Question about Toshiba TZ50V51 50" Rear Projection Television
Cracked Toshiba TZ50V51 outer screen
I need a lenticular screen for the TZ50V51, it is cracked. Do you know where I can find one?
Thanks,
Fernando
  • 125 Answers
Andrews electronics at santa clarita ca
Posted on Aug 29, 2008
I got a toshiba tv and cracked the screen on it wer do i get a new screen 4 cheap
pigdigger,
I have bad news for you, the total cost for the three screens you will need will be about $290.00. They can be obtained from http://www.encompass.com . Here are the part #s: Fresnel 23311898 $80.00, Lenticular 23311897 $120.00 and Protector 23311863 $90.00.
Installation is straight forward. Generally you have to remove the back top cover with the mirror attached. Then check under the bezel on the front, below the screen, for several screws. Remove the screen and lay it flat on the floor. Remove the screen hold in screws or clips. Remove the screen.
Assemble the new screens. Make sure they are in the correct order. Protector (on outside), Lenticular in the middle and the Fresnel on the inside. You will need to secure the screens together. Black cloth tape works well around the perimeter. Reinstall the screen into the frame and reassemble the unit. This should complete the job.
Thanks for using FixYa and for the great rating.
hardrocko
Sep 29, 2010 | Toshiba TZ50V51 50" Rear Projection...
Toshiba TZ50V51
andrews electronic in santa clarita ca but they are very expensive your best option is to find a used one
Aug 21, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba TZ50V51 50 in. Rear... Problem:
The Toshiba part number is: 23837513, but htis part is listed as no longer available. All you can do at this point is to try and call different Toshiba parts distributors or service shops to see if anyone still has one around.
Dan
Aug 19, 2008 | Toshiba TP50H50 50" Rear Projection...
Replacement lenticular screen Toshiba 50"
i need a lenticular screen for my 50 inch GE rear projection tv. model number is 52gw948 and i also need an outer protective screen as well. you can email me at mweezzee@yahoo.com
Aug 18, 2008 | Toshiba TZ50V51 50" Rear Projection...
I would need to know just the width and heigth of the viewable screen area in order to help you out.
Aug 17, 2008 | Toshiba TZ50V51 50" Rear Projection...
Lenticular screens...
yes just need to know your size. measure height and width, and i will check the inventory and let you know.also specify if you need both screens lenticular and the outer protective screen
Mar 26, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba TZ50V51
I have same problem my screen is cracked and cant find a place for parts.
If someone replies they will answer to postings.
Thanks
Shag
Sep 09, 2007 | Toshiba TZ50V51 50" Rear Projection...
Toshiba 50a60 cracked screen
i have just experienced the same myself, what you need to do is find a tv the same size, it doesnt have to be the from the same manufacturer, although it helps if you can get the same, as all lenticulars do the same job.
The outer screen is called the Lenticular, and the inner is called the fresnal, depending how bad your lenticular is cracked will determine if your fresnal has gone also, the only real way of knowing is when you take it apart to change it, (Dead Easy).
they are quite close together, but dont be afraid of trying, i have never changed one before, but i did it in about forty minutes and i dont know the first thing about tvs and now it is as new.
to change it, all you have to do is unscrew the front of your tv, from the surrounding screws at the back of it, once you have done this there are four or five small screws that hold the front of it up, take these out and your front will come off complete with lenticular and fresnal.
place it face down on a soft surface, so as that you are looking out of the inside of your screen, and you will see the fresnal.
they are held together with four brackets, one on each side of the screen.
unscrew the brackets, and take the fresnal off, then the lenticular.
put your new lenticular in, then the fresnal on top of that, and then secure it together again by screwing the four brackets back on.
it really is that simple, do not let these TV repairmen, scare you into buying a screen from them and charge you an extortionate amount of money to fit it.
im not sure if plexiglass will work, i was quoted £160+VAT for my screen from Toshiba, so what i did, i went on Ebay and found a full tv that was for spares or repairs, and paid £26 for it, and it is just as it was before.
One thing you must not do when attemting to change it, and that is to be scared of attempting it, because once you have done it, and at a fraction of the cost, you like me will curse the people who make a living out of overcharging people for such an easy job!!!!
Good Luck, and hope this has helped..
Doolb
Aug 26, 2007 | Toshiba 50A60 50" Rear Projection...
Toshiba TZ50V51 50" Rear Projection Television Logo
81 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
