Question about Amana Kitchen Ranges
Replacing right front dual ribbon element in glass top electric range model ART6610WW. There are five contacts: 1a; 1b; 2a; 2b going to the dual limiter and one (no lable) going to the element (2 prongs, one hard wired to 1a. There are five disconnected wires: purple; red; brown; brown with white checks; white with black checks. Can't find a wiring schematic. What goes to what?
  • leemun Aug 29, 2008
    OK, Wiz, let's get on with this
  • billypep2001 Jan 13, 2009
    i have the same issue but just a diff model stove - it's an Amana - Model# ART6610WW and P/N#P1142674NWW....the dual ribbon burner has a break in the ribbon going to the large burner side....can this be repaired?....i doubt with solder but will ask anyway...if not solder how?'s not burned in any way just broke right where the clip is...i can actually make the contact holding it and then able to check the continuity with my ohm meter and it's fine......would hate to spend $80 for a new burner if i can just add a new clip or solder it...please let me know...thx much!
Can't remember ware the wires go. Help!!!!
Posted on Jan 06, 2011
I have obtained a replacement element Whirlpool AP5653770 for my Jenn-Air JEC8430ADS cooktop. I have lost the secmatic I made showing the colopr of wires going to each position on the element. I have a...
This is the correct way to wire the right front burner on Jenn-Air JEC8430ADS cooktop. Let's do the red wires first. The red wire that comes from #2 on the switch goes to the common connection for the element that should be labeled 2a. The other red wire goes to either of the "b", hot surface indicator switch contacts and the black to the other. Use 1b or 2b for these connections whichever reaches easiest. The yellow wire goes to the inside loop of the burner and the tan to the outside element.
Dec 04, 2013 | Jenn-Air JED8430 Electric Cooktop
I need a wiring diagram for husky power washer 1750. I took the power switch out and I can't remember how the wires go back on.
Connect the black and white to the 1A and 2A (on side) then connect the gray and tan to the 1B and 2B, Black to 1A and Tan to 1B
Sep 16, 2013 | Garden
Firing order and cylinder number of rolls royce merlin aero engine
The firing order of the cylinders was 1A, 6B, 4A, 3B, 2A, 5B, 6A, 1B, 3A, 4B, 5A, 2B (where A is on the right viewed from the pilots seat- B on the left- and the rows are numbered with the front row being 1).
Feb 03, 2013 | Cars & Trucks
1a-6b-5a-2b-3a-4b-6a-1b-2a-5b-4a-3b idle 4deg a.t.d.c. hope this helps
Apr 28, 2011 | Jaguar Xk Series Cars & Trucks
What is the firing order & position of spark plugs in jaguar xj8
V6 is 1,2,3 on the right and 4,5,6 on the left....Firing order is 1,4,2,5,3,6
V8 is 1,2,3,4, on the right and 5,6,7,8, on the left.....Firing order is 1,5,4,2,6,3,7,8
Jaguar labels this as 1A,2A,3A,4A on the right and 1B,2B,3B,4B on the left and the firing order is 1A,1B,4A,2A,2B,3A,3B,4B
Mar 19, 2011 | 1998 Jaguar XJ8L
Model MES5770AAB Serial 11517659WK The single element, 700 watts came with a wiring kit for a new connections. My range has "Old connection type 1" . the moddification kit (A-30001, Revision 4) shows...
Ten to one the elements will have to be changed also. Call or email Maytag about your dilema. You can simply reject to pay me also on this one
Jan 21, 2010 | Maytag Kitchen Ranges
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Replacing a radiant element on a maytag glass top range I'm having strange problems with the two right elements of my MER5770 The front larger dual element will only operate at high heat. When turning on...
If the burner is scorched or pitted, go ahead and replace it. New burners can cost anywhere from $10 to $40. Otherwise, check the burner's electrical connections to make sure there is solid contact. Jiggle the burner in its socket. If it is loose, then remove the burner—most just pull out of the electrical socket, although some are mounted with a screw. (Always unplug the range before removing a burner.) Slightly spread the two terminals apart for a tighter connection. If it still doesn't work, then replace the faulty burner with a functioning burner of the same size. If that burner works, then replace the bad burner with a new one. If it doesn't, then inspect the electrical socket for damage. If it's charred, replace the socket. To do so, remove the screws that secure the socket to the range and then unscrew the range wires. Attach the wire connections of the new socket to the range wires and reassemble the burner.
Aug 19, 2008 | Kitchen Ranges
yea sounds like an issue for sure, nut not with the element but hte switches instead, theres a short in one or the other( most likely the dual switch) i wouls reccomend replacing both the switches, the elemenst should be fine.
May 24, 2008 | Maytag MER5770 Electric Kitchen Range
Burner no longer functions
two thiongs, you might have a bad switch( under control knob), or before you try that ck the old elemnt that you replaced, on the back of the limiter( the glass rod that goes through elemnt itlself), you'll see little letters 1a,2a,1b,2b.--- new replacemnets depending on age are wired differently, they too will have 1a2a1b2b but in different position. id check that first
Mar 02, 2008 | Jenn-Air JES9800AAS Electric Kitchen Range
Kitchen Ranges Logo
171 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
