back of the clock (electronic range control or ERC).
  • Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  • Make sure everything is clear and will not short out when power is turned back on.
  • Turn power back on to stove.
  • Watch for the F1 and listen for the beep.
  • If you get the F1 and beep, replace the ERC.
  • If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part.
  • Let me know if this doesn't point you to a solution. There are a couple of more things to try.
    Feb 01, 2009 | Ovens
    Frigidaire Range control panel DEAD
    We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
    Dec 16, 2008 | Frigidaire FEF366EC 30" Freestanding...
    My kenmore electronic stove is having a beep with code F1 on the
    Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
    KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
    F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
    KENMORE - 911 Series (General Electric/Roper)
    F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
    KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
    F1-E0 EPROM Error - Electronic Range Control (ERC).
    F1-E1 EPROM Error - Electronic Range Control (ERC).
    F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
    F1-E3 Fuel Type Fail
    Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
    “9” for gas-If code changes again-replace Electronic Range Control (ERC).
    KENMORE - 790 Series Electronic Oven Control (Frigidaire)
    F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
    Runaway Temp = Replace Electronic Oven Control (EOC).
    Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
    Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Oven element will not turn off
    I just had someone come out to look at this problem. He said that the control board needs to be replaced and it would cost me about $400. He said that it's almost better to go out and buy a new oven.
    Nov 11, 2008 | Frigidaire FEF352 Electric Kitchen Range
    F1 - oven will not turn on
    You can try turning the power off for a couple minutes then back on but this is typically caused by a stuck key or a faulty control board. Either way you're looking at needing a new control board.
    Hope this helps.
    Dec 20, 2007 | Frigidaire Gallery GLEFM397DS Electric...
    Frigidaire FEF355 Electric Kitchen Range Logo
    731 people viewed this question
    Top Frigidaire Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Paul Carew
    Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
