Question about Hitachi Computers & Internet
I have purchased a Maxtor One touch 4 Storage Unit and have it conected to my desktop. What is the easiest way to connect it to my wifes laptop and store her photos etc. Both operate on Windows XP Home 72YO New Nerd
  • 95 Answers
Plug it into a USB port on the laptop
Posted on Aug 29, 2008
I have a Maxtor 500GB. It was working ok but today the green light is blinking and the external memory is not conected with the computer. I have tried using different USB ports, conecting an desconecting...
you could disassemble the case and remove the drive. it could then be connect via an external controller such as(http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2477926&CatId=3770) and test if the drive itself is good in which case it is the controller in the case.
cheapest way I can think of to diagnose these external enclosures
GL
Don't forget to vote if I have help you,
TY
Jammer
May 25, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
Our MAXTOR Onetouch 4 mini is not recognized by computer. Can your software recover the data?
could be several issues to cause this fault, make sure your usb port is usb 2.0, replace the usb cable, take the unit apart and look for loose conections, try the drive in another caddy, or try another drive in the maxtor caddy. You will probably be able to remove the drive from the caddy and connect it into your computer if you have a tower and the correct connections.
May 02, 2011 | Maxtor OneTouch 4 Mini 120GB External USB...
I plugged in my maxtor 500gb ONE TOUCH, to my Mac, i used to work now that i plug it in, i cant heard the HDD make a noise like it used to, the power light is just blinking on the maxtor. Anything i can...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Nov 11, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
Oct 15, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Problam in connecting maxtor one touch 4 mini dosn't ditected
is this a USB type connection, if so try rebooting. Usually though it should detect it automatically with Vista or XP. Make sure the unit is also fully powered on.
Apr 16, 2009 | ASUS Computers & Internet
I backed up my old Dell laptop last year. I bought a new Dell laptop. I want to access the backup on my Maxtor and cannot do it. I want to load it onto my new laptop. How do I do this? I want to back up...
Very Simple. Just connect the Maxtor External Hard drive to your new laptop. Open Windows Explorer and you will see the Maxtor appearing as a Drive. Access the files from the explorer.
My advice is that create a new folder on the maxtor and then do a backup of your new laptop on to this new folder.
DO the same for your office PC.
Apr 03, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
User manual for Maxtor One Touch 180gb
The item is an external HDD, you can use to store files on it.
You can download drivers, manual etc from Maxtors supporter site bellow.
http://www.seagate.com/www/en-us/support/downloads/
Youst select the model of your Maxtor, there are 4 diferent in that family. You can see on your item what model it is.
Download the drivers, install them, connect the item..and VIOLA, you will have 150GB external storage!
Good luck to you
If you find my answer helpfull, dont forget to vote!
Dec 11, 2008 | Computers & Internet
Maxtor one touch 4 mini 250 GB
try plugging it in and then clicking on it in the computer section
right click on the properties tab and then click on compatibility
click in the tick box and highlight win xp
apply and ok
do not throw ii in the the bin as it can be used as a hard drive in any computer or being mini , in any laptop unit
Mar 22, 2017 | Maxtor Hard Drive
Maxtor 3200 Some files not accessible when I switch computers
Unreliable drive. Remove and hit with a sledgehammer. Trust me. Do it now before u lose all your data. The 3200's are nothing but trouble. Did u know they use seagate hard drives?
Jan 01, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Computers & Internet Logo
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
