Question about Archos Audio Players & Recorders
I can't make my archos
When I make a playlist for my Archos 504 on my laptop, and then select a song to play on the player, it plays it but won't stick to the playlist. It just moves onto a song from the general library. And when I try to open a PDF ebook on the player, it won't open at all.
  • 7 more comments
  • allietwo Aug 29, 2008
    Sorry I don't understand the response I got. I would love some step by step instructions on adding a playlist from my laptop and adding pdf documents to my archos player. (just assume I'm stupid when you answer basically, I won't take offence!! lol)
    Thanks but I know how to do it on the player itself. What I need to know is how to do it from my laptop. You know like dragging and dropping files from a folder on my laptop to the folders in my archos that come up when you attach it with a usb cable. which is what I did originally but it doesn't seem to play them as a playlist despite them being in a playlist folder.
    I also transferred the pdf the same way, by dragging the file to the archos player window.
  • allietwo Sep 05, 2008
    The main problem with my Archos 504 right now is getting a PDF ebook I bought onto it. I'm not sure
    1. What folder to put it into when I drag the file from my computer to the device.
    2. How to make the device read the pdf - do I need a converter of some kind or is it something to do with a license?
    Any suggestions about the PDF ebook issues in my above details? Thanks
    How do I do that?
    Thanks Ekse but that's what I've been doing and although it shows up for selection under the browse section of the device, it won't open at all.
    Yeah it opens fine on my desktop so it's def not corrupted. I checked for new firmware downloads and my current one is 1.5.55 and on the website it says this:
    " Download Archos 504 OS v 1.6.53 (17638Kb)
    Caution: For technical reasons, this release of the Operating System (OS) will not allow a downgrade.
    If you feel you do not need the improvements brought by this release or want to be able to downgrade to a previously released version, then you should not upgrade your product with this release.
    Be assured this was done purely out of necessity and not as an attempt to limit using previous OS versions."
    Would you say I should download that or might it cause problems with my device?
    Well there were several helpful suggestions and they work to an extent but I guess it's the sort of problem I need to show someone in person. Thanks for this solution, I'll try it.
  • allietwo Sep 08, 2008
    I am still having trouble with making my Archos display PDF ebooks. I am hesitant to download the firmware update due to what the website says about it (I included that in one of my above comments)
    Genius:
  • 1,269 Answers
Select the Show playlist menu item while you are in the Music browser. A playlist panel will open on the right: you can now start adding songs to the current playlist. In the left pane, locate the songs you would like to add to your playlist. Highlight a song and press or OK to add it to the playlist (the song’s icon in the left panel will change to, indicating that it is part of the current playlist). Repeat this operation with all the tracks you want.
You can also add the content of an entire folder, artist, album, etc. if you highlight it and press OK.
Another way to add songs to a playlist is by using the Add to playlist or Insert in playlist menu items:
Add to playlist - will add the highlighted track, folder, artist or album at the end of the playlist.
Insert in playlist - will insert the highlighted track, folder, artist or album before the selected item in the playlist.
Note: a playlist can have a maximum of 5000 songs.
You can use TextEdit application to Add/Delete/Move the mp3 song in the playlist.
For example the playlist file you just created has the default name untitled playlist.m3u and there are 2 songs included:
/Music/Danielle Davis/I'm Sorry.mp3
/Music/Danielle Davis/Outta My Dreams.mp3
If you want to Add another song from a different location (ex. Slobberbone folder, song name: slippage.mp3), then you just need to open the untitled playlist.mp3 file with TextEdit and add another line to:
/Music/Wes Burden/ Brave New World/Brave New Wold.mp3
Save the untitled playlist.m3u file again and close. Next time when the untitled playlist.m3u is opened, you will see that there are four mp3 songs included.
Note: to delete a song in the playlist, simply delete the line which contains the title of the mp3 song.
If none works, Firmware update is an option.
Download the firmware from Archos Website.
Connect the device to the PC.
Go in “My Computer”, you should see “Archos 504/604”.
Copy/Paste the firmware downloaded on “Archos 504/604”
Disconnect the device safely. Go to Setup > System > Update Firmware.
You can also copy the firmware update file to the root of the device, and select while browsing the hard drive content with the “Browser”.
Posted on Sep 05, 2008
  • Archos Master
  • 13,433 Answers
Hey
alright, pdf into the player, I will figure this out for you, please hold on for a few minutes, please don't reject my solution untill I have posted everything I have to say.
One moment..
  • 2 more comments
  • Ekse Sep 05, 2008
    The pdf reader on the archos 504 is really easy to use.
    To open a pdf document, in the pdf document in the file browser and press ok.
    simply copy your pdf file into the archos into a folder that you can easyly find when your using the file browser on the device.
  • Ekse Sep 05, 2008
    you can find your user manual from
    http://www.archos.com/support/support_te...
    talking about the pdf reader in the page 35
    is there anything else I can help you with or do you need more assistance with this or anything else? please let me know.
    Thanks,
    Ekse
  • Ekse Sep 05, 2008
    Corrupt file? does it open on your desktop?
  • Ekse Sep 05, 2008
    Also I would suggest performing a firmware update from the archos website.
