Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Spin cycle I have a LG Tromm WM2077CW. When it gets to the rinse and spin cycle I hear the maching running and some water is coming out, but the drum does not spin and eventually the UE (uneven load light comes on) The machine is only a couple of years old. What's the problem??
  • 706 Answers
You have an uneven load... ( not kidding here).. If you remove and/or reposition the clothes inside . and restart.. does it spin up and complete the cycle? ( probably yes).. but if no.. please elaborate on what it does or doesn't do so we can help.. I've experienced the same problem when my daughter tries to do her entire weeks worth ( maybe longer) of clothes in one load.. The quick fix is usually to down size the amount being washed.. Hope this helps you...
Posted on Aug 29, 2008
  • Reese McCleary Aug 03, 2011
    I have done all of that and even removed everything. Still have the UE with empty tub.
  • Dana H Aug 12, 2013
    Mine will wash, but not spin. And no, my load is not big, never really is. I have cleaned out the little basket (after draining from the spiget, I do now how to do that) and have unplugged and pluged in again. Fills back up, starts to work, then won't spin, makes noise like it's trying.
LG Tromm Steam Washer Cycle is complete and the stuff is so wet that they have to wrung by hand to even put they on a clothes line. Can washer be put on spin only? How?
call a technician as it indicates that the cycle from rinse, spin is not progressing to spin only
rinse,spin is a low speed spin to facilitate the rinse and to balance out the clothes ready for the fast speed spin cycle
Feb 25, 2017 | LG Washing Machines
LG Tromm WM2277 leaking from back bottom
The last spin is the final Emptying phase. There has to be a leak somewhere in the exiting water route. All tubing and the water pump along with all clamps will need to be checked for integrity.
Aug 04, 2012 | LG WM2277H Front Load Washer
you may have stripped teeth on the motor rotor (plastic) to metal drum shaft. this is found behind rear access cover. you will need a #17 socket and breaker bar to remove rotor shaft bolt. if you have a "LE" CODE displayed, you will need a new hall sensor.
May 03, 2011 | LG WM2016C
LG tromm washer stuck in rinse cycle
  • I had the same issue of being stuck in rinse and timer stuck at 20 min. Mine was a water flow problem, at the back of the washer where you hook up the water there is a small in line screen to stop debris from water supply. I removed them, they were clogged, cleaned them up, works great!!!
Aug 22, 2009 | Frigidaire GLWS1339CS Top Load Washer
LG WM2077CW small item trapped behind drum
you would need to remove bottom exit rubber pipe from drum and use a flash light to free coin or screw,hope this helps
May 27, 2009 | LG WM2077CW Laundry XL Front Load...
My LG TROM wash googd but dosn't want to spin
Check and see what type detergent you are using. I bought regular liquid detergent and the machine began making noise during the spin cycle and the drum would not spin. I was informed that you have to use detergent that is labeled HE (High Efficiency). The regular liquid detergent will suds up during the wash cycle which then causes the drum to slip and not spin during the spin cycle. What you are hearing during the spin cycle is the drum slipping. Unplug your washer for 30 minutes and let it reset. This lets the suds dry out. Run a cycle with no spin to rinse out the drum. This should eliminate your problem. If you have clothes in the machine, run a cycle with no spin, just don’t add any more detergent. Then run the normal cycle with spin a second time with no detergent. I hope this cures your problem.
Apr 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
474 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
