Question about Video Game Consoles & Games
Msi.chm\msdn c:my programsassetsmoviekurtcs55sfd. verify this so that i can continue my installation of my game xmen 3 istallimg Ut 3 says error please verify these files exist
  • 52 Answers
It seems that the file c:\programs\assets\movie\kurt\cs55sfd is corrupt or cannot be copied from the source
Posted on Sep 27, 2008
MS vista and MS office 2007 installation
You install disk is corrupt (probably from a scratch on the disk), you can download a new copy to burn, making sure it passes the MD5 checksum after download is complete (and use your key during installation).
Jun 28, 2013 | Dell Computers & Internet
Need to re-install ms office 2007-get setup.CHM error- for XP - n/disk
The setup.CHM error appears when the previous install is still there in some form. Run the uninstaller if it still appears in Programs, then manually locate and wipe all the Office folders left in in C - especially those in Docs and Settings. Now reboot and run install and run a cleaner like this one. Now reboot once more and install and run a registry cleaner like this one. Reboot once more and you will now be able to reinstall.
Sep 26, 2011 | Microsoft Office 2007 Basic for PC
When playing games on using my new MSI GTX 570 Twin Frozr/OC every once in a while the screen goes black for two sec. and the sound hangs and repeats. Some games like Crysis 2 and CODbo continue after this...
I believe that your GPU is ok, have you updated your Direct X? Go to this Microsoft website to download the latest version of Direct X. Also, have you verified that your power supply has enough watts to power your system?
Jun 13, 2011 | MSI N570GTX Twin Frozr II OC GeForce GTX...
Error 1603 contact Msi.chm for help on Call of Duty 4mw
Hi. Error in installtion is a windows problem. I provided you a link on how to resolved the issue. Please click here.
Sep 12, 2010 | Activision Video Game Consoles & Games
ERROR:-1603 fatal error during
1) Click Start > Run
2) Type msiexec /unreg and press enter and wait until it appears to have
finished.
3) Go back to Start > Run
4) Type msiexec /regserver and press enter.
5) Try to install 'management' again.
Jan 13, 2010 | HP Pavilion DV6700T Notebook PC
Activision Call of Duty 2
The msi.chm refers to the windows installer help documentation.Probably by any chance, the dvd is scratched making the that particular set of installation files unreadable. Try copying the disk contents to your hard drive prior to installation.Then make the installation from hard drive. There is no other solution because the Error itself is not clear.
Nov 17, 2008 | Activision Call of Duty 2 for Windows
Error 2753 HP3055
My Scenario:
OS: MS Windows XP SP3 [Version 5.1.2600]
Printer: HP LaserJet 3390 (AiO) (Firmware datecode: 20070331)
Printer Connection: Connected via Ethernet with a static IP address
HP Driver Version: v4.0 (hp_LJ3050-3052-3055-3390-3392_Full_Solution_AMWE.exe)
Ran into same error that everyone else is experiencing. (see below)
Now Launching=X:\hpzmsi01.exe -m dot4msi -l XXX -f X:\DIVins??.DAT
Error message received: The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2753.
X:\HPZBDI32.msi failed with return code 1603
MSIInstall() failed with 1603
Exit code=1603
After debugging HP's installation scripts for 2 days, here is the cause & solution I identified to this specific install error. Once I got passed this error, everything installed without error and all functionality was working properly (including scanning!).
BACKGROUND:
Microsoft Installer (MSI) error 1603 is simply a generic "A fatal error occurred during installation" -- see http://msdn.microsoft.com/en-us/library/aa368542(VS.85).aspx. This is basically MSI telling you that something very bad has happened during the installation. In order to get more details, you can turn on MSI debug logging by following this MS Knowledge Base article (http://support.microsoft.com/kb/223300).
The MSI error code 2753 is the code for "The File '<file name>' is not marked for installation.". This error can be triggered by many scenarios, but usually, it has to do with the actual installation script not properly checking for the existence/non-existence of an installation file and then not marking it for either installation/removal. I know this sounds confusing, and it is. If your curious about all the possible causes, just Google for "msi 2753 not marked for installation" and you'll see lots of results which you can peruse for your own enjoyment.
In order to identify what was causing these 2 errors, I enabled debugging for MSI via the aforementioned MS KB article
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
If all goes well, the install should now run without any issues.
Hope this helps since many people (including myself) have spent a lot of time (and HP Support chats) trying to find a workaround for this issue.
If you find this solution helped you out, please feel free to make a small donation to my PayPal ;)
Jun 26, 2008 | HP LaserJet 3055 All-In-One Printer
Navigation fatal error Error 1706
oops..sounds like maybe your drivers are unhappy...
Mar 09, 2008 | GPS
Video Game Consoles & Games Logo
864 people viewed this question
Top Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
