Question about GE Refrigerators
Temperature too low - GE Refrigerators
  • andreeg2104 Sep 02, 2008
    Thank you very much1 I will see all you say.
    Have a good day!
    Andrée ü
  • GE Master
  • 19,396 Answers
There can be several reasons why the fridge is not cooling.
see the following notes from repairclinic:
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on Aug 29, 2008
Where is the engine coolant temperature sensor low input located on a kia 2007 spectra
Not low input sensor...P0117 KIA - Engine Coolant Temperature Sensor 1 Circuit Low Input
Possible causes
Low engine coolant level
Faulty Engine Coolant Temperature (ECT) sensor
Faulty engine coolant thermostat
Engine Coolant Temperature (ECT) sensor harness is open or shorted
Engine Coolant Temperature (ECT) sensor circuit poor electrical connection
Just replace coolant temperature sending unit....
Nov 14, 2017 | Kia Cars & Trucks
Tip
Detroit Diesel Fault Codes
Code Description DDEC V Circuit
11 P 187 4 Chain PTO. Short circuit in the power
11 P 187 7 control system PTO wrong answers
12 P 187 3 Chain PTO. Short circuit in the ground
13 P 111 4-level circuit antifreeze. Short circuit in the ground
13 P 111 6 second-level circuit antifreeze. Short circuit in the ground
14 P 52 3 circuit coolant temperature intercooler. Short circuit in the power
14 P 110 3 circuit temperature antifreeze. Short circuit in the power
14 P 175 3 Chain oil temperature. Short circuit in the power
15 P 52 4 circuit coolant temperature intercooler. Short circuit in the ground
15 P 110 4 circuit temperature antifreeze. Short circuit in the ground
15 P 175 4 Chain oil temperature. Short circuit in the ground
16 P 111 3-level circuit antifreeze. Short circuit in the power
16 P 111 5 second circuit level antifreeze. Short circuit in the power
17 P 51 3 Throttle position circuit failed high
17 P 72 3 Bypass position circuit failed high
17 P 3 354 Relative humidity sensor circuit failed high
18 P 51 4 Throttle position circuit failed low
18 P 72 4 Bypass position circuit failed low
18 P 354 4 Relative humidity sensor circuit failed low
21 P 91 3 TPS circuit failed high
22 P 91 4 TPS circuit failed low
23 s 65 3 Oxygen content circuit failed high
23 P 174 3 Chain fuel temperature. Short circuit in the power
24 s 65 4 Oxygen content circuit failed low
24 p 174 4 Chain fuel temperature. Short circuit in the ground
25 no codes
26 s 25 November Aux. shutdown # 1 active
26 S 61 11 Aux. shutdown # 2 active (Incorrect SID. subject to change)
27, p 105 3 circuit temperature in the reservoir. Short circuit in the power
27 p 171 3 Ambient air temp circuit failed high
27 p 172 3 Air temp, circuit failed high
28, p 105 to 4 Chain manifold temperature. Short circuit in the ground
28 p 171 4 Ambient air temp circuit failed low
28 p 172 4 Air temp, circuit failed low
29 p 404 4 TCO temperature circuit failed low
29 p 351 4 TCI Temperature circuit failed low
31 S 51 3 Aux. Output # 3 open circuit (high side) S3
31 S 51 4 Aux. Output # 3 short to ground (high side) S3
31 S 51 7 Aux. Output # 3 mech. system fail S3
31 s 52 3 Aux. Output # 4 open circuit (high side) T3
31 s 52 4 Aux. Output # 4 short to ground (high side) T3
31 s 52 7 Aux. Output # 4 mech. system fail T3
32 S 238 3 SEL short to battery B1
32 S 238 4 SEL open circuit B1
32 s 239 3 CEL short to battery B2
32 s 239 4 CEL open circuit B2
33 p 102 3 Boost pressure circuit failed high
34 p 102 4 Boost pressure circuit failed low
35 p 19 March Ext range oil pressure circuit failed high
35 p 100 3 Chain oil pressure. Short circuit in the power
36 P 19 April Ext range oil pressure circuit failed low
36 P 100 4 Chain oil pressure. Short circuit in the ground
37 P 18 March Ext range fuel pressure circuit failed high
37 P 94 3 Chain fuel pressure. Short circuit in the power
37 P 95 3 Fuel Filter Restriction circuit failed high
38 P 18 April Ext range fuel pressure circuit failed low
38 P 94 4 Chain fuel pressure. Short circuit in the ground
38 P 95 4 Fuel Filter Restriction circuit failed low
39 S 146 2 Mechanical error EGR valve
39 S 146 12 Mechanical error EGR valve
39 S 146 return valve 7 does not meet the exhaust
39 S 147 2 turbocharger control mechanism does not respond
39 s 147 12 turbocharger control mechanism does not respond
39 s 14 147 current returns exhaust gases enough
