Question about Plantronics - Bluetooth Headset Plus Base & Headset
Dan8888 seeking help
I have tried making sure battery is full charged. I have called phone company and turned bluetooth on and off and sought to pair the devices and had the phone search for device. I have made sure blue light is on and flashing
  • 2 more comments
  • dan8888 Aug 29, 2008
    I have nothing in the pair section nothing except bluetooth turned on and the replacement phone is the same phone i had
    I have tried battery withdrawel and reboot. Did not work for me. So far nothing seems to work Does the 220 have a sequence to turn on or fomulate a driver device. Like two or three clicks. The blue light blinks but is not consistent or steady. When I place the earpeace in my ear and push the volume button, I hear beeping sounds. The device is fully charged and so is phone.
    that did it and it is working. Thanks
  • Anonymous Mar 22, 2014
    I'm not sure if its charged because I am not hearing prompts or anything for that matter and can't get it to pair or even show up on my phone
  • 1,586 Answers
Strange. I'm wondering if there's a difference in the software between your original phone and the one you have now, something like that which is causing the problem. Your new phone I'm assuming is the same type as the old one right?
Have you made sure that the phone you have now doesn't already have a bluetooth device in its pairing memory? I know on my razr I could only have one device assigned to the phone, and I had to delete that one before I could pair a new one up.
Posted on Aug 29, 2008
  • 3 more comments
  • Jeremy Dellow
    Jeremy Dellow Aug 29, 2008
    Try removing the battery from the phone (and from the bluetooth device, if it's not just a plug-in rechargeable device), let it sit a few minutes, and then reinstall it. This can sometimes serve as a soft-reboot for a phone, and may help you.
  • Jeremy Dellow
    What type of phone do you have?
  • Jeremy Dellow
    Nevermind, sorry - Nokia 6555b. I missed that earlier.
  • Jeremy Dellow
    In order to get the headset into pairing mode, try this: Begin with the headset turned
    off. Press and hold down the silver call control button in for 6-10
    seconds. The light will flash blue first. Continue to hold the button
    down then release the button when the indicator light starts flashing
    red then blue. the passkey is "0000" if you're asked for it (this is by default).
  • Jeremy Dellow
    Great - my H550 device was similar - I had to hold the button forever to get it ready to accept the pairing. Glad it worked for you:)
Why is my USB Bluetooth Adapter not showing up under settings?
Make sure the headphones are in the searchable mode or try searching from the headphones instead of the PC.
Oct 17, 2016 | Insignia Bluetooth Wireless Headphones...
After I complet a call I still get some static in the headset. right now its been going on for 10 minutes. its at a very low volume but annoying
Making sure the headset is fully charged, you'll probably want to try and pair the headset to your phone again. Make sure that any bluetooth devices are removed from the phone. Removing the battery (if possible) for about 15 seconds helps to reset the phone. Follow the pairing instructions on the link below for the Plantronics Voyager Pro.
Plantronics Voyager Pro Pairing Instructions
Good luck from Headsets Direct!
Sep 05, 2011 | Plantronics Voyager PRO Bluetooth Headset
Having issues syncing my Uniden BT112 Bluetooth to my BlackBerry Bold. I used this Bluetooth with another telephone and don't have any of the old packaging. I don't have a pin number. Help!
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Uniden BT-108 Bluetooth Headset
I can't connect with my phone
Please follow the detailed instructions below for the proper pairing of the headset with your phone.
CHARGING
Before using, you must first charge your headset.
20 minutes = minimum charge
2 hours = full charge
Light is solid red when battery is charging.
NOTE For the best user experience, keep your headset fully charged.
CAUTION Do not use headset while charging and do not connect the charger while the headset is in use.
POWERING
Press the control button for 2 seconds to power on. Press the control button for 3 seconds to power off.
PAIRING
Step One:
Prepare Phone- Turn on Bluetooth For most phones, go to Settings/Tools menu and select Bluetooth or Connectivity and select "On."
Step Two:
Prepare Headset- Pairing Mode Begin with headset turned off. Turn headset on (hold call control button for four seconds until the light flashes blue) and it will automatically go into pairing mode, flashing red and blue.
Step Three:
Pairing- Add Headset to Phone For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device, then Select "220Plantronics." For passkey enter
0000. Headset will flash blue when paired successfully. It is now powered on and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with another device, follow pairing instructions below.
If headset has been previously paired with another device, please follow these instructions for pairing a second time. Be sure the headset is fully charged.
1. Press and hold down the call control button for 8 seconds until the headset status
indicator begins to flash blue then red.The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing,use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
NOTE: The headset can pair to multiple Bluetooth devices, but will only connect to one device at a time. The headset will automatically connect to the last device to which it was connected.
Please don't forget to rate me if satisfied.Thanks for choosing Fixya.Good Luck.
Jun 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
MY VOYAGER PRO .. LIGHT FLASHES BLUE RED BLUE RED ... CAN'T TURN OFF, CAN'T RESET, CAN'T RE PARE
If you manually turn the headset off, make sure that it is by itself, no other phones in the area, no WiFi hotspots. Once this is done make sure that there is not a bluetooth already installed on the phone itself, if there is, delete it. Make sure that the headset has a full charge. Try the pairing again. If this still won't work, you can try Plantronics Tech service line 800-544-4660.
Here are two links that may be helpful:
Plantronics Voyager Plus User's Guide
Plantronics Voyager Plus Pairing Instructions
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
When I make a call using the bluetooth, I can hear who I am talking to through the bluetooth, but they can't hear me?????
Make sure both devices are fully charged. Turn off your phone and disconnect the battery for about 30 seconds (this helps to reset the phone). Make sure there are no other bluetooth devices interfering with the connection. Turn off your headset and carefully follow the pairing instructions on the link below for the Plantronics Discovery 925.
Plantronics Discovery 925 User's Guide
May 12, 2011 | Plantronics Discovery 925 Bluetooth...
Just received a brand new, in original packaging, ...
Your headset should enter the pairing mode just by opening its boom. If it has never been paired before, it will be in pairing mode right away. Otherwise, make sure that the bluetooth radio of all devices preivously paired with it, are turned off (or, at least, out of reach). As soon as its boom is opened, and it can't find any paired device active, it will enter the pairing mode. Once your headset is in pairing mode, make the bluetooth application of your phone search for new devices. After a while the H700 should appear on the phone screen. Select it and make the application connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). The pairing process should be done only one. All subsequent connections between any two previously paired devices should be done automatically, provided that their bluetooth radios are on and with each other's reach.
Hope you are able to sort your problems out.
Regards, Carlos
May 19, 2010 | Motorola Mobility H700 Wireless Headset
My wireless bluetooth headset is connecting failed but code is correct then i will stating the pairing and is it a connecting to failed.. Plzzz help,,,,
please try to powercycle your phone... turn it off and remove the battery.
make sure your headset is fully charged... the indicator light should be in steady blue before pairing it
Feb 09, 2010 | Nokia Bluetooth Headset Headset
H700 bluetooth help
Depending on the phone... try and remove the current bluetooth device. Close the headset. Go to the phone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized. After this, it will ask for a passcode.
The purple light will not stay lit as long as the mic boom is closed.
Also make sure the battery on theheadset is charged before doing this.
The passkey will be 0000, four zeros.
Aug 05, 2009 | Motorola Mobility H700 Wireless Headset
Jabra bluetooth headset
how do I set up the phone to discover jabra vbt185z?
Dec 29, 2007 | Jabra BT350 Bluetooth Headset Headset
Plantronics - Bluetooth Headset Plus Base & Headset Logo
43 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
