Question about RCA HD61LPW42 61" Rear Projection HDTV
Realistic Lamp Cost ??
TV has no picture - we figure it's the lamp b/c best buy told us we'd need to replace in a few years . But when i called local TV service repair they told me $600 .... then i look online and i see a price for $139 - does anyone know how much i should pay ?? thanks!!
139.00 seems reasonable for a replacement lamp. is that the only problem that you are having or are you hearing a squealing sound and then the tv cycles off?
Dan
Posted on Sep 20, 2008
How do I know if I need a new lamp?
Yes, if you have not replaced the lamp since you purchased this TV.
Lamps usually last about 6000 hours.
I've seen lamps last much longer than 6000Hrs, it all depends on the usage.
Remove the lamp from the TV and do a visual inspection, see if there's a crack on the glass or the bulb.
If the TV is few years old then the Lamp may be bad.
Buy original Lamp: 800 638-3328
https://www.encompassparts.com/
DO NOT BUY the cheap lamp from ebay
Good luck to you.
Nour Sabre
www.tvservice.com
May 24, 2012 | Sony Grand WEGA KF60WE610 60" Rear...
Turn set on picture is dark.. if I leave the TV on.. in several hours it's viewable.
I have seen several Samsung's including 3 that were only a few months old at the time where it was the lamp---one was so dim it was very hard to even see the picture or that the screen was lit.
Two suggestions here: One of course would be to buy and gamble and replace the lamp.
What I found in two of the three cases was when I removed the lamp the glass pillar inside it was "bent" at a angle from heat or a natural defect--in both those cases a new lamp cured this dim picture issue.
Set will monitor the lamp and if too dim may shut set off or even blink for a prolonged period of time.
If the lamp is over 2 years or age (average life) or was replaced with a non-Samsung lamp you are going to have to take the gamble to try another one.
Inspect the lamp---that pillar supports the filament and if bent the lamp is suspect at best.
May 20, 2012 | Televison & Video
I have an RCA DLP tv model HP50LPW52. the sound was there with no picture. since it is 5 years old I replaced the lamp for the first time. got it all hooked up, turned it on and the tv slowly came on....
That is your Color Wheel that is bad. I wish you would have posted the problem before buying a lamp. I would have told you to treat yourself to a new set instead of putting good money into a DLP set that is 5 years old.
Feb 10, 2011 | RCA Televison & Video
The TV toll me to some light was ready to expire. What do have to buy??my screen is off.
Your tv needs lamp replacement that was said, required lamp for tour JVC HD-56G787is available with discount-merchant.com for $135
Replace lamp in tv to get its picture back, call local tv repairman to replace lamp if you feel uncomfortable doing so.
Thanks.
Nov 16, 2010 | JVC HD-56G787 Television
Tv lost picture, when you shut it off, it turns back on with a line in picture and lamp light is flashing. Is this just the lamp or something else? I was told this is common on this tv
Lamp will last Appox 2 years with 6 hour a day use or 4000 hours. If it's the blub shop it online use TV model # Cost $75-$100 Not sure what to do call a TV tech.
Good Luck!
Oct 11, 2010 | Samsung DLP HL-P5663W 56" TV
No Video/Sound,POwr Gren LiTE Blinks 4Ever, SONY WEGA KDF-55WF655
Please check lamp in tv as pop sound seems broken lamp.
Did you replaced lamp in last 2-3 years in tv? If not, then its lamp that got broken and tv needs new lamp.
Lamp replacement procedure is written in user manual and its easy, please buy Sony original lamp for good picture in tv.
Thanks.
Apr 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Panasonic projection tv model # pt56lcz7 no picture, bulb out?
This unit does not have the usual lamp assembly that most do. On this unit the whole light engine has to be removed to replace the lamp assembly. Part number is LFS4000PA1 and cost is $1,351.95 @ www.partstore.com.
Sep 01, 2009 | Panasonic PT-50LCZ70 50" HDTV
Picture and sound go off for a few seconds and then come back on.
When the bulb goes off with the sound. The lamp is starting to fail and you need to replace it. Wear gloves when replacing the lamp. Use XL-2400(part # F93087500) replacement lamp. For information visithttp://sonystyle.com/tv for US residents and http://sonystyle.ca/tv forCanada residents.
  1. Remove the outside lamp cover.
  2. Turn the knob counterclockwise to OPEN and pull out the cover.
  3. Hook a finger through the loop of the lamp handle and pull the handle upwards then pull the lamp straight out.
  4. Putthe new lamp in its place. Mount it securely and take extra care not totouch glass portion of the lamp.
  5. Turn the knob back to CLOSE and secure the cover.
  6. Put the outside lamp cover back in its place.
  7. Turn on the TV
  8. Browse MENU>SETTINGS>SET-UP>Lamp Replacement then follow the on-screen procedure.
NOTE:Dispose the used lamp properly. It contains mercury and disposal isregulated..Contact your local authorities for proper disposal.
Aug 23, 2009 | Sony Televison & Video
LG 44SZ8D not turning on
The red light indicates the lamp is burned out. A new one is $100 to $200.
Depending on whether you use the old housing or want to order the lamp and housing together. There are lots of sources for this lamp online.
Once the lamp is replaced, it will be good as new and the lamp will last aprox. 8000 hours.
Apr 06, 2009 | LG DU-62SY20D 62" Rear Projection HDTV
Have a green tint over 90% ot the center of the screen
I had the same problem with my 60V500A about a year ago. The screen got a red tint in the center and the image was fuzzy in that area. A new lamp didn't solve the problem. I did some checking and found out that the original light engine used in this model had a cooling issue that could cause the light engine to overheat and distort the LCD panels. My warranty had run out more than a year before this happened so I figured I was screwed since the light engine was so expensive. I decided to call Hitachi tech support and see if I could get a discount on the cost of a new light engine since the cooling problem was a known issue for this model TV. I calmly explained to them that I was aware of the cooling issue in the light engine and that I felt like a $4000 TV should last more than two or three years. Tech support gave me the phone number for my local authorized Hitachi service center and I gave them a call. Once the technician confirmed that it was the light engine that was the problem Hitachi sent him a replacement light engine at no cost to me. I was WAY past my warranty period so I still had to pay for the labor to replace the light engine. $300 for labor was a lot cheaper than buying a new light engine or tossing the TV and buying a new one. I have to say that Hitachi earned my respect for admitting there was a problem and doing what was needed to correct the problem more than a year after my warranty had expired.
Feb 20, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
RCA HD61LPW42 61" Rear Projection HDTV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
