Flickering screen could be indicative of a loose connection
or a cold solder. Most likely, it would be in the inverter and/or CCF
(cold cathode florescent) lamps. This is a relatively easy repair by
re-soldering. It is perhaps more of a task to open the panel lid/cover
of the LCD display.
This of course would require a fair
familiarity of electronic components/circuitry and safety procedures,
use of a DVM and a soldering iron. It would be to your added advantage
access to a service manual or at the very least a schematic diagram
with voltage readings. Should you be uncomfortable performing a DIY
(do-it-yourself), perhaps your best bet would then be to seek the
services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
this is a new laptop, I bought it on november last year, and the the issue started around a month ago
Has this problem only just started occurring ?
or
Is this a new laptop ?
please write back
Thanks
