Question about Hitachi 53UDX10B 53" Rear Projection Television
50UX18B Hitachi Projection TV
Picture jumps around. Eventually afte rit get farily warm the picture flutters or scrolls. Can anything be repaired?
  • zbrown23 Sep 02, 2008
    My Hitachi Projection tv jumps a lot at first and then after a while it gets better but will only do it rarely when it is on...What can i do?
TV won't come on only clicks when pressing on button
Posted on May 26, 2009
  • 927 Answers
Good Day, monarchdr272;
Sounds like you may have a bad comb filter. Yes things can be repaired. Good Luck, big IRISH.
Posted on Sep 01, 2008
SOURCE:
My tv when it turns on there is no color and after a while the colors appears, also the picture is distorded, any sugestions?
Its a older set and I have fixed and even owned one---bad solder connections and or convergence problems---can you describe better what it looks like when cold?
Nov 04, 2012 | Televison & Video
Picture flutters
If this is a projection TV and it shrinks and expands its a common issue with certain Philips TV sets. Sites like www.TvRepairKits.com have the kits to fix this.
Mar 30, 2012 | Televison & Video
53SDX20B Projector TV - No Picture
It was condesnation from moving the TV from the cold outdoors to the warm indoors. I let it warm up for about 2 hours and then it was fine.
Jan 11, 2010 | Hitachi Televison & Video
Jumpy picture
ck for dry solder joints if you take rear cover off and just lightly tap on convergence ic heat sink if the tv jumps then you have to remove the board and resolder the joints. also if you have a magnifying glass ck all solder joints on board when it is out
Oct 05, 2008 | Hitachi 50UX58B 50" Rear Projection...
Problems with my 50 inch hitachi ultravision projection screen tv
check the solder around the area of the vertical IC. solder is either cracked or else cold. Cold solder appears as dull. Resolder anything that isnt shiny.
May 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Picture flutter
As I indicated (I think) in another string, this sounds more like bad connections than anything else. Try resoldering the pins on the convergence ICs. Let me know if that does not resolve the problem.
Dan
May 13, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Problem with tv
does it do this on video inputs? if not then you have a possible bad tuner.
Apr 09, 2008 | Hitachi 51F500 51" Rear Projection...
Hitachi ultravision
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Dec 20, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Picture Problems with Hitachi 53" Projection TV
most tv shop's will replace convergence ic's,which your tv needs.Thepart number is stk392-180 very common You need 2 plus poss resistors,3 bucks apiece
Mar 20, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Fluttering
I've worked on a few of these sets and have found C2P08 to cause something like rolling bars in the picture and have found C2P05 to cause lines jumping in the picture.
Feb 10, 2007 | Mitsubishi VS-60607 TV
Hitachi 53UDX10B 53" Rear Projection Television Logo
246 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
