Laptop viewing on TV
My Dell D610 will not hold the 2nd monitor after I switch it on. It asks if I want to activate the 2nd monitor, I say yes, it turns on, it says to reboot, I do, I go back to the set up monitor area and the second monitor is gray (off) again. I still cannot see my laptop screen on my TV monitor.
  • dmcclain Aug 29, 2008
    How would I do that? I did go into the screen set-up and turn on the second screen. Unfortunately, when it states that I need to reboot, I do, and then I go back to the screen set-up and the request does not hold.
  • 594 Answers
On your laptop did you set it up to clone the origanal screen?
Posted on Aug 29, 2008
  • Cameron Viseth
    Cameron Viseth Aug 29, 2008
    go to your properties. and click on settings. you should have the option to clone the picture.
Are hp laptop and dell monitor compatible?
Without knowing the model numbers of both it could be impossible BUT if you have a connection on the computer that you can hook the monitor to, the F4 key is the one that switches from the laptop screen to the external one. Hold down the key that says Fn and while holding press the F4 key above the number keys on the top row at the keyboard. You should get some activity on the monitor.
Jun 24, 2014 | Dell E176FP 17" LCD Monitor
I forgot my password to Dell Latitude D610 Laptop
Hello, can you tell me if you see the Windows Screen? or is a bios password? 2_25_2013_4_30_31_am.jpg2_25_2013_4_30_55_am.gif
The first one can be unlocked using a program called Active@password.
The second one can be unlocked for $30. Hope this helps.
Feb 25, 2013 | Dell Latitude D610 Laptop Computer -...
Problem connecting Dell D610 operating on Windows XP to TV. Nothing on screen when VGA & S-Video connections tried
OK ..the first thing you should check is the video driver to be installed..cause even if the main display will work without the video driver ...(only with the standard one from the operation system ) , the secondary monitor will not ...so ..check if you have the latest driver installed ..and if it is working ..If you are not sure of it ..just get to the manufacturer site ..and select the model of the laptop and the operation system ..and download the driver again and run it into the system ..restart and now you will know for sure you have it ..
The next action is to try to activate the secondary monitor ..in case it is not activated..This is done from the settings of the video driver....either select video settings from the control panel ..or ..just click right on the desktop ..and select properties..and than settings ..(the last in the right 0 ..In there you have the video settings /display ..
Open them ..and you should see 2 monitors displayed...The no 1 is the one you see on the laptop ..and no 2 is the one needed to be activated.
Click ..on the secondary ...and click activate ...and select a way to function ...as a clone ..or extension ..(cloning means you will see the exact same thing on both ...and extension means that your secondary monitor will act like an extension of the primary one ..and you can set its position by dragging it ..and you can go with the mouse from one to another if you point on the edge between them depending on the position you select in the settings..)
In short ..the important thing is to enable the secondary monitor ..and after that set it as you need..
Usually ..there is a hot key for to enable the monitor ..and it has a monitor sign on it ..and if you press Fn + hot key ..it enables it automatically ..this key can be F5 or F4 or F8 or F10 ..depending on the model and settings .....Please rate teh answer if it helps...have a nice day !
Dec 09, 2011 | Dell Latitude D610 Intel Pentium M 1.6GHz...
Hook-up from d610 to tv
It is possible that your laptop drives EITHER its own display OR an extrnal monitor such as your TV. Look for a Screen Swap key on the laptop keyboard. It is usually a "Fn" key and requires you to hold down the "Fn" (Function) key whilst you tap the screen swap key. This key usually has a small picture of two screens seperated by a / . Hope this helps. Ian.
Sep 29, 2009 | Dell Latitude D610 Notebook
External montior is blank
Are you sure the laptop is powering up?
Do you hear the laptop boot up and the hard drive spinning and the power LED is on when you connected the external monitor?
The monitor must be powered up before the laptop for the video info to switch video port automatically.
If the external monitor is blank then you can't make it work, your video card is faulty and it is not possible to replace as it is built-in on the motherboard. You could replace the motherboard but this may not be a cost effective solution,
May 05, 2009 | Dell Latitude D610 Laptop Computer -...
Have a dell d610. its not picking up the wireless modem in house. worked yesterday. prompting me for wireless switch. and the light/activity/wi-fi light is not on. is there a switch or function key i need...
Your Dell has the ability to turn the wifi on and off using the Fn key (lower left on your keyboard) and (If I remember correctly) the F2 key--anyway, it's the function key that has a little picture of a "radio antenna" on it. Hold down the Fn key and then press that other key. The wireless network should then be active.
Jan 31, 2009 | Dell Latitude D610 Notebook
How to use a sony tv as a monitor?
Change the resolution on the second monitor if you ont have the 2nd monitor on your pc , Clik ON DESKTOP PROPRERTY ,SETING'S amd see the 2nd screen rezolution. and make it smaler on the second ,you will be able to keep bouth screen active the monitor and the main screen of laptop.
Jan 19, 2009 | Toshiba Satellite A15-S129 Notebook
My Dell D610 laptop monitor has went completely white.
I don't have a Dell D610 with me, there should be a VGA/SVGA port on the back. If not, there's a DVI port.
If the video has not gone bad, you should be able to. Connect the monitor to the back vga/svga port or DVI port.
The are several controls to activate the monitor for Dell computers.
CTRL ALT <
CTRL ALT F10
FN F8 (CRT/LCD)
FN D
FN F12
Good Luck.
Dec 30, 2008 | Dell Latitude D600 Notebook
Dell latitude D610 and 1901 FP monitor
Did you hold down the Fn key and press the function key for the external VGA port? It should cycle as LCD only, LCD and VGA, VGA only and then back to LCD.
Dec 28, 2008 | Dell Latitude D610 Notebook
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
