Question about Brother MFC 1950MC Printer
Brother 1950MC Print Problem
Message: Hi, I just put a new cartidge in and it on prints on the left side of the page - the right is blank. Tried the following: 1) reinset cartidge - 4 times. 2) clean heads 3) power down 4) bought a second new cartidge None of this worked. I put the old one in and it did the same. Before I changed it - it worked. Any ideas?
I have had the same problem, and it does appear that it is related to the section connected with the blue clips. You can trick the machine into thinking that the cover is closed (There is a lever on the left front that you can see when the cover is open.) Then, if you try to copy a page and while scanning, hold down on the metal bar on the bar connected by the two blue clips (hold it all the way down), I found that the printer worked fine. There are a couple of ways to jury-rig things so that this can work, but I don't think it's worth it, as the print quality of this machine isn't too great anyway. Find a cheap unit at OfficeMax, OfficeDepot, Fry's Electronics, or another discounter instead. Thanks for the other posters as it would have taken me a lot longer to figure out that this wasn't worth fixing.
Posted on Jun 17, 2008
Had the same trouble as the below. Changed out the cartridge with a new one and only printed out on one side of paper.
If you apply heavy duty packaging tape down on the silver bar that comes down over the film it will solve the problem. But if that tape gets loose it will start doing it again. So you have to change out the tape when you change out the cartridge and make sure enough pressure is applied.
In other words you have to rig it to work correctly.
Posted on Oct 26, 2007
  • 3 Answers
I have this same problem on two of the same fax machines. It was printing fine and when I put in a new cartridge, it started printing on the left side only. I bought a used one off Ebay and it only prints on the right side. Did you find the answer or part number to correct it? Thanks - MJ (
Posted on Aug 31, 2007
I am the owner - it was suggested to me that the 'blue toner clips' - two on each side that hold the ribbon cartridge down are broken. I checked them, this is not the case. I called Brother they suggested i take it to the nearest service center - 212 miles from away. I give up.
Posted on Sep 14, 2005
  • 277 Answers
Listen, my friend had the same problem with his MFC 1950MC: "... have a Brother MFC 1950MC fax machine. I bought it used because I can't afford to buy a new one. I was told it was ok but it's not. It prints on only the right half of the paper. I was told by a 3 different authorized service centers that it's a common problem and requires a specific part that almost always fixes the problem. But, they won't tell me the part number or sell it to me. I think I found someone who will sell me the part if I can give them a part number. Anybody have any knowledge of this problem? If so, please help me out with a part number or solution. ..." Anyway, he found it on: but he cant remmeber the part number. sorry. Hope it helps. K.
Posted on Sep 11, 2005
The black ink on my Brother DCP-130C won't print and it's a brand new ink cartridge. I thought it was a defected cartridge so I bought another one, same thing. The other 3 colours print ok though....
I have the same problem. Everything on the printer is working just fine. It'll do a test page just fine, so everything's working right. The %$^ thing just won't print. It makes noise like it's printing when you give it a print job, but it spits out blank pages.
Sep 08, 2011 | Brother DCP-130C InkJet Printer
"Machine Error 81" message when I tried to set up my 1950 MC
check for any papaer jam or any dust material blocking the rollers of the printer to move.OFF the printer.and blow air through the blower in whole internal area off the printer.then ON and check.
Oct 29, 2008 | Brother MFC 1950MC Printer
All of a sudden my printer will not print in color.
Have you tried printing a test page and re-aligning it?
Jun 18, 2010 | Brother MFC 210C All-In-One InkJet Printer
Only one side of the page prints out
try looking at 1 of 2 slate-blue retaining clips that secure the thermal cartridge in place on the side that is NOT printing.
it could be broken.
it will need to removed to see any cracks or breakage.
Jun 23, 2009 | Brother MFC 1950MC Printer
Print only on rigth side. I know it the blue lever. Where can I get parts
I have the same problem with my 1950MC. When I examined the blue lever carefully on the right side of the machine I found that the plastic lever was cracked at its thinnest point. Thus when both levers are locked down that one was not holding the print head tightly enough to print that side of the paper. If I held the print head down manually, the copy printed fine. So if you have this problem, check the blue levers for cracks. The levers are easy to remove and should not cost very much. I recommend that you replace both left and right levers. These plastic parts cannot stand up to very much use without cracking.
Jun 22, 2008 | Brother MFC 1950MC Printer
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC 1950MC thermal ribbon fax machine
Sounds like print heads are fried. I found this guys website he says he has lots of brother parts and his rating is good. Otherwise you might have an auction of your own to sell your PC101 carts. As far as your Ebay problem, that's why they have a dispute department and feedback. Good luck
Aug 30, 2007 | Brother MFC 1950MC Printer
Mark on page
First try to clean the head: Open the top cover and print head, Moisen a small piece of soft, lint-free cloth with alchol and keep wiping the edge of the print head... second, This could also be caused by excess lubricant on the tonercartridge . Print or feed up to 10 sheets of paper through the printer to eliminate the marks. If the problem continues please contact Brother Customer Service at 1-800-284-4329 Monday through Friday, 9:00am - 7:00pm EST, excluding holidays.
Nov 29, 2005 | Brother MFC 1950MC Printer
Brother MFC 1950MC Printer Logo
190 people viewed this question
James Cagle
James Cagle
Jim Keysor
