Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by side Refigerator an Freezer
Our GE side by side which is only four years old has just "gone hot" the refigertor is now at 88 and the freezer is at 40, any idea what to do ?
    Scholar:
  • 62 Answers
Check to see if the condenser fan maotor, located at the back bottom is working or not, If the motor is not working the problem could be the main control board if this is an electronic contol ref. it will need replacement. Try using a fan and letting it blow on the coils and see if it cools down. Check the compressor to see how hot it is getting if you can. This is the most common problem. you could have something else. Hope this helps.
Posted on Aug 31, 2008
I have a 15 year old side by side ge profile refigerator. The floor of the freezer constanly freezes order and leak under the freezer side, What is the cause?
LOOK IN SIDE THE FRZ ON BUTTEM BACK WAY LOW BACK THER A DRAIND AND IS PLUG UP OR FROZER NEED TO UN PLUG TRY TO USE HOT WAER AR A HOT STEMER TO UNPLUG DRAIN.
Feb 21, 2012 | GE Profile 26.6 cu. ft. Side-by-Side...
GE side by side ADORA, refer and freezer or not cold, cleaned and unplugged to maybe reset. Unit is 4 years old.
return air ducts from the freezer may be iced up, unplug unit and use a hair dryer to defrost. The ducts will be behind the rear panel, but just let the hot air circulate for a couple of hours to really defrost it
good luck
Nov 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My two year old admiral refigerator has air entering freezer part
lube the hinge side, sealing face of gaskets with vasoline. Heat gaskets with hair dryer then tape doors shut when hot. wait an hour before removing tape. do this on both doors.
Aug 26, 2009 | GE GSH25JFR Side by Side Refrigerator
GE side by side
Something has gone bad in the defrost circuit.(Heating element was notorious for this) but could be a timer or thermostat. Frost buildup will cause inefficient cooling as will dirty condenser coils.
Eric
Jun 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water on Floor Outside Freezer (Side by Side)
take a wire and run it through the drain until there is no resistance and then put hot water into it.
Mar 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Outside front of freezer side ,not the door, is very warm. is this normal?
this is normal. some of the hot pipework is led across the side and across the transom between fridge and freezer to prevent condensation
Sep 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side not cooling properly/outside surface hot
please check the condenser fan motor. it is probably not running or the condenser is very dirty.
remove the rear cover and it will show you the compressor and the condenser fan.
if the fan is not running, try to rotate it manually and feel if it is sticking .
if it is, it may just need the old wd 40 lubricant.
tnx 4 using fixya,
drcool
Sep 07, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE Side By side doesn't cool and freexer frosts up
Most common problem on GE's is the defrost heater(s) has gone bad. They are a glass tube and when they go bad the tube will have a burnt or black color to it. A good heater will be clear. I bet that is your problem. Seems to be the problem about 90% of the time on GE not defrosting.
Jun 29, 2008 | GE GSS20IEP Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
80 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Brad Goodale
