Question about Nikon Cameras
I have a nikon d40 and just purchased a 52mm lense reverse ring for it but when i attatch it to camera it keeps saying lense not attatched. what am i doing wrong?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
You need to switch to Manual (M) mode. You won't be able to meter through the lens. Nor will you be able to autofocus.
Posted on Dec 30, 2009
I found a Quantaray 55-52 mm step down ring (Manufacture # 241664614) on Wolf Camera's website that I am interested in purchasing, but want to make sure it would work for me. I have some close up...
No. The 55-52mm step-down ring will let you attach a 52mm attachment onto a lens with a 55mm thread. You want a 52-55mm step-up ring.
Mar 21, 2011 | Cameras
Canon on nikon
The Canon lenses are FD mount which means that you will need to get an adaptor to convert the FD mount to fit the F mount on the Nikon. An example of the mount can be seen here:
http://www.rugift.com/photocameras/canon-fd-nikon-adapter.htm
As for the speedlights the hotshoe mount will accept them on your Nikon, put them on with fresh batteries and try them out.
Jan 13, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
What size filter do I need for a Nikon D40 and what size filter do need for aSigma 70-300mm Thank you
Hi!
Usually the diameter is written on the front of the lens. You can use lens with different diameters on this camera, it really depends on the lens, but it will most likely be a 58mm.
Tom
Oct 09, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Is the quantaray 55mm lens hood compatible with a d40
yes and no. no because the lens diameter of the 18-55 is 52mm and yes if you use a stepping ring that you screw on the 18-55 to accommodate the 55mm hood.
Feb 22, 2009 | Quantaray Cameras
Nikon f3
First thing to check....how old is your battery? First replace the battery, then go from there.
Jan 05, 2009 | Nikon F3/T 35mm SLR Camera
A/F PROBLEM
The D40 (& D40X & D60) will not autofocus with the G series lenses. The three cameras above require a newer DX series of lenses for the AF to work.
Jan 04, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 I bought a set of macro lenses that said they were compatible for the d40 but i cannot figure out how to fit them. They are 52mm lenses - should i have bought an adaptor or something? where...
Macro lenses are mounted to your camera body in place of the lens you currently have mounted on the camera. If you bought the camera with the lens already mounted you may not have realized that the camera and lens are 2 separate objects. To remove your lens see page 8 in your user manual for instructions and an illustration. If you don't have your user manual handy, you can download a PDF file from NikonUSA Here.
If what you bought are macro rings, they go on the camera, then your regular lens mounts onto the ring. You can use one or more of the rings between the lens and camera to produce different macro settings.
If what you bought are macro filters, they screw on to the front of your lens. If you have a UV filter on your lens you need to remove that before you attach another filter.
Dec 22, 2008 | Nikon Cameras
Nikkor lense
You need AF-S or AF-I Lenses. These have the autofocus motor built in to the lense. The D40 and D40x does not have an autofocus motor in the camera body itself, while the D80, D300, D3 Etc to have the motor in the camera. You can use most old lenses on your D40x, but you will have to focus them manually.
See Ken Rockwells page for a lot of D40 / D40x info
http://www.kenrockwell.com/nikon/d40.htm
Jun 03, 2008 | Nikon D40x Digital Camera
Really Dark Viewfinder
That would explain the darkness if the lens is stopped down. It would seem the aperture control is faulty on the camera body. Normally, the aperture remains open until you take the picture. It is only closed down while the shutter is open.
Feb 11, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Pictures not clear - grainy
Yes, that is exactly how the camera works. You may want to check your ASA/ISO settings as well as image quality and size.
Jan 03, 2008 | Cameras
Cameras Logo
50 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
