Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Magnavox 60 Replaced the chip for shrinking and now I have an inward bow at the top and bottom of the screen.
  • 1 more comment
  • gr2000css Aug 29, 2008
    The model # is 9P6034C101, Chasis Model# PTV835. I replaced the chip HCNW136-000E, recomended on the Magnavox help site for shrinking and expanding picture. The day before I replaced the chip is when the new problem started. The chip fixed the 1st problem.
    Thank You
  • gilster463 Sep 03, 2008
    when i turn on the tv the picture has a black bar down the left side and then the picture starts to shrink and has blue and green color on the left half of the picture and red and yellow on the right side. the t.v. goes black then the picture comes back on and the shrinking starts all over again. please help.
  • BigTVgonebad Oct 09, 2008
    I have an inward bow at the top and bottom of the screen on a model 9P6034C 60" rear projection. please help!
  • Philips Master
  • 3,459 Answers
If you have any of the following problems you may want to check the site www.tvrepairkits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
Symptom: Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
(Note: The below symptoms typicaly occurs after having the expanding/shrinking screen problem above)
Symptom: No Audio or Video but power light is on
Symptom: Audio works but no Video. Power light still work
Symptom: No Video. Audio is intermittent. Power light still works
Posted on Oct 12, 2008
  • Edward
    Edward Oct 12, 2008
    If the inward bow is stationary check the 1007 & 1405 Fuses.
  • Edward
    Edward Oct 12, 2008
    FYI - If the inward bow is stationary check the fuses 1007 & 1405 Fuses
  • Philips Master
  • 8,617 Answers
Which chip did you replace? and what is the model number of your set?
Posted on Aug 29, 2008
Poor picture quality. Picture also tends to curve
The curving is caused by bad digital convergencr chips (2) located on large signal board. They need replaced along with blown pico fuses and the convergence resistors. Chips are huge compared to a regular IC. 2" x 1.5" and they will be bolted on fairly large heatsinks. Cloudy picture is most likely the coolant needs replaced in the picture tubes. This needs to be done approximately every 5 years.
May 01, 2010 | Philips Magnavox 9P6034C 60" Rear...
3-d effect it appears on the top and bottom of screen it slowly progressed inward
This convergence out ICs failure symptoms in TV and you need to replace two convergence out ICs in convergence out section / board in TV
if you are not familiar with TV repair then call qualified Tv tech to fix it.
Apr 15, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture arches down at the top and arhes up at the bottom
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 08, 2009 | Philips Magnavox 9P6034C 60" Rear...
Tv Colors are bad
You have a convervence problem. You will need to replace both convergene chips and possibly the resistors. You can get more information and a repair kit with instructions from www.TvRepairKits.com
Jan 09, 2009 | Philips Magnavox 9P6034C 60" Rear...
Color seems to be pealing up from the bottom of screen
If the screen is bouncing...expanding/shrinking you need to get a repair kit from www.TvRepairKits.com
If your screen looks 3d in color, has a stationary bow, or if you can't adjust one or more colors from the "convergence" menu you need to buy a convergence repair kit. You can get one from the same site listed above.
Hope this Helps,
Nov 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox 60" model ptv835
Recently had same issue and after EXTENSIVE SEARCHING found all three ICs and replaced them. TV works perfectly, also, replaced convergence ICs at same time. The one 16-pin IC for the regulation ckt. is $49.95 the other 16-pin IC is $19.95 and the 8-pin opto is about $10. This price is for a minimum qty. and must have a business for quote.
Aug 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
60" TV has an arc in the pic
Check the fuses 1007 & 1405. If they are blown in will cause an Arc.
Note: If the screen shrinks/expands you may need a chip kit from www.repairkits.com
Aug 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
Convergence with new chips
im not too sure if those are compatable chips.... if they are then at least you would have to service mode converge the set. something a tech would need to do.
May 02, 2008 | JVC AV-56WP74 56" Rear Projection...
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
165 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