    President:
  • 1,263 Answers
Alot of times windows media player is not compatible with certain players. most often times you have to install an updat to the programing of your player. even though you can get most files to play without the update, you can't fully sync with device. if your having problems and don't think windows media is allowing the files to transfer, you can try other players such as rhapsody or jukebox. I have found that because of codec issues that jukebox is the best and i have always had good luck with it.
    Master:
  • 848 Answers
Load Windows Media Player.
Find the CD you want to put onto your MP3 player.
Select the "Copy from CD" tab in Windows Media Player.
Look at the list of tracks that Windows Media Player displays for you.
Select which tracks you want to convert to MP3 by ticking them.
Click "Copy Music."
Wait patiently for Windows Media Player to finish ripping your CD.
Connect your Archos MP3 player.
Click on the "Sync" tab.
Synchronize your device.
Posted on Aug 29, 2008
    Master:
  • 521 Answers
Right click the songs you required and save them to the play list.it will ask you where you want to save .it will give you the options.you can select it from the option.its simple.
pls do rate the solution
thanks.
regards.
fixya expert team
    President:
  • 1,952 Answers
Get try to new down load software
  • 6,487 Answers
Follow this steps:
Step1Turn on your Archos 104 MP3 player.
Step2Navigate to the "Music" menu.
Step3Press the right button on your MP3 player. That displays the contents of the play lists.
Step4Locate the songs that you want to add to your play list in the left-hand window.
Step5Use the "Up" and "Down" navigational keys to highlight the track you want.
Step6Press "Enter" to add that track to your new playlist.
Step7Continue doing this for each song that you want to add.
Step8Enter the menus and select "Save" to save this playlist to your device.
Hope that helps........
    Brigadier General:
  • 3,614 Answers
Be sure that you have already saved a list of song on your playlist. and for the pdf also make sure that there was a file that save on that location...
let me know
  • micromaster
    micromaster Aug 29, 2008
    ok, just let me know your email add. and i send a copy of the instruction right there...
    thank you
  • micromaster
    micromaster Sep 05, 2008
    create a .txt file
I want to have hebrew in my archos 504
Update your device at Archos official site/support/downloads/firmware and select your Archos model.
Dec 18, 2010 | Archos 504 500870 Digital Media Player
How can i put dvds on my 504
You can drag and drop dvd files (divx/avi+AAC codecs) into the video folder of the device, but in order to play the you must buy the Archos cinema plugin. Visit the Archos official page and search your model.
Nov 20, 2010 | Archos 504 500870 Digital Media Player
I am having archos 504..It only plays windows media player files if I want to plar other player files how can I do that?
get the best all round anything player KMPlayer. link below..
kmplayer.en.softonic.com/ - United States
Mar 05, 2010 | Archos 504 500870 Digital Media Player
I can't play video on my Archos 504
This problem seems to occur when the device overheats. It doesn't make a whole lot of sense, but most videos set at 720 by 480 wont play when the device is left running for a long period of time. The smaller video files, however, still play. I think it deals with the amount of system resources required for such files to play. If you turn the device off completely by going to menu, power, and turn off device, and leave it sit for 30 minutes, all files should play properly when you turn it back on.
As a suggestion, DO NOT leave your Archos powered on and on the dvr station. This causes the device to constantly run, and if you havent noticed the Archos operates at an extremely high temperature.
Also try the reset button just as a back up to what i have put. Karlos
Jul 04, 2009 | Archos 504 500870 Digital Media Player
My archos 504 will play for 2-3 mins then will freeze.
you have to format your hd. for this conect your dvd player to pc. there is coming your hdd with a letter disk . click with the right button mouse and give format. after formating make sure to put some video from media player as described in your manual. (videos must be codec compatible to play). if is repeated same thing check your audi and video setting if nothing.... good luck i dont know another solution.
Apr 05, 2009 | Archos 504 500870 Digital Media Player
Only showing in black and white
Problem fixed by going to 2nd menu group (left click the menu button) display>external display and selecting s-video (this is the cable I use)
Apr 21, 2008 | Archos 504 500870 Digital Media Player
Archdfios 605 wi
mine's just gone a similar way - made a playlist and saved it...all songs were playing ok up until then. When i went to play the playlist it told me that the file was corrupt then proceeded to tell me all 14000 songs were corrupt...just in the middle of an attempted repair!
Jan 27, 2008 | Archos 605 WiFi Digital Media Player
Can't get the dvr working
ARchos is macrovision compliant to prevent copying copyright programs. I think in some cases the recordings are encoded as such and will not play on your tv in those cases. I would fire off a letter to Archos technical support archos.com) and check with them on this.
Nov 20, 2007 | Archos 504 500870 Digital Media Player
Placing films onto the 504
I have put plenty of DVDs onto my Archos, but I use the optional cradle which connect to the TV as well as DVD players. You simply connect the DVD player onto it and play your dvd, which switching on the Recorder function on your unit.
Alternatively, can you convert the DVD onto your PC and then transfer onto the Archos in normal fashion, or is this what you are saying you tried to do already?
Sep 14, 2007 | Archos 504 500870 Digital Media Player
481 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
