Question about Panasonic CT-27SL15 27" TV
I can't change my input source
When I select "TV/Video" the input can change. How I can fix it? Thank's
    Novelist:
    Champion:
  • 277 Answers
Are you using the TV/VCR button on the _original_ panasonic remote control? And do you mean it does nothing?
Posted on Sep 11, 2005
SOURCE:
Pioneer plasma tv will not connect with the tv channels but will allow videos or Netflix what is needed to fix this problem Thank you
To get the TV channels, its input selection should be TV. Check it. To receive video and Netflix, the input selection is AV. Try by changing the input select to TV, and then check. If it do not help you the tuner inside the TV is faulty, and should be replaced. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
http://homenol.blogspot.com/
Feb 05, 2017 | Pioneer Televison & Video
How to source AV Input on remote
Search Results
    How do I change the input on my television? ' FAQ ' Cogeco ...
    https://www.cogeco.ca/.../how-do-i-change-the-input-on-my-tele...
    CogecoClick on the TV button near the top of the remote. Click on the video source button on the bottom left corner of the remote. Using the arrow keys to highlight/select the inputyou want. Some televisions may require pressing the source button multiple times to change the inputs.
    Understanding Inputs - Harmony Support - MyHarmony
    https://support.myharmony.com/.../understanding-different-input-changi...
    Televisions, AV receivers, soundbars and other home electronic devices switch ...Devices with toggle (or cycle) inputs have a single button on their remote that ... In the below example, you would press the Source button to bring up a list of ...
    Changing AV input on TV using Sky remote ' AVForums
    www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
    Changing AV input on TV using Sky remote. Discussion in 'Satellite TV, Sky TV ...VSX-924 LG simplink changing AV source to TV. Posted By djrobmac In AV ...
    Selecting the DVD, VCR, Game Console, HDTV, Camera, or ...
Feb 08, 2016 | Venturer KLV39150 15" Under Cabinet LCD TV...
Problem: TV Menu w Auto & Manual Scan greyed out cannot be selected
Check the input selected. if it is other than tuner, this might happen. Change the input to tuner, and check.
Jan 11, 2016 | Televison & Video
Im having problems with my brand new Westinghouse LD4255VX. i bought it tonight, took it home and took it out of the box. at first it turned on fine, then got to about the 3rd step in the setup menu and...
It sounds like the problem is simply the input selection.
SELECTING THE INPUT SOURCE
There are two ways to select the video input source.
Using the Individual Input Keys
TV, PC, Video, YPbPr, HDMI Keys
Press any of the following remote control keys to change the input source: TV, PC, Video1, YPbPr1, HDMI1, or HDMI2.
Let me know if this fixes your problem
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | Televison & Video
No picture on this TV. Sound is OK
Hi! Welcome to Fixya!
If you are unable to view video on your television set, the issue may be that the TV's video input selection does not match.
The TV input source must match how the equipment for example DVD is connected to the TV. Every TV is different in the way that the ports are configured on the back of the TV and the menus are presented on the TV screen; however, there are some basic similarities between them.
To correct the issue, use the TV's remote control and change the video input selection. Many newer TVs have an auto-detection system and will automatically detect that something is connected to the various ports on the back of the television. However, some TVs have to be configured manually.
Some common names of the button on the TV remote are:
  • Video Source
  • Video Input
  • TV/VID
Locate the video input menu for their specific TV. Below is an example of the video input menu of a TV.
This example indicates check boxes next to the items that the TV is detecting. Be advised that this menu must match the location on the back of TV where video components are connected.
You may also check if all cables are properly connected.
Thank you.
Keep me posted. :)
Lor04
Mar 12, 2011 | Televison & Video
When I switch on the unit, i can hear the sound but there is no picture
The TV input source must match how the device for example DVD player is connected to the TV. At the back of Samsung's LN40A650A HDTV are three HDMI inputs, plugs for component input, an antenna input for the DTV receiver and a VGA input. Please check on what port the device is plug.
  • Press the Menu button on the remote control and navigate to TV Input
  • Only ones that are actually connected are highlighted and available.
  • If there are multiple device connected please make sure you select the device you want to connect.
Thank you.
Mar 12, 2011 | Samsung LN40A650A LCD TV
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, mikedee4@gmail.com
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
Jan 20, 2009 | Televison & Video
Manual donwload
Video input source is changed by the buttons:
1. Video Source
2. Input
3. TV/Video
4. Source
one of those four on the remote some where.
Also, chances are your TV itself will have one of those buttons somewhere.
Usually pressing it will either cycle through the inputs or bring up a selection of them, which is usually navigated by either arrow buttons on your remote or the channel up and down keys.
Lemme know how it goes.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Panasonic CT-27SL15 27" TV Logo
224 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
