Question about Casio FX-9860G Graphic Calculator
Casio fx-9860g ............ how to do percent operation
Hi , I recently bought the Casio fx-9860g calculator for school and I'm wondering how one would do a percent problem on it ? Even the cheapest calculators have a % button . What am i not seeing ?
Any insight would be greatly appreciated
thanks , Sean
  • Casio Master
  • 7,993 Answers
[OPTN][LIST] scroll right till you find %. Press the function first then the number. It gives you the percent.
Hope it helps.
Posted on Oct 01, 2009
Not quite, [OPTN][LIST] scroll right till you find % is a LIST function, it is intended to work on a list. Pressing the button sequence will produce the word PERCENT immediately follow this with a list in braces ie {10,1} now press EXE and the result should be {90.91,9.91} ie PERCENT finds the total of the list which is 11 in this case and then displaying what % of this total 10 is and then what % of this total 1 is. But this does not answer the original question. I cannot find a simple % button type function anywhere in this complex beastie very frustrating!
Posted on Feb 23, 2015
  • 76 Answers
Hello wake up!!!almost all operations can be done on the scientific calculators...the % problem can be solved in the calculators...the % option can be used by pressing once the SHIFT button...and press = button...using this u can find % for any numbers!!!!
Posted on Jul 24, 2009
What is an Ma error casio fx-9860gii
Ma error means Mathematical error.
Check input values and make corrections to ensure that values are within allowed limits.
Please Check the manual for the calculator. It is available on the Casio website. Here is the link.
fx 9860G fx 9860G SD Calculators Manuals CASIO
Aug 30, 2014 | Office Equipment & Supplies
Casio FX - 9860G SD have complex equations??
Your question (?) is not clear so I will not try to guess what you really mean.
Be it as it may, the Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Apparently it will take coefficients that are real, and will give a Ma Error if any coefficient is complex.
Mar 16, 2012 | Casio FX-9860G Graphic Calculator
Can you calculate indefinite integrals on the casio fx-9860G
Unfortunately, the Casio FX-9860 G does not have a Computer Algebra System or CAS. For this reason it can only calculate definte integral over a given interval. The lower and upper limits must be supplied. The result will be a number.
Casio calculators that have a CAS are the Casio ClassPad CP330/ 300Plus/ 330, or the Algebra FX 2.0.
Feb 08, 2012 | Casio FX-9860G Graphic Calculator
Prime factorization using Casio FX-9860G Graphic Calculator
There is a program called Prime Factor Analysis on this site. It is written for the FX-9750GPlus calculator but I suspect you should be able to use it on the FX-9860G. To access the site you must have an account. You can register and it is free.
Jul 30, 2011 | Casio FX-9860G Graphic Calculator
I have the casio fx 9860G. how do i take a screen shot form the calculator and then get it on a word document?
The easiest way to do this is to take a photograph with a digital camera or mobile phone and transfer using blue-tooth or data cable to a PC.
Mar 24, 2011 | Casio FX-9860G Graphic Calculator
How can you change the mode on a casio fx-9860g calculator to deg. mode?
Press SHIFT MENU to bring up the setup screen. Use the arrow keys to move to the "Angle" line and press the function key for the desired angle mode.
Mar 04, 2011 | Casio FX-9860G Slim Graphic Calculator
How to calculate percentage in fx 9860G
You will find the Percent operator under the List submenu.
Press Menu.
Use Arrows to highlight RUN menu and press EXE
Press F1 to open the list submenu.
Press F6> , F6> to leaf through the menu pages.
Then Press the F4 key, under the percent sign.
Dec 27, 2010 | Casio FX-9860G Graphic Calculator
I have the Casio FX-9860G Slim, how do i do logs with something other then base 10?
Use the logab function in the catalog. For example, to calculate log base 2 of 32:
OPTN F4 F6 F4 2 , 3 2 ) EXE
Dec 15, 2010 | Casio FX-9860G Graphic Calculator
Installed a wrong OS update version
get battery out-and install it again(after you return the battery)
Jun 27, 2008 | Casio FX-9860G Graphic Calculator
Casio FX-9860G Graphic Calculator Logo
2,441 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
