Question about Scunci 52001 Handheld Steam Vacuum
No steam in scunci steamer will not work lights uop hear pressure and heats up
  • Anonymous Dec 05, 2008
    sparo13617@yahoo.com
  • Anonymous Dec 07, 2008
    The arrow needs to be turned the opposite way. The calcium builds up. I have been looking for the same solution.
No steam in scunci steamer, it does gets warm but no steam at all. like if it was blocked
Posted on Nov 24, 2008
My steamer heats up but no steam come out. There is also a dial on the nozzle with an arrow, that I can not move. my phone # is 239-333-9844
Thank you! Joanie
Posted on Nov 29, 2008
I followed the recommendations that were described ,tore the critter apart washed in distilled water and a tad of WD40 and all is well. the Company involved should recommend the use of distilled water
Posted on Apr 15, 2013
What recommendations ...I have the same problem
Posted on Apr 21, 2013
How do I get a stuck top off a Scunci ss1000 steamer?
try putting it in a freezer for awhile cold makes metal shrink and that may loosen the top .
Dec 07, 2017 | Scunci Ss1000 Steamer Irons/Steamers
Steam will not travel through hose scunci steamer ss1000
Blocked with limescale maybe? if its heating to correct temperature to disperse steam then I has to be blocked, that or its not heating up to boiling heat
Mar 03, 2014 | Vacuums
Can't get cap off a scunci portable steamer
make sure there is no pressure in the tank by pulling the triger then press down and turn antyclockwise.
Sep 15, 2012 | Scunci 52067 Handheld Steam Vacuum
Need a manual for the hand held Scunci steamer
Try this:
http://www.ehow.com/how_4811845_use-scunci-steamer.html
May 15, 2010 | Scunci 52000 Handheld Steam Vacuum
Scunci steamer will not heat up
Take the bottom off (Just break it after you get the two normal screws out), find the white wire from the element, bridge the offending fuse located under the special insulation, with a piece of wire, if you cant replace it, re assemble, and steam away. If the lack of that fuse worries you, don't do this, just pitch it.
Jan 13, 2009 | Scunci 52000 Handheld Steam Vacuum
My scunci steamer fell off while collectin the power cord it broke its can it be plastic body around the triger can it be fixed? can it be replaced?
if the steamer still functions... use some glue that would be resistant to heat and works on plastic... i'm drawing a blank at the moment as to what glue would work. actually when i read that again... it broke it's can... you mean cannister ?
Robert
Sep 22, 2008 | Scunci 52067 Handheld Steam Vacuum
Heats, but no steam.
The people who manufacture this unit and box it are idots. The manufacturer should that steam can be dangous, and , a user manual should be shipped inside the box. Hey SCUNCI STEAMER dum dums,. Put a printable manual on the site so your customers won,t get hurt by not knowing robert ferriss
Aug 29, 2008 | Scunci 52001 Handheld Steam Vacuum
Scunci ss1000 handheld steamer
My Scunci MS 1000 heats and builds up steam, but the steam does not release from the spout when the release button is pushed. Plenty of pressure is built up inside (escapes when cap is opened). What is the problem?
Aug 03, 2008 | Scunci 52001 Handheld Steam Vacuum
Scunci steam cleaner not spraying steam
Unscrew the screw on the handle and remove handle. Remove rubber where top screws on. Remove two screws and the top and now unscrew the black pipe where the steam comes out. Now remove the button and see the small metal protrusion on the pot where the button was. Hit it with a hammer a few times softly to remove the scale buildup until the metal starts moving in and out again. I also sprayed it with a little silicone spray. Now put everything back together again. My steamer now works beautifully again!
May 24, 2008 | Scunci 52067 Handheld Steam Vacuum
Scunci 52001 Handheld Steam Vacuum Logo
1,593 people viewed this question
Top Scunci Vacuums Experts
ray gallant
Are you a Scunci Vacuum Expert? Answer questions, earn points and help others
