GenCdRom my cdrom cant be install code 10
  • mund5 Aug 30, 2008
    I also get a code 10--my cd-rom tries but fails to start. mund5
  • 43 Answers
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows failed to start (code 10)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Sep 18, 2008
Baixar driver gencdrom
Drivers and other software are available from here: http://www.baixaki.com.br/categorias/256-drivers.htm
Nov 10, 2013 | Foxconn G31MXP-K Core 2 Quad/ Intel G31/...
Cannot boot from cdrom
your cd-rom reached its end of life, your best bet is to buy one, either online or at your local computer store.
Apr 09, 2012 | HP Compaq dc5100 Desktop PC - Intel...
Hi, my name is victor. I have a HP Pavillion dv9225nr entertainment laptop, with amd turion dualcore x64, 4GB's RAM, and a Pioneer slimline dvdrw drive. the drive is a (pioneer dvr-kd08hb____1k09_...
Hi digitaldr445 !
This is one solution , maybe not the easiest one nor the best one but it will work .I understand you have the Win 7 install disc :
Back up your data , especially the drivers .
Extract the hdd out of your lap , put it in a external USB box or use a specific connector to connect the drive to a healthy pc . Format the drive . Place it back into your laptop and reinstall
Windows 7 .
Best regards .
fanaudi .
Feb 25, 2011 | Computers & Internet
Error 0xeb020b88
Are using roxio ,nero or Cyber link software?
Aug 02, 2009 | Computers & Internet
Very slow system boot up and report for Express Gate error code C800002
What the error is telling you is there is an error on trying to install Express Gate. and best to install on a USB drive. If you must install it on the hard drive. you will have to set to IDE not AHCI or RAID mode. ExpressGate has to be installed on the SATA hard disk is connected to the red SATA port. (Other color slot can not be used)
May 07, 2009 | Computers & Internet
Cant install windows xp
You Need To Boot From The XP CDrom...
Press Power Button To Boot, Hold Down F-12, Choose To Boot From CDROM, Go Through The Windows Setup Process, Remove Vista (delete it), then Format and Install XP...
Your 7520 can use the drivers from another acer model, for instance, try aspire 3000, or 5000 drivers.. or try another model...
If it's not the correct one, it will not install and throw up an error telling you it is incompatable and not going to install....
Feb 05, 2009 | Acer Aspire 7520-5757 Notebook
My pc cant restart aspire 5610
Hi, This might be a solution:
get into setup mode (before booting) and set the settings to default.
Now, try installing the OS from the cdrom.
You may also want to check if the CD is not corrupt. try that CD with some other computer (to see it getting stuck at the same stage).
Sep 20, 2008 | Acer Aspire 5610-4648 Notebook
Cant able to format HD
To re-install XP over it's self. Put the CD in your cdrom drive. Start the system & press the F5 key every 2 seconds. This will load a boot menue. Using your keyboards up & down arrow keys highlit the cdrom drive & press enter. You will see to boot to the cd press any key, press the space bar. XP will start to load. Choose the correct options for a re-install.
Enjoy!
please vote...
Feb 26, 2008 | Samsung 80GB INTERNAL 3.5- IN SATA HDD...
Philips dvd re-writer spd 2412 t
download the newest driver for your dvd writer which is specifically made for vista operating system. install it, reboot your computer and test.
Feb 25, 2008 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
Installing XP on a dell computer
try to go to bios and load bios defaults, esc then save and exit. boot from the cdrom by, tapping on F12 at dell screen. at boot menu screen, choose cdrom, press enter, when you see the message, PRESS ANY KEY T5O BOOT TO CDROM, hit any immediately, that should allow you to install xp directly from the cdrom.
Feb 13, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
4,491 people viewed this question
David Payne
David Payne
