Question about Yamaha RX-V890 Receiver
Front speaker output is not working
My receiver has been sitting in storage from last move and I do not have remote- but my yamaha rx-v890 front speakers do not work.
  • 3 Answers
Firstly ensure that the 'mute' has not been accidently engaged.
Have you tried connecting other speakers to the same output and cables? If the sound now works, the problem is with the speakers (providing all amplifier settings are correct and wiring is correct). It would be highly unusual to have a problem with both speakers or two sets of cables. Alternatively connect the problem cables and speakers to an alternative source. If they work on an alternative, you are looking at an amp issue.
Posted on Aug 29, 2008
My Yamaha RX-A830 won't play the sub. I've reset the speakers with the mic multiple times but it's still not working. I confirmed that the sub works on another receiver.
There is a difference between SUB and LFE. In 5.1 mode, the LFE is the ".1" channel. It will output bass only when audio information signal is addressed to this channel. In stereo mode, depending of the receiver setting, it can output normal bass when front speakers cannot handle low frequency. In setup menu, you'll probably have to set your Front speakers as "Small" to make the sub channel taking the relay in low frequencies. There also can be many other reasons for your problem but this might be the solution. Good luck!
Dec 02, 2013 | Yamaha RX-A830 A/V Receiver -
Connect speakers
What kind of problem are you having?
Jun 29, 2013 | Yamaha RX-V890 Receiver
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
I Have a Yamaha RxX-V890 that turns off when in use. I have it connected to two theater logic T 2400 tower speakers (400 watt, 8 OHMS). As soon as i turn the music up at a decent volume the receiver turns...
First of all, the speakers are part of a scam. How good can they be?
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Aug 11, 2011 | Yamaha RX-V890 Receiver
Yamaha RX-V861 no sub woofer output
It sounds like you have switched off the sub channel.
Keeping pressing C Level on the remote till you see SWFR.
Press D l / h to adjust the speaker output
level.
Jun 25, 2017 | Yamaha RX-V861 Receiver
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I have a Yamaha RX - V665 and the right rear surround works only part of the time.
Start by using an old test speaker and connect it directly to the right surround output with a short wire and monitor it.
If it sems to work with no issues, you either have a bad connection at receiver or speaker, or a break in the speaker wire somewhere.
If you have the same problem with the test speaker, you have a rgt. rear output issue in the receiver and it needs repair.
Hope this helps
Apr 17, 2010 | Yamaha RX-V663 Receiver
I have distortion coming out of my front right channel of my AVR
Yes, sounds like your DSP chip has an issue. Not an inexpensive repair if that's the culpret. Around 400-500 to replace the chip. It's an awesome receiver and worth 300-400 in repair, however, a 3800 or 1800 can be had for 600-800 depending where you look. If you need more help, post a comment and I can help you some more.
Aug 10, 2009 | Yamaha RX-V2600 Receiver
Yamaha RX-V2700 no sound from any speaker outputs
Make sure that you have the correct input signal selected.
Also, check if the sound is not muted.
If you have a multi-room speaker switch, make sure it is set correctly to main speakers.
Apr 28, 2009 | Yamaha RX-V2700 Receiver
Power shuts off
is it pl;uged direct in wall must nbe on a nice hi end break surge proably got zapped transisters in it best to try to replace it u can try to un plug it from that outlet few min then back in anther one
Jan 21, 2008 | Yamaha RX-V890 Receiver
190 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
