Question about Panasonic PT-47WXC43 47" Rear Projection Television
Comes on for about 3 seconds and then shuts off!
I turn the power on and it shuts off after about 2-3 seconds. I get a brief picture and then it's out. When it goes out my power indicator light blinks 3 times and pauses, blinks 3 times and pauses...so on and so on. Any ideas as to what may be causing this???
  • Anonymous Mar 25, 2014
    Turn on power,gets a picture for a few seconds the it shuts off and blinks twice.
    Novelist:
    Champion:
  • 277 Answers
My Panasonic PT has developed the same problem: The repair folk came and replaced the "entire" electronics section! The guy said it was $1500 just for the section. He had no idea what caused the problem---just that Panasonic told him to replace the entire unit. I'm delighted it was still under warranty!
Posted on Sep 11, 2005
    Novelist:
    Champion:
  • 277 Answers
I have the same problem: It seems the high voltage trasnformer blew which in turn casued the pin cushion?? to blow. It then shuts the tv off to prevent more damage to it. Gonna be about $500 with service charges to get it fixed!
SOURCE:
65" RCA LED led65g55r120q Screen flashing on every few seconds
You have at least one bad LED strip, it is drawing to much current and shutting down the power supply for the lamps, you can fix this yourself but its not real easy getting the panel out and back.
Oct 17, 2017 | RCA Televison & Video
When I turn the tv on the power light goes green for a couple of seconds then it shuts off and the picture never comes up.
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Jun 03, 2011 | Mitsubishi WS-65315 65" Rear Projection...
Everytime I turn on mu playstation 3, no picture comes out in TV.
Try accessing the recovery menu 'safe mode'.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Try 2-5.
Try using HDMI cables and AV cables.
Jan 16, 2011 | Sony Playstation 3 (PS3) Console
Whenever i plug the unit in i hear a clicking sound from the back of the television it is for about 3 seconds and it usually takes 2-5 seconds before it starts the noise. The power light only comes on for...
Ur tv turn on now,hear alot of clicking?The tv LED light "lamp" on front panel flashes or light up?The tv projection lamp is dead.The Ballast board dead too,if hear alot of clicking?The ballast board help to ignite the projection lamp.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
Monitor comes on for a brief milla second then
hold the power button for 5 sec : if the picture appears replace the button. ELSE check the chimic capacitor if damadged replace with new
Jun 21, 2010 | Dell E173FP 17" LCD Monitor
Mitsubishi w52525 - replaced lamp and red light still on
could be the wrong lamp or not set right in housing or bad door switch.
May 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
On start-up, Samsung S860 beeps 3 times then turns itself off
first off,never use rechargable batteries in this camera or most digital cameras for that matter.2 use only lithium batteries,enegizer preffered.,also yes you can view all your pictures when connecting the usb,meke sure you turn the power on,and highlight the word computer,push ok.you should be fine.good luck .i hope i helped
Apr 30, 2009 | Samsung S860 Digital Camera
Will not come on
Check capacitors 3 of them cp150 2200uf 16v if it is bad set will not turn on other 2 caps will be next to it 220uf 35vs.cp111 cp114 cp120
Dec 14, 2008 | RCA D52W19 52" Rear Projection Television
RCA P52937SG
Time to replace.
Mar 10, 2017 | Televison & Video
Open Questions:
Panasonic PT-47WXC43 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
