I have a Lexmark 3400-3500 series printerit will only print sometimes only when I turn it off and then back on again. What have I done?
5 Suggested Answers
cheetahj25
  • 32 Answers
SOURCE: Lexmark 1200 series
How is the printer connected? USB, network, LDP cable?
Regards,
Chester
Posted on Jan 11, 2008
otacon
  • 1944 Answers
SOURCE: I can get drivers with
You can download them here from Lexmark.
http://support.lexmark.com/cgi-perl/selections.cgi?ccs=229:1:0:-1:0:0&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&&req=:::-1::
Type in the exact model of your printer and press GO.
Posted on Apr 07, 2008
SOURCE: Lexmark series 3400 printer/scanner installation disc
I cannot get my lexmark 3400 series to install. I already have a 1100 series install on my computer please help
Posted on Sep 16, 2008
SOURCE: install a printer
What a mess this was! I had followed all of the direction exact, and nothing worked right. I finally deleted the printers (all of them) and went through the add a printer wizard (find this by control panel, printers..) I had windows locate, then changed the file to USB as it tried to install on another location. FINALLY, after 3 days of trying... I can now print.
PLEASE NOTE: there was nothing in the resolution center to help me here, and I am not a computer geek, so it was definitely a "fun" install. This may resolve your issue.
Also, check the connection once it says it is installed by putting in a memory card and checking to see if you can view the photos on the card!
Posted on Dec 16, 2008
ginko
  • 19396 Answers
SOURCE: how to install lexmark 3500=4500 series printer without setup disk
To all Lexmark owners with the lost disk problem.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
If you instead want to purchase a new disk, bear in mind that Lexmark does not distribute replacement install disk for all models.
Contact Lexmark here, to see if the disk for your printer is available.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Posted on Apr 07, 2009
Lexmark Pro 715 prints garbage
Sorry, hit the wrong key... IF a different program prints okay, try again with the program that invoked the original issue.
Update windows and the offending program.
The piece that stumps people is the buffer. Print buffers sometimes do not purge easily, and you have to "bleed" the garbage out of the buffer, by turn off, and back on type of procedures.
Oct 05, 2012 | Lexmark Pro 715 All-in-One Printer
Lexmark wireless printer 1400 series prints blank pages
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark Z1400 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Jan 22, 2012 | Lexmark Z1420 Printer
My printed pages come out blank
Try to reseat your cartridges into the printer. Open the printer cover and remove the cartridges. Re-brick your printer by pulling out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds. When the printer turns on, reinsert both cartridges. Try to print again to verify that the problem is fixed.
Long period of non-usage can result to drying of ink and clogging in the print nozzles. Try to clean the cartridge nozzles using the Lexmark software on your computer. Go to Start menu > Programs > Lexmark X1200 Series folder > Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Try to print your document again to verify that the problem is fixed.
If this does not help, try to insert different known working cartridges or better yet brand new genuine Lexmark cartridges.
Nov 19, 2011 | Lexmark X1270 All-In-One InkJet Printer
My Lexmark x4850 has stopped prin?t the computer. What is wrongting . Sometimes it will print when I restar
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/lY7NTO. Select your operating system, download and execute the file. After the install process, try to print a document again to verify that the problem is fixed.
Oct 23, 2011 | Lexmark Wireless X4850 All-In-One Inkjet...
My laptop cannnot locate my lexmark x1100 series t
Make sure the Lexmark X1100 Printer Driver is installed on your computer.
If the printer driver was already installed and working with your computer, please follow steps below:
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
Aug 30, 2011 | Lexmark JetPrinter X1185 All-In-One InkJet
Hi I purchased an X4975 Lexmark Printer last October and just started getting a message that says it doesn't recognize my printer anymore and a pop up screen suggests I try many things ie: Unplug the...
Hello and Welcome to FixYa!
The recognition issue may arise due to 2 reasons, one the Cable is faulty, but this is ruled out as you have changed the cable now the second thing that I can think of is about the drivers, they get corrupt and you start getting these type of issues.
So, what you should do is first uninstall the driver from you PC, uninstall the support software if installed any. To do this you need to work under the device manager of your Operating system.
Once done, then download the fresh software from here (For all Windows 32-bit) and here (For all Windows 64-bit)
Install the software then plug in the printer cable, it will be detected and installed again, hopefully this will resolve the issue.
Note: To uninstall the printer, the shortest method is Click Start > Programs > Lexmark xxxx series > Uninstall Lexmark xxxx series.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
Aug 12, 2010 | Lexmark X4975 Wireless Color Multifunction...
My Lexmark x5495 will not print. I get the message enable bidirectional communication. I am running XP operating system. What is the solution?
Go to Control Panel > Printers and Faxes > right click on the Lexmark 5400 Series print object > Properties > Lexmark 5400 Series Properties window pops up, click on Ports tab > place a check mark in Enable bidirectional support by clicking in the box beside it. Hit Apply and click Ok to save the settings. Try to print. If problem persists, disconnect the printer usb cable from computer, uninstall the software completely by clicking on Windows logo Start menu > All Programs > Lexmark 5400 Series folder > Tools > Uninstall. Restart pc. To reinstalI, I recommend you use the software you can download from the Lexmark website. Just click on this link: http://bit.ly/cgn74X. Download and install the software. Follow the instructions. Try to print again. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 04, 2010 | Lexmark X5495 All-in-One &USB...
How do you save margins and save information to print out later on IBM wheelwriter 35 by LexMark?
First thing is to be sure the batteries are good and the holder is clean. If there not you will get lo batt on the display and everything you put in will clear when you turn it off.
To save something Press store and an address 01-99 type info when done press store again info. is stored. to print press play and the address. To delete use del and the address.
DickyO
Nov 19, 2009 | Lexmark Wheelwriter 35 Series II...
No power on my Lexmark X8350
That's the same printer I have.
First, make sure the blue "copy" button is lit. Printing is done there.
Then, go to the circle with the checkmark in it and hit the menu, and arrow down to copy papy size and make sure it says "letter".
Click start on your computer, then click control panel, then printers, and make sure Lexmark 8300 series is the default printer and has a green checkmark in a circle.
If all these things are right, you should be able to print a test page and the computer should work fine.
If any one of them are wrong they must be corrected. If you need help on any one of those please write back.
Sirwriter
May 14, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
166 people viewed this question
k24674
