Question about Pioneer Audio Players & Recorders
I have just purchased a Pioneer VSX517 and have connected the digital audio (via SPDIF cable)to a digital TV (Hisense mod-HSLC2629HDI). I have selected all relative options on the amp (auto, digital & analogue) The analogue works fine (AV from the TV for video), but I cannot get sound from the optical connection for digital TV stations. The TV is transmitting light via the cable, which makes me suspect a setting or problem at the amp. Out of desperation, I selected all sound options (5.1 surround, stereo etc.) Any help appreciated.
  • 3 Answers
After some searching I found that I needed to assign the digital input, as instructed on page 30 of the instruction manual, "The Input Assign Menu".
Posted on Aug 31, 2008
My pioneer vsx517 does not receive sound from the tv connection. where to look for the cause?
hello
check the input cables it might be broken or loose . and if not then check your selection on the front panel ,
if not then you have to service your pioneer .
the cause, it can be the electronic selector is damaged
hope this helps
kind regards
Apr 24, 2016 | Pioneer Audio Players & Recorders
How do I connect a Pioneer S508 amplifier to a Samsung Bluray DVD player?
This is a common problem. Not all models of DVD players have analog audio connections.
The image of the back of the DVD is suppose to be a BD5700?
The connections AUX on the amp and the connections audio out red and white RCA connector are connected with a audio cable.
The images marked with the red are these locations
If your model of DVD player does not have a set of red/white audio connectors you have two other choices.
  1. If TV is connected via HDMI that the audio is included to the TV. The TV will likely have a set of red/white audio "out" RCA connectors that would connect into the Pioneer.
  2. Purchase a specific powered adapter that takes the Optical audio signal and converts to a analog RED/White RCA connector that will connect via audio cables into the AUX of the Pioneer,
Dynex Optical Coaxial Digital Audio to Analog Audio Converter Black
Jan 07, 2016 | Samsung BDD5700 BluRay Player
Can't hook up my sb 2920x-c6 to my auria eq 5888 tv where audio out jack
can't find that eq 5888 model number but does the tv have a connection labelled as spdif this is a special digital audio out standard by phillips.
http://www.hardwaresecrets.com/everything-you-need-to-know-about-the-spdif-connection/2/
I am not sure if this can be plugged into the sb 2920x-c6 digital in socket or if you need a digital amplifier between the two items ?
Someone else on fixya may know if a digital amplifier is needed or a direct connection from tv to sound bar is possible via a spdif cable.
Nov 27, 2015 | Audio Players & Recorders
Sound output through hdmi
DVI is "Digital Video Interface". No Audio is transferred through this type of connection - even if one end of the cable is HDMI.
BEST solution would be to purchase a video card with HDMI output.
Alternate solution would be to run audio from rear audio jack to TV (assuming you have an input on the TV that will accept it)
Dec 29, 2012 | ASUS P5K64 WS Motherboard
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
Nov 25, 2010 | Pioneer VSX-455 Receiver
How to connect the PS3 to RX-V365 to get best sound qualitity in films. I have sony BRAVIO LCD wiht PS3 and I recently bought RX-V365 Yamaha home theater system. Please advice on connecting all three to...
You can connect PS3 video via HDMI to receiver and from receiver via HDMI to TV. But RX-V365 doesn't support HDMI audio, so you have to connect audio separately via SPDIF digital cable. I think PS3 uses optical SPDIF, so you will need optical cable. If you can't find cheaps optical cables in your shop, you can try byuing from ebay ($1-5 max.)
Feb 13, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I plugged in my cable HDMI into my RX - V365 Yamaha reciever. and HDMI into my TV. I get video, but cannot get my attached (to reciever) speakers to play. Help
RX-V365 doesn't support HDMI audio. You need to connect the cable box also via spdif cable for audio to work. Look at the box if it uses optical spdif or coax spdif. If optical, you see that optical input on receiver is named DTV/CATV, so use also DTV HDMI for video. Coax spdif is named DVD, so in this case you will need to use DVD HDMI input.
Also you need to configure the inputs accordingly.
Nov 14, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Pioneer vsa e06
depends what audio outputs you have on the sky box,analogue (two phono usually red for right channel and white left channel)in which case just use phono leads to the phono inputs,Optical(toslink),connect an optical cable from the output to the optical input on the dvd channel of the pioneer,coaxial (spdif)connect to spdif input on the laser disk input of the pioneer,dont connect to the attenuated spdif.In the unlikeley event of the sky box not having any audio outputs,just use the outputs from the tv to the pioneer.The optical digital input gives the best quality on the vsa eo6
Jan 24, 2008 | Pioneer VSX-1015 Receiver
191 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