39 S 147 11 turbocharger control mechanism does not respond
39 S 147 7 turbocharger control mechanism does not respond
41 S 21 0 Too many SRS (missing TRS)
42 S 21 January Too few SRS (missing SRS)
43 p 111 1 Low coolant level
44 p 52 0 ntercooler coolant temp, high
44 p 105 0 temperature in the reservoir above the norm
44 p 110 0 antifreeze temperature above normal
44 p 172 0 Air inlet temp, high
44 p 175 0 Oil temperature above normal
45 p 19 January Ext range oil pressure low
45 p 100 1 Oil pressure below normal
46 p 168 1 Low voltage batteries
46 S 214 1 RTC Backup Battery Voltage Low
46 S 232 1 Sensor Supply Voltage Low A3 & W1
P 0 47 18 Ext range fuel pressure high
P 47 94 0 The fuel pressure above normal
47 p 0 102 Turbo boost press high
47 p 106 0 Air inlet pressure high or TCBV diff press high
47 p 164 0 Injection control pressure high
48 p 18 January Ext range fuel pressure low
48 p 94 1 fuel pressure below normal
48 p 106 1 Air inlet pressure low
48 p 164 1 Injection control pressure low
48 p 351 1 TCI Temperature below range
48 p 404 1 TCO Temperature below range
48 p 411 1 EGR Delta pressure low
48 p 412 1 EGR Temperature low
49 p 351 0 TCI Temperature above range
49 p 404 0 TCO Temperature above range
More Fault Codes here Detroit Disel DTC
on Dec 20, 2016 | Cars & Trucks
Tip
Komatsu Fault Codes
E02 PC-the EPC system;
E03, Swing parking brake system;
E10, the engine controller power failure, the engine control drive system circuit malfunction (this engine stall;
E11, the engine control system failure (decrease of output power, in order to protect the engine);
E14, the feedback system abnormalities;
E15, engine sensors (temperature, fuel pressure, oil pressure) fault;
EOE, a network failure.
The fault code: the 989L00 the engine controller lock warning (mode 1).
989M00, the engine controller to lock warning (mode 2).
989N00, the engine controller to lock warning (mode 3).
AA10NX air filter clogging.
AB00KE charging voltage is too low.
B @ BAZG, low oil pressure.
B @ BAZK, the oil level is too low.
B @ BCNS, engine coolant overheating.
The @ B BCZK the coolant level is too low.
B @ the HANS, the hydraulic oil from overheating.
CA111, the engine controller internal fault.
CA115, the engine speed sensor and backup speed sensor failure.
CA122, the intake air pressure sensor feedback voltage is too high failure.
CA123, the intake air pressure sensor feedback voltage is too low failure.
CA131, the throttle plate sensor feedback voltage failure.
CA132 throttle plate sensor feedback voltage and low failure.
CA144, high coolant temperature sensor feedback voltage fault 145, the coolant temperature sensor feedback voltage is too low failure;
CA153, intake air temperature sensor feedback voltage is too high failure;
CA154, intake air temperature sensor feedback voltage is too low failure;
CA155, the intake air temperature is too high (over limit);
CA187, sensor power supply voltage is too high failure;
More Fault Codes HERE http://truckmanual.weebly.com/komatsu-fault-codes.html
No DTC definition code found p1114
Hi there:
DTC P1114 - Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage/IAT - B Circuit Low Input
The engine coolant temperature sensor is a thermistor (a resistor which changes value based on temperature) mounted in the engine coolant passage. Low coolant temperature produces a high resistance 100,000 ohms at -40 oC (-40 oF) while high temperature causes low resistance 70 ohms at 130 oC (266 oF).
OPERATION
The VCM supplies a 5 volt signal to the engine coolant temperature sensor through a resistor in the VCM and measures the voltage. The voltage will be high when the engine is cold. The voltage will be low when the engine is hot. By measuring the voltage, the VCM calculates the engine coolant temperature. Engine coolant temperature affects most systems the VCM controls.
The scan tool displays engine coolant temperature in degrees. After engine start-up, the temperature should rise steadily to about 9O oC (194 oF) then stabilize when thermostat opens. If the engine has not been run for several hours (overnight), the engine coolant temperature and intake air temperature displays should be close to each other. When the VCM detects a malfunction in the Engine Coolant Temperature (ECT) sensor circuit, the following Diagnostic Trouble Code (DTC) s will set.
