Question about RCA P52926 52" Rear Projection Television
Squealing noise When you turn the tv off and then try to turn it back on it makes this high pitched squealing noise. If its something like the colorwheel where do I get parts for it and how hard is it to fix?
    Genius:
  • 2,920 Answers
A shop will need to do the repairs on the tv..its not something a novice shouldd try to repair
Posted on Sep 02, 2008
Went to turn on tv and made high pitch noise like a jet engine. Made this noise a couple times and heard a fan kick on then power went off and red light came on.
Colorwheel eeds replacement most likley it could also be a fan but I would assume its the colorwheel especially if it was real highpitched sort of squealing sound. You can get the colorwheel and free tech assistance from the guys over at www.tvrepairworld.com
Nov 10, 2012 | Mitsubishi WD-65733 65" HDTV
5 year old goodmans tv suddenly went off, then intermittent high pitched squealing noises
Check the horizontal output section circuit. It sounds that the LOT {Line Output Transformer} has damaged.
May 11, 2012 | Televison & Video
Toshiba Regza bought 1/28/08 makes squealing noise
It's in the repair shop. I'll write back what the problem was and how much it cost to ship.
Oct 07, 2009 | Toshiba REGZA 47HL167 TV
High pitch noise from the projector and is not from the fans
it's the colorwheel. if you have an infocus x1a, it is a dlp projector and has a colorwheel and dmd chip instead of 3 lcd panels. the colorwheel spins to allow the lamp to stike. it should make a slight high-pitched squeal. if it's too loud, the motor is shot and needs replacing.
Aug 13, 2009 | InFocus X1A DLP Slide Projector
RCA Model f27650 High pitch squeal
the high pitch squeal indicates shorted component/s. the transformer goes hot co'z its being overloaded by the shorted component, it too could be the one creating the squeal!!
if you have experience with electronic troubleshooting, try to test some of the components particularly on the secondary part of the transformer.
Be careful and make sure the TV set is unplugged.
test for shorted diodes and transistors, if you're in doubt of your readings try to desoldering one leg of the diode then proceed with the testing/measuring. replace any of the bad components you find exactly with same part number or replacements with the same rating.
spend more time on it resoldering some other cold soldered components.
Oct 29, 2008 | RCA F32650 32" TV
RCA F36650 36" TV
is the squealing noise from the back of ur set , if so it is ur flyback transformer
May 29, 2008 | RCA F36650 36" TV
52 in RCA widescreen HDTV Monitor
high pitched squealing noise >> im thinking is the color wheel which will also give you the yellow color, don't know if that would also cause your screen to blank.
mcm carries RCA
Feb 01, 2008 | RCA HD52W59 HDTV Projection Television
My set has deveolped an intermittent high pitch squeal.
It always nice when the high-voltage circuit gives you fair warning of impending doom. Have the high-voltage (flyback) transformer replaced now before it fails catastrophically and wipes out other stuff with it. There are other things that could make noise too, same advice applies to them.
Hope ya fix it!
Jan 03, 2008 | Toshiba 36AF43 36" TV
High Pitched Noise on TV
THIS NOISE IS NORMAL. IS THE DEGAUSING COIL
Sep 16, 2007 | Televison & Video
RCA P52926 52" Rear Projection Television Logo
100 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
