Question about Frigidaire FDB641RA Built-in Dishwasher
Frigidaire dishwasher model# fdb641rab1 Door latch wiring diagram
I have a Frigidaire dishwasher model# fdb641rab. The latch broke so I removed the old one and ordered a new part. I failed to mark the wires. I have a black and a white from the power source which has straight spade connectors and a black and white that leads to the cycle control which have right angle spade connectors. The latch assembly has a space on each side for 1 pair of wires. I need the configuration of where the 2 sets of wires go specifically. Can anyone help.
5 Suggested Answers
  • 1003 Answers
SOURCE: FDB768GCC0 model Frigidaire Gallery series Dishwasher
REPLACE TIMER
Posted on Jan 18, 2008
  • 89 Answers
SOURCE: frigidaire dishwasher
Next thing to look at--considering all the power is good--although that's what I'd check on again, would be the door switch. May have to remove the control panel cover or the door interior.
Try www.repairclinic.com if you need parts.
Posted on Oct 28, 2008
SOURCE: Frigidare Gallery Pro Dishwasher Control Panel Power
It can be the problem with the transformer. Try replacing it with another one.
Posted on Dec 15, 2008
WRMtech
  • 70 Answers
SOURCE: Installed new soap dispenser; forgot to mark wires
it does not matter. you can place them either way :-)
Good Luck!
Posted on Feb 26, 2009
SOURCE: Frigidaire Dishwasher (model FDB1050REB0) Wash Light Flashing
Well, I've got a different problem. I need a control module!!!
BUT!
The flashing WASH light appears to indicate the door latch (switch) is not fully engaged. I proved that I mine which works, just doesn't pump out/drain water. If I unlatch the door and then press START, the WASH light blinks.
*WARNING* 120V ELECTRICAL CURRENT! ONLY ATTEMPT THIS IS YOU KNOW WHAT YOU ARE DOING!
The switch is located behind the control panel (5 screws from the inside.) The Hot (Black) AND Neutral (White) wires comes from the electrical input and pass through the switch. You can do a simple continuity check with the power disengaged to test the path through the switch and into the control module (pins 3 & 9m black and white).
Now... anyone have a Control Module (working) they want to give/sell to me so I don't have to go buy a new dishwasher? I just replaced the drain valve on mine :( If you do, you can send me a note vidioteic (at) gmail (dot) com
Happy Washing!
Posted on Mar 28, 2009
THE LATCH IS READING THAT THE DOOR IS CLOSED BUT I CAN OPEN THE DOOR WHILE THE DISHWASHER IS IN CYCLE. WITH THE SPRING INDISE THE DOOR BEING LOCKED IT WONT EVENT LET ME FULLY SHUT THE DOOR! ANY HELP.
Hello friend, thank you for your post!
From what you have described the spring from the latch is broken inside of the door and you are unable to close your Frigidaire dishwasher. You would need to disassemble the dishwasher in order to replace the latch or spring. This needs to be done by a professional technician as improper disassembly could results in personal injury. I hope this information is helpful to you. -Matt
Feb 19, 2016 | Frigidaire Dishwashers
Frigidaire dishwasher model fgbd2431kw1 not working after power surge
Good Morning Cary, I am happy to assist you!
Let's try resetting your dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn dishwasher back on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Nov 02, 2013 | Frigidaire Dishwashers
FRIGIDAIRE dishwasher door won't latch
Check to see if the door is not aligned correctly anymore, or if the door sags underneath the latch plate and go from there. You may need to adjust the door or replace the latch itself.
Jul 21, 2012 | Frigidaire Dishwashers
Frigidaire Model Number FDB1100RHM0 Dishwasher does not do anything. All switches on front panel seem to work and the water is turned on
proceed with this step:
Power from the house
test for some blown fuse or c. breaker reset.
Door switch
if the swtich door if open or defective, will not start the machine see the wiring diagram attached.
Wiring
see for wires, burn, breaker or loose repair.
Timer or selector switch
test the timer, for contact dirty, or corred, clean, and tigh the wires loose see the diagram attached.
May 07, 2012 | Frigidaire FDB1100RHM Builtin Dishwasher
The knob broke off. How do I fix it?
well if you broke only the knob, then thats an easy fix.. just obtain part # 154535903 - KNOB and replace.
however if you broke the shaft off inside the knob you will need to procure part # 154668901 - CONTROL MODULE
remove power from the dishwasher and remove the screws holding the inner door panel to the door.
once that is removed you should see the control assembly and related wire harness that needs to be disconnected and screws that need to be removed, etc..
hope that helps,
best of luck,
ttfn
Oct 19, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
The latch on the door broke and the machine will not start when the door is closed. Can we fix this ourselves? It is a Frigidaire #FDB641RJS1 dishwasher.
This is a repair that you can easily perform yourself. The part number for the replacement latch is 5304442173. Go to repairclinic.com and type in the this part number and they will also include a new door gasket. All their parts ship with instructions on how to replace as well. Just make sure you secure power to the dishwasher before servicing. If you need assistance with replacing the part, please let me know. I hope this helps you.
Aug 19, 2009 | Dishwashers
Dishwasher loses power
you have a loose ground wire, the is a wire under neith that is a gound that connets to the frame, check to make sure that the wires in the wire nuts are not broke also, even if they look good they could be broke
May 30, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Frigidaire dishwasher door won't close
with aa small thin screwdriver you can try to pry the "latch/catch "back to an open positon
Dec 17, 2008 | Frigidaire PLD4375RFC Dishwasher
Wiring diagram on door latch for Frigidaire dish washer model number fdp635rfr3
http://www.frigidaire.com/support/ResultsPage.asp?strModel=fdp635rfr3&User=
you will get on this web side all manual digram parts no
Aug 13, 2008 | Dishwashers
Frigidaire FDB641RA Built-in Dishwasher Logo
445 people viewed this question
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
