Question about Dometic RM2652 Refrigerator
Dometic Model # RM2652
No power to frig no lights will not work on gas or elec
  • Anonymous Mar 25, 2014
    The elec. and propane are working
  • 51 Answers
Check with a DC meter on fuses to verify voltage is passing then check at the input on back side of the fridge to verify voltage is there. If yes to both it can be the eye brow or the lower control board hard to tell without further testing.
Posted on Sep 07, 2008
Dometic RM 2652 Refrigerator/Freezer is not working. Light works, 110 and propane are fine. Are there steps in trouble-shooting problems with this refrigerator? No visible leak or obvious problem. It's in...
Dometic refrigerator lp gas electronic Model # 3662. Same problem. gas works fine and power is there. as lights on top of frig work.... not even trying to be cold. Same suggestions as 2652? How to bypass thermostat? and will try relay after... thanks.. Bob in Canada<input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" /><!-- from fixya rte -->
Aug 02, 2010 | Dometic RM2652 Refrigerator
Refrig does not work on elec
there is a small fuse on some models and check you heater for a short
Jun 02, 2009 | Dometic RM2652 Refrigerator
My dometic frig will not work no power. Has 12 volt and 110 volts
Replace the bulb and also check the relay and the sensor in the back of the unit. But first try replacing the bulb
Feb 13, 2009 | Dometic RM2652 Refrigerator
Dometic rv refrigerator
I found that they rewired the 12 volt supply, red wire, thru a heat safety switch on the burner unit and it was open instead of being closed and cut off the main 12 volt supply to the control board. I connected a jumper wire around the new switch and the frig works . either the new switch is bad or too close to the heating unit.
Oct 22, 2008 | Dometic RM2652 Refrigerator
Refrigerator not working
The controls for Models RM2612, RM2812, RM2652 and RM2852 are unique to these models. They
are NOT interchangeable with any other models.
If you suspect mismatched part numbers, compare the part numbers on parts to the ones listed below
to ensure a proper match.
The RM2612 with Serial Number 41900000 or higher will have Version III controls as original
The RM2812, RM2652 and RM2852 should have only Version Ill controls as original equipment.
Display Panel 2932189.01
Power Module 2931842.02 or 2931842.03
Thermistor 2931863035
Display Panel 2932189.02
Power Module 2931842.02X
* Power Module has red plugs and a Red Dot on
the cover.
Display Panel 2932189.03
Power Module 2931842.04
Oct 03, 2008 | Dometic RM2652 Refrigerator
Not working on elec.
No most likely you need a heating element. Verify you have 110 volts going to the outlet were the fridge plugs into.
Jul 09, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
580 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
