2000 Toyota Camry Logo
Posted on Jul 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Both left windows have problems. Whenever the left driver window goes down, it stays down. When I try to pull the window back up (it won't go up on its own), it won't stay up. It starts coming down again. The back left window doesn't move at all.
  • Anonymous Mar 16, 2014
    back window goes down but won't go up
Anonymous
Level 2:
New Friend:
  • Expert 135 Answers
  • Posted on Jul 22, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
135
Questions
0
Helped
34472
Points
379
Check master switch,window motor-regulator
1helpful
I have a 1999 Pontiac Grand Prix gtp . The driver window goes down but won't come back up . None of the other windows does anything . What could be the problem ?
All four windows get power and ground thru the driver switch.
So I would start by checking the driver switch with a meter or test light.
Driver side auto window wont stay up
If the motor or track has something that causes a drag or interference, the motor will reverse as a safety feature.
The motor would not know if the drag was a faulty track or a child's arm.
You may have to pull the door panel and check the movement of the glass.
Windows won`t go up or down
Power windows usually use a circuit breaker (in the under dash fuse panel) rather than fuses or relays.
If no windows work, check for broken wires in the driver's door opening, going to the master switch on the driver's door. Or pull the master switch out and check for a hot wire there with key on. You can also check the ground there too for the windows. The ground for the windows will start at the master switch and go back inside the car, possibly grounding at the left kick panel.
2helpful
2answers
Problem with power windows
most likely the window regulators. these make sure the window is pulled and pushed evenly. if this is faulty or damaged then the window will be pulled at an angle. new regulator is probably the easiest option
1helpful
Window won't rool up
If it is electric then you may have to replace the window motor, if it is a hand crank window then just take off the door panel and put the belt that goes from the crank to the chases of the window back on track, someone probably kept rolling it after it was already down
Driver side window goes down but won't go up on
If your window goes down...your motor is good...I had the same problem in my Pontiac Bonneville..It ended being a bad switch...I changed it..end of problem....I hope this was helpful.....PEACE....
Passenger window for a 2003 Venture, won't roll up
If it is a power widow-pop the switch from the arm rest and then unplug it from the wiring-may need a screw driver the first time as the hold down clips may be snug. Make sure in ignition is off and then take two large paper clips and pull them open and bend to a U shape. Jumper one from the black wire to the dark brown wire and the other from the medium blue wire to the yellow wire. Turn on the igition and the window will go up. Works everytime on my 2004. I now leave it unplugged so it won't accidently get opened. Go to the wrecker and get another switch, if you can find a car that has one left in it.
Gary
Windows won't go up or down and interior lights stay on
You have two separate (and unrelated) electrical issues.
(1) windows - probably the fuse is blown - replace. If it keeps blowing fuses, then you have a
short somewhere in the wiring to the window operator motors or the switch to raise/lower
the windows (any soda/latte been spilled on one of the switches lately?, or perhaps a window
left open overnight in a rainstorm?).
(2) interior light staying on - almost always a stuck/corroded/worn door switch - play with all
four & you'll find which one has gone marginal (97% of the time its drivers door switch,
since the driver's door gets more usage than all the other doors put together).
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
