Question about Whirlpool LSQ8000 Top Load Washer
How to remove inner tub
I have a 9 yr old Whirlpool washing machine and I can't get the inner tub out so I can thrououghly clean the machine. The agitator is out and the spanner nut is off, but the inner tub will not lift out. Can anyone help me?
  • putergurl Apr 07, 2009
    Mine is an 80 series Kenmore, model 110.28892790, I have the same issue. I have removed the agitator and the flat spanner nut, but the drive block and inner tub will not come off the drive shaft.
  • Whirlpool Master
  • 19,396 Answers
How do I remove the top of whirlpool awoe 9140 front loader washing machine?
there are 2 or 3 screws behind the top cover,but this wont get you to where the odor exists,its in between the inner and outer drum,you need to also remove the front cover including the door then remove the inner drum pulley and belt and then split the outer tub to clean out old detergent and fabric softener if you use this as this is where the smell is coming from
Jan 07, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Just need to know how to take front off of washer its a front load the tub is making a racket like something is in it
Do not remove front of this tub. You can remove the item by removing the inner tub fine to reach between the tubs, much easier. You can also remove items in the pump from a clean out if you remove the lower panel. This is also another way to get between tubs, by removing rubber bladder to pump at the bottom right of tub. Good luck, Mastatech
Aug 21, 2011 | Whirlpool Washing Machines
I have a Whirlpool Calypso and I have removed the washplate, lock nut using spanner wrench and u joint assy. I want to remove the metal inner basket so I can clean all the scum inside the outer wash...
Once you remove the agitator, then the nut with the spanner wrench, the basket should lift right out. It may need a little encouragement but it will lift out. I clean the out side tub with a putty knife to get the bulk of the scum off then use some cleaner like 409, or purple power to get the rest off. BE careful around the tub seal around the shaft, you don't want to damage it and have to replace it.
Jan 22, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
How do you get the inner tub all the way out of a old whirlpool machine.
First you must remove the agitor then you see a large nut tighened down wedging the inner basket down it would be best with a spanner and hammer wrench but if careful can be removed with a flat square metal rod and hammer once unscrew pull up and out to remove
Dec 05, 2009 | Whirlpool Washing Machines
I am trying to clean out all the gunk that has built up between the inner and outer tub on my trusty Kenmore 60 series washer. I have removed the agitator and tried to life the inner tub out to no avail. ...
there is a special nut called a spanner nut. it is about 1 1/2 inches and needs special tool to remove it to get the inner tub out of the unit. you might be able to remove it with a pipe wrench and then you can get access to the outer tub.
i would recommend just using a washer cleaner and trying that first.
these chemical cleaners are designed to remove residues and are much easier then taking the unit apart.
Feb 23, 2009 | Whirlpool LSQ8000 Top Load Washer
ouch generally a bad rear bearing..sound god awfull almost hurting your ears to listen too??? a rear bearin replacement requires inner tub, outer rear tub, new pulley. quite expensive repair, if not covered under a warr. luckily multiple yr warr on part offered by manufactue, id cvall so see what if anything would be covered
Nov 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Worn outer tub
yea youl need to replace the tub alright, cgances are the bolts holding the inner tub to the transmission shaft have also broken off, which is why the inner tub spun off kilter and rubbed a hole in the outer tub,. the bolts (2 of them ) woulds have benn locking the inner basket to the tranny shaft, visible after removing the agitator
Apr 14, 2008 | Frigidaire FWS1339A Top Load Washer
Whirlpool top loader 9 kg - I can't see any serial no.
There are no lint filters on this machine. The lint is pumped out with the water. There may be a restriction in the drain line starting where it connects to the tub or the small drain holes in the inner tub may be clogged.
Jan 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Lint Filter in Whirlpool Agitator washing Machine
I have a regular top loader and the lint filter is on the underside of the inner tub. You have to remove the inner tub to get to it. You might be able to find a service manual explaining this at
Aug 22, 2007 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LSQ8000 Top Load Washer Logo
1,157 people viewed this question
Dan Webster
Dan Webster
Sal De
