Am having trouble installing a new game on my computer. 2 For You game pack with Mahjong and Domino. Says everything installed but when I try to run it, it says directx error. The soft ware says it is compatabile with my microsoftME
  • 95 Answers
You need to have at least xp for that to run
Posted on Aug 29, 2008
Tip
Solve Installer issues
Many have been having an issue when installing the SIMS2 PETS expansion pack (EP) and Glamour Life EP.  The best way to resolve this is:
1. BACK UP your game folder first (usually: users + your folder + Documents + EA Games).  You want to back up the EA folder.
2. Download (do not install yet) the SIMS2 COMBO UPDATE patch at http://www.macupdate.com/info.php/id/18988
3. If you have already had the issue (which you probably did, otherwise you would not be reading this), delete your SIMS 2 folder from the HD and the EA games folder from the location mentioned above.  Yes, I know, it is painful but you saved what you needed, so stay with me.
4. Reinstall your SIMS 2 game (the base game).  Run it and make sure it works fine.  This will create a new EA Games folder where the old one was.
5. Now install the PETS expansion pack. If you want, start it to make sure it works fine.  All should be OK.
6. Now run the Combo pack. It will scan your HD to find the SIMS folder and what you need.  A window will open allowing you to select the install. Do it and install it.  If you click the arrow next to the installer options you will see there are patches for all the EP's, but they will be grayed except for the one you need.
7. Install your next expansion pack and run the combo patch installer again, now selecting the appropriate pack to patch.  Again, all others will be grayed except for the one you need.
8. Keep doing this with every expansion you install thereafter.  What the patch does is it updates each expansion pack to make sure it works by solving issues that came up after the release and will update everything up to December 2007.
9. After you are done, copy your original saved EA Games folder back into the location you had it.  You will need to hit 'replace' as SIMS will have installed a new EA Games folder in its place.  It is OK, this is all your games saved data.
10. Start SIMS2 and go look for your saved game!
on Jan 04, 2009 | Aspyr SIMS 2 PETS for Mac, Sun
Cannot install a game
I assume you are running Vista so try running the setup.exe or install.msi or whatever as administrator. if that doesn't work upgrade the VGA card. yours is integrated which is not good for gaming. puts stress on cpu and steals ram
Aug 25, 2009 | Microsoft Zoo Tycoon 2 for Windows
Trying to install an older Hoyle Solitaire and Mahjong game
Once you insert the CD, go to Start -> My Computer, and Double Click on the Drive that has the Hoyle Picture. This will either start the Installer/Auto-run window, or it will open a series of files. Double click on Setup.exe if it does not autorun.
Jun 17, 2009 | Sierra Online, Inc. Hoyle Classic Games 2...
Windows Microsoft games
go to control panel-> add remove programs-> add remove windows components-make sure to put check mark on accesories and utilies then double click it then look for games put a check mark again then hit next
Nov 17, 2008 | Microsoft Windows Vista Home Premium with...
Need help with ultimate Mahjongg. wont run?
Technical Questions Q. Ultimate Mahjong refuses the run at all
A. Make sure you have DirectX 9 installed, this is a games library created by Microsoft, and can be downloaded freely from here. If it still does not work then you can contact our technical support at support@inertiasoftware.com.
Q. Ultimate Mahjong runs slowly on my computer how can I make it faster?
A. Ultimate Mahjong probably runs slowly because of your graphics card, make sure you have the latest drivers for it installed and that you have DirectX 9. Trying changing between 2D and 3D modes, and see which runs the fastest. Finally, many people find that Ultimate Mahjong runs faster in a 16 bit color mode, so try changing your display settings.
Q. Ultimate Mahjong will not run and keeps telling me I have an incompatible display, what should I do?
A. You should try changing your display settings, some video cards cannot run Ultimate Mahjong in certain color modes. Try setting your display properties to a 16 bit color mode, this usually solves the problem.
http://www.ultimate-mahjong.com/faq.php
Oct 31, 2008 | Computers & Internet
We have a windows vista computer and a game which we havent installed yet because we were wondering if it might damage the game or computer because on the minimum requirments it says that the computer must...
the worst that could happen is that the computer may not run the program. try installing the game, your cd (assuming that's the source of the setup files for the game) should not be affected.
after you install the program try to run it as usual by double clicking the icon to run the program if it doesn't run as expected try this.
1. right click the icon you use to run the game.
2. select properties
3. select the compatibility tab and select an appropiate mode. (ex. windows xp service pack 2)
not completely sure but you may also want to try to run the installation/setup program by changing the compatibility mode so you may be able to trick the program into believing the app/game is being installed on a windows xp service pack 2 system increasing your chances to have the installation running properly.
Sep 27, 2008 | Computers & Internet
Mahjong Quest III
Try first to press CTRL+ALT+DEL on your keyvoard then task manager will open check under process if you see 2 majong running if yes, right click the other one thenend task...
IF still the same go to cotrol panel then look for Majong then remove it from there , then go ahead with the new installation...
Hope that helps...........
Aug 22, 2008 | Video Game Consoles & Games
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
