Question about Canon C130F Black and White Copier
Canon C100 copier
I inherited a Canon C100 copier today. No matter how carefully I adjust the settings, I get dark streaks although the resulting copy is readable and usable for home use. I have replaced the toner cartridge with a brand new one.
Thank you very much,
--angela
  • 1,219 Answers
Its the drum unit that you need to replace and clean the optics-call service
Posted on Jan 19, 2010
Dark streak on paper
you need to clean the rollers. consult the manual about cleaning the copier. if you don't have a manual, then get some methyl alcohol (any alcohol that evaporates completely will do). use a lint free cloth to rub a small amount of alcohol on all roller surfaces (accessible via pull-down compartments on front and back, usually).
Nov 29, 2011 | Canon PC-921 Black and White Copier
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    Have a canon c130.changed toner and still getting dark streaks on copies. Have cleaned all I could find inside still dark streaks
    Try doing a "stop test." You would induce a jam before the paper reaches the fuser.
    Just open a cover while printing and hopefully some image has been transferred to the paper. If the defect exists already then the laser unit, or document scanner may be causing it.
    If that eliminates the dark streak, then obviously the fuser FG6-3720-000 should be changed.
    Whit
    Item, Inc
    Aug 18, 2010 | Canon C130F Black and White Copier
    Dark black streak down the middle of the page
    sounds like your cartridge is leaking. I'd try replacing the cartridge
    Apr 30, 2010 | Canon PIXMA MP830 All-In-One InkJet...
    Dirty print - dark streaks across top of document
    Check the PC drum,if dirty clean.Has toner spilled from the I/C inside of the copier?Clean.Is the PC drum charge voltage terminal in good condition?Check and change if necesary.Is the grid voltage terminal in good condition?Check or change if necessary.Are the fusing rollers dirty with foreign matter?Clean or change.Clean the mirrors,lens and original glass.
    Aug 06, 2009 | Canon imageRUNNER 2200
    Hi, my canon mx310 is showing a daRK line when we
    Use a flashlight and look closely at the narrow glass next to the platen glass. I usually find a spot of white out on the glass causing the streak. Also a dark spot on the white guide above the glass will cause a streak like you mentioned.
    Jun 22, 2009 | Canon PIXMA MX310 All-In-One Printer
    Want a B&W copy from colored sheet of paper w/o dark background.
    It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
    Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
    Dark streaks
    Dark streaks are an indication of "burned" or overheated ink. This will occur when the printer sets for a long period of time and nothing is printed. The problem will usually disappear after 50 pages or so, unless the printhead is damaged.
    If the print remains dark, the printhead will need replaced.
    (Very expensive)
    (Dark print can also be caused by using Non-Xerox ink)
    Sep 10, 2008 | Xerox Phaser 8400 Laser Printer
    Poor quality copies from the Canon NP 7130F
    hi im jules_09.have check the drum unit and the fuser unit check the two unit.first of all the drum unit the drum may be scratch or damage that goes with the fuser unit too.
    Dec 12, 2007 | Canon NP 7130 Black and White Copier
    Canon pc-6re
    have you tried adjusting the image density dial located inside the front door?
    Dec 10, 2007 | Office Equipment & Supplies
    Canon C130F Black and White Copier Logo
    109 people viewed this question
    old marine
    old marine
