Question about Sceptre S1902D-4 Monitor
Microtek S1902D monitor
I was using the computer and one day the screen just went off. I don't know if there is a problem with the cable of the actual monitor. Please help!!
  • 3 more comments
  • gaby1120 Aug 29, 2008
    Yes, there is a little green blinking light.
    When I turn off the monitor and turn it back on, the picture comes on for about two seconds and then the screen goes blank again and the on light (green light) starts blinking.
    I just used the flashlight and I don't see anything. Do you think I need a new monitor cable?
  • gaby1120 Sep 04, 2008
    I tried the monitor cable and did not work. I guess I have to buy a new monitor =(
  • Roberta Smith
    Roberta Smith May 11, 2010
    are there still any lights on the monitor (power) ?
    Robert
    Brigadier General:
  • 5,158 Answers
If you have a flashlight.... shine it into the back of the monitor thru the vent holes.... do you see a anything displayed on the screen ... while the computer is on of course.
Robert
Posted on Aug 29, 2008
  • Roberta Smith
    Roberta Smith Aug 29, 2008
    i can bet power supply issues. the flashlight test usually confirms it.
    Robert
  • Roberta Smith
    Try a new monitor cable if you have one and let me know the results please
    Robert
Will it support TV (rca) a/v input through vga
That should work because a/v and vga are analog.
Dec 16, 2013 | Sceptre S1902D 19" LCD Monitor
My screen has gone to a blue tint. What is the life expectancy for a screen?
Blue tint (Red tint, or Green tint) is more likely due to one of the pin on the VGA cable is bent ot the cable is not seated properly of the the video card conectors may be the problem. Try it with another PC and check the pins.
LCD monitors usually fail after about two years due to bad caps.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find
Nov 14, 2010 | Sceptre S1902D 19" LCD Monitor
I powered the monitor off 1 evening after watching movies I was useing the monitor as a second monitor on computer doing multi tasks, but now when i turn it on i just get a black screen it lights up at...
Your computer may not be seeing your second monitor. Go to your display settings and see if you computer is seeing monitor 2.
A fast way to check is to plug this monitor in as your primary on the computer to see if it works.
Mar 09, 2010 | Sceptre S1902D 19" LCD Monitor
? to turn off key lock?
Enter in main menu, settings, touch protection. This should help you
Sep 14, 2009 | Microtek 997M 19" Flat Panel LCD Monitor
My sceptre monitor S1902D won't turn on just stopped
If the monitor has no power at all then you have a dead power board, or a broken power cord, test also a different wall AC outlet.
If instead there is a flashing led on front of the monitor, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
Regards
Mar 06, 2009 | Sceptre S1902D 19" LCD Monitor
My microtek 517m lcd monitor it keeps going blank
the monitor its self has no problem but try installing the drivers again
Feb 06, 2009 | Black Box Computers & Internet
Problem with sceptre monitor
I have repaired a few of this model by replacing the failed capacitors in the power supply.
Monitor Mike
Dec 23, 2008 | Sceptre S1902D-4 Monitor
Computer not recognizing moniter
Resolution set too high for display.
Attach TUBE monitor, Start Windows, change resolution to 1024x768 (MAX) and then hit APPLY/OK.
Also check refresh rate, it is listed in hertz (hz) in advanced settings. Should be 70-72khz not faster than either.
Shut down PC, Connect LCD, you should have a decent picture.
Dec 13, 2007 | Microtek C593 15" Flat Panel LCD Monitor
Hi light is going dim day by day
your monitor is going to damage.the parts inside has leak.the capacitor inside.if you can open your monitor try to diagnose capcitors beside flyback.some of them has a leaky state.ok good luck.
Nov 29, 2007 | X-10 VE710B 17 in. Monitor
Computers & Internet Logo
216 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
