Question about Hitachi 42HDS69 42 in. Plasma Television
42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
My 42HDS69 42 in. Hitachi plasma has several thin green vertical lines running down the middle of the screen. The lines appear after the tv has been on for awhile and disappear and reappear as I continue to view. Any idea how and if I can fix this?
  • 1 more comment
  • martin II Sep 13, 2008
    I have the same problem for this model the difference is the color of the lines are blue on my.
    Could you advice step by step how to re-set the cables I would like to try my self doing the repair.
    Thank you in advance...
  • ccarbis Oct 03, 2008
    I have a Hitachi 42HDTV79 that I purchased less than 2 years ago and about 3 week ago it developed a band of color down the right side, usually bright green, about 3" wide, right at the edge of the widescreen picture and the 'grey screen.' It has gotten worse. It occurs whether I am watching cable or a DVD. I called support at Hitachi and they were of no help, other than to say that I would have to have a service call, at my expense of course.
    Anybody else out there have this issue? The TV was bought new, delivered directly to my home and has never been moved. We have no children; it's just the two of us and it is on maybe 3-4 hours a day on average.
  • bg19895 Nov 23, 2008
    I have the same problem, my 42HDS69 42 has 3 bands(left, center, right) of lines, they would come on after the tv's been on for a while, but they would disappear if i turn it off for couple hours. i read other posts in this website which indicate the cause might be dry solder joins. anyone knows how to fix it?
  • 4,234 Answers
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Posted on Aug 29, 2008
I have a vertical line on my Samsung (PN50A510P3F) plasma TV. Would replacing the E and F buffers fix the issue?
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 11, 2017 | Samsung Televison & Video
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Vertical green line
? 4:45
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
Mar 10, 2008 - Posted on Mar 17, 2012.
I have a black vertical line in the middle of my
There are two boards at the bottom of the set connected to the panel. Follow the black line to the boards(it will be inline with one or the other) either that board is bad or the panel itself is bad . The boards do not meet exactly in the middle.
Oct 21, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
I have an orange line down the middle of my screen
i have a thin green line down my computer screen how do i get it off ?
Jun 29, 2009 | Hitachi P42H401 42 in. Plasma HDTV
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 42HDS69 Blue Vertical Lines
I think that you have dry solder joints on either the vertical scan board, the focus board, the line output stage, or the chroma panel. Hope this helps.
Sep 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
50" LG Plasma - Thin red vertical line in middle of screen
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
Feb 11, 2008 | LG 50PX4DR 50 in. Plasma TV
Hitachi 42HDS69 42 in. Plasma Television Logo
1,021 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
