Question about Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player
Numark no power on numark cdn22 mk4 my numark mixer power isn't working properly. I plug the adapter into the mixer, the power isn't turned on. when I bend the power source thats connected to the mixer, the power comes on. What can I do about it?
  • niceness Sep 27, 2008
    I bought another adapter for a mixer, And Its still not working.
    (what now?)
You need a new adaptor...the wires have lost their connection in the cable or plug which isnt user servicable
KK
Posted on Sep 27, 2008
No control on the left cdplayer, left display is not working
I HAVE RECENTLY HAD TWO OF THESE FOR REAIR WITH THE IGHT HAND CHANNEL BEINGAT FAULT. THE FIX ON BOTH OF THESE WAS TOO STRAIGHTEN THE PINS ON THE CONNECTING CABLE AS REPEATED USE HAD BET THEM. BOTH UNITS NOW WORK CORRECTLY.
Feb 26, 2014 | Numark CDN22 MK5 CD Player
I HAVE A NUMARKKMX01 MIXER WHEN I PLUG THE RED RCA JACK IN TO THE MIXER I GET A LOUND HUM
What is plugged into your Numark mixer when this happens? Try disconnecting ALL audio inputs to your mixer, turn mixer volumes to zero and see if the hum is still present. Adjust the volume and check if the hum you mentioned returns. If it is still heard, try new cables between the mixer and amp...if not then start reconnecting inputs until the hum is heard again. It's a process of elimination but not that difficult to find the source of your problem.
Oct 31, 2012 | Numark Industries Numark DM 1200 Mixer
I have a Phonic Max 2500 amp and use a Numark 2 channel mixer with CDN 22 mK4 Dual CD. Just in past wekk I've been unable to fade out the track playing oin either side of the mixer (you can still hear...
If you have fader capabilities...and there is still signal "leaking" through...you may try reducing your input gain on each channel of your mixer...as well as make sure you have a good ground connection between your components.
Jun 19, 2011 | Phonic MAX 2500 Amplifier
Use the cdn22 on weekends for 6 hours a night. at least twice a nightone of the cd players said no disc when i put one in. its not always the same side that does it. the only way to correct it is to power...
Check for contamination on the disks that won't load. Also if you have things like cigarette smoke or "fog" machine that can cause the problem. The precision of the head of the CD players is amazing as the tracks are millionths of an inch apart and it doesn''t take much to cause a problem. If trying to load again the disk finally works, then it may not be registering on the hub quite right. Care in centering MAY help.
Mar 14, 2011 | Numark Industries Numark CDN 22 Mk4 Double...
Numark Axis 9's wont turn on
1. Check for internal fuse.
2. Check the power transformer.
3. Check the rest of the power supply.
Aug 11, 2009 | Audio Players & Recorders
Numark 360 21v 750ma Power Supply
Try the following sites
http://www.powerstream.com/power2.html
http://www.platinum-records.com/Numark-21V-750MA-AC-Adapter-Power-Supply-prod7509.htm
Or even a cheap replacement laptop power supply as these usually start at 1000 mA which will give you current to spare and have a longer lifetime. most of these cover from 15V to 24V and are either auto switching or manual select for the voltage. Plus you can pick these up from most electronic / big box / supermarket shelves
Aug 10, 2009 | Numark DM1200 DJ Mixer
No power.
sounds like your blew the first power stage, probally a fried power diode. is there a fuse you can replace? if not it will most probally need componet level troubleshooting/repair.
good luck!
jesse
May 05, 2009 | Nu Mark Numark Cd-Mix-2 Dual CD...
Numark dxm09 mixer will not turn on
Any Luck with Mixer, My has suddenly stop working. I've put the adapter on and its not coming on? May be the adapter has been fused, and still waiting for a new one? If not a new Mixer:-(...
Dec 15, 2008 | Audio Players & Recorders
Numark
Bring it back to the shop where you purchased it from and it may be under warranty, if not then the problems yours. Try replacing the fuse in the plug. If bought online, then bring to a repair shop if all else fails, email them
May 09, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player Logo
291 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Greg Cann
Greg Cann
robert landry
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
