Question about Microwave Ovens
Amana RFS12SW2 microwave. Mag is overheating; the TCO is working properly and shuts the oven off at 325 degrees F. I replaced it for good measure and it made no difference. It takes on average 2 minutes of running time to get to this point. The transformer is reading 85 ohms on the secondary. This Mag is a replacement for the one that was discolored on the plastic where you connect the two high voltage wires. I am a novice at this and I'm stumped as to what to do. Thanks for any help.
  • tarun01 Apr 17, 2009
    my microwave is not heating the product, all other function working well.
    can some one tell me what's wrong ?
    Thanks
    Tom
  • William Miller
    William Miller May 11, 2010
    Is the cooling fan working right?
    Is the air path sealed well?
    You can't test run these with the cover off very long or they will overheat because the cover is a critical part of the air flow.
  • Microwave Ovens Master
  • 9,098 Answers
Posted on Sep 01, 2008
I contacted Amana tech support. They stated to check that the stirrer was revolving and to make sure I had the cover back on the microwave. Once the cover was put back on and the grease shield was in place, the stirrer did revolve and the magnetron no longer overheated.
Posted on Aug 31, 2008
I have a Amana microwave with a f-5 fault code.Model#RFS12SW2
Hi ejv3968,
This means that you have a control board failure. Error code F5 can only be fixed if the control board (ERC) is replaced. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Apr 05, 2011 | Amana Radarange Microwave Oven
I have Amana Commercial microwave RFS12SW2 The fan keeps running even door is open , it wont stop.
These microwaves are designed to run the fan for a couple mins after the cook cycle to continue cooling the electrical components.
Oct 20, 2010 | Amana RFS12MPS Microwave Oven
Microwave runs for about 3 seconds and turns off
most likely the thermistor that shuts off the magnetron tube for overheating is defective,if all else is good and there are no hot odors,its mounted on the vent side of the mag
Jul 25, 2010 | Panasonic NN-S540 Microwave Oven
Panasonic NN-C980B stopped working. Blown fuse.
Sometimes when the mag shorts it takes out the inverter. I would measure the mag leads to ground and they should be open or 20M or so. If you have both a mag and inverter bad it's probably time for a new oven.
Apr 19, 2010 | Panasonic NN-C980 Convection/Microwave...
Quit working circuit breakers are ok where's the fuse located?
it is an inline fuse between thepower in and mag tco, check hv capacitor for a short
Feb 05, 2010 | Jenn-Air JMC7000 Microwave Oven
No heat
The service manual is here.
Jan 29, 2010 | Amana RFS12MPS Microwave Oven
Only heats to 325 degrees in convection mode. takes long time to reach this temp.
Hi two possabilities here, either the element or the thermostat is faulty and will need to be replaced.
Jan 07, 2010 | Amana AMV6177 Convection/Microwave Oven
Kenmore Ultra Wave Microwave has no power
after removing the cover of microwave chk for continuty of cavity thermostat usually calld TCO(thermal cut off). it is located on top of the cavity and circular in shape.usually neutral wire goes through this 2 control board and this TCO is for protection of cavity from overheating.if this tco is open.then replace it.usually this happens when u cook for 2 long.
Aug 15, 2009 | Goldstar MV-1515 Microwave Oven
Vent Fan Will Not Shut Off
The vent fan TCO is a normally open type. I would say you replaced it with a normally closed type.
Probably the only TCO that was bad would have been the magnetron TCO.
If you still have the old vent TCO, I'd reinstall it.
Otherwise, you can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
We own a GE Microwave jvm1653sh01
The first thing I would check would be the magnetron TCO (thermal cut-out). This is a little safety devise that protects the magnetron in the event of overheating. These can act up even without overheating. I believe the nuetral side of this TCO runs through the board, and therefore the flickering and shutdown. When the TCO cools, it resets. If it were the door switch, you would blow the fuse and wouldn't be able to set the time without changing the fuse. There are other cavity thermostats that could be the culprit but my quess is on the magnetron TCO. When working with microwaves always unplug the unit and discharge the capacitor. This is high voltage..Good Luck
Jun 11, 2006 | GE JVM1651 Microwave Oven
Microwave Ovens Logo
252 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