Hope this helps.
Feb 15, 2013 | 2000 Audi A6
Saber que es codigo 15 codigo 20 y codigo 25 isuzu trooper mod 1988 gasolina 2.600 cc. inyectado
Revise estos codigos correspondientes al sistema OBD I...
13 Open Oxygen Sensor Circuit
14 Coolant Temperature Sensor (High Temp Indicated)
15 Coolant Temperature Sensor (Low Temp Indicated)
21 Throttle Position Sensor (Signal Voltage High)
22 Throttle Position Sensor (Signal Voltage Low)
23 Manifold Air Temperature (MAT) Low Temp Indicated
24 Vehicle Speed Sensor (VSS) Circuit
25 Manifold Air Temperature (MAT) High Temp Indicated
32 EGR system fault
33 MAP sensor circuit (signal voltage high, low vacuum)
34 MAP sensor circuit (signal voltage low, high vacuum)
44 Oxygen Sensor Circuit (Lean Exhaust Indicated)
45 Oxygen Sensor Circuit (Rich Exhaust Indicated)
51 PROM error (faulty or incorrect MEM-CAL).
Suerte.
Apr 18, 2011 | 1987 Isuzu Trooper
Hur byter jag växellädsolja på
160....O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161....O2 Sensor Heater Circuit (Bank 2 Sensor 2)
P0162....O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163....O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164....O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165....O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166....O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167....O2 Sensor Heater Circuit (Bank 2 Sensor 3)
P0168....Fuel Temperature Too High
P0169....Incorrect Fuel Composition
P0170....Fuel Trim (Bank 1)
P0171....System too Lean (Bank 1)
P0172....System too Rich (Bank 1)
P0173....Fuel Trim Malfunction (Bank 2)
P0174....System too Lean (Bank 2)
P0175....System too Rich (Bank 2)
P0176....Fuel Composition Sensor Circuit
P0177....Fuel Composition Sensor Circuit Range/Performance
P0178....Fuel Composition Sensor Circuit Low Input
P0179....Fuel Composition Sensor Circuit High Input
P0180....Fuel Temperature Sensor A Circuit
P0181....Fuel Temperature Sensor A Circuit Range/Performance
P0182....Fuel Temperature Sensor A Circuit Low Input
P0183....Fuel Temperature Sensor A Circuit High Input
P0184....Fuel Temperature Sensor A Circuit Intermittent
P0185....Fuel Temperature Sensor B Circuit
P0186....Fuel Temperature Sensor B Circuit Range/Performance
P0187....Fuel Temperature Sensor B Circuit Low Input
P0188....Fuel Temperature Sensor B Circuit High Input
P0189....Fuel Temperature Sensor B Circuit Intermittent
P0190....Fuel Rail Pressure Sensor Circuit
P0191....Fuel Rail Pressure Sensor Circuit Range/Performance
P0192....Fuel Rail Pressure Sensor Circuit Low In put
P0193....Fuel Rail Pressure Sensor Circuit High Input
P0194....Fuel Rail Pressure Sensor Circuit Intermittent
P0195....Engine Oil Temperature Sensor
P0196....Engine Oil Temperature Sensor Range/Performance
Nov 20, 2010 | 2004 Volvo S80
Our new model #00592W1 includes a low temperature adaptor that plugs into the wireless sensor. Is it necessary to use this?
I found this on another Acu-Rite manual: In case temperatures fall below -4F, bring the wireless sensor indoors and use the included low temperature adaptor by routing the wire out through a soft seal opening such as a window or door. (That way the Wireless sensor is protected indoors in extreme temperatures. Low temp adaptor is used outside to observe temperature.)
Dec 12, 2009 | Acu-Rite Audio Players & Recorders
HI, Good day, I have an LG LT0810CR wall air conditionning. When I set the temperature to 17c the compressor stop working after 10 minutes. It wasent doing that before. At this temperature setting at 17c...
Does it run longer at a higher temperature say 20° or 21°and what's the outdoor temperature?
Try to run system at a higher temperature, to see if you still have the same problem, if you don't then you may have a low pressure switch opening and shutting the compressor down. If this is the case the outdoor temperature may be too low, dirty filter or indoor coil, fan speed too low or low on refrigerant.
If not then it could be run capacitor, loose wire or thermostat.
Aug 24, 2009 | LG Heating & Cooling
Refrigerators Logo
135 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
