Question about Acer Aspire 7720 Notebook
Laptop keyboard replacement
Hey, i cant figure out how to replace my keyboard, i was wondering if the top panel with the power button pops off? or do I have to do something else? thanks
  • kumar007
    kumar007 Dec 01, 2011
    Acer help needed? Call them and give this service 05020774316 before December 23 (expiry date) for hardware issue only.......Kumar....let me know if you find this useful or anything else if they ask while customer service.
I had the same problem ... spilled a drink on my keyboard causing the keys to stick
1) Internet explorer browser always jumps to top of page even when trying to scroll page down
2) Windows explorer can't select any items except the top or upper most item or folder ... top item always stays selected
Fortunately, the keyboard is pretty easy to access. According to the service manual ...
1) Unplug the power cord from the wall and laptop
2) Remove the battery pack
3) Remove the lid covering the hard disk drive
4) Remove the hard disk drive and bracket assembly
5) Remove the 2 screws from the battery compartment
6) Unsnap the "Middle Cover" ... that's the small panel between the keyboard and LCD that has the power button located on it
7) The keyboard can now be gently lifted out
Download the User Manual ... SG_AS7720_7720G_BOOK.pdf ... click on the very small, almost hidden, looks like a legal disclaimer, link near the bottom of the page labeled, "Save file to your PC: click here" ...
Order a new keyboard ...
Part Name and Description
Acer Part No.
Google Shopping Search ...
Note: If you have a different model Acer laptop, here is a link to more service manuals ... ... you can find part numbers listed in those.
Posted on Feb 01, 2009
Advent t9307 power switch not working
Your laptop's power button sits directly on top of a device called a power button board. This is a small circuit board where all power and control buttons interface with your laptop's motherboard. The repetitive use of the power and control buttons can damage the power button board. Repairing your power button means removing and replacing the power button board, which requires partial disassembly of your laptop.
1.Power down your laptop. Unplug the AC power adapter and all external devices from the computer. Close the laptop's LCD panel and place the laptop face down. Rotate the laptop so the front opening edge is facing you. Remove the battery pack from its compartment on the laptop's bottom side.
2.Flip the laptop over, and pull open the display panel as far as possible. Use a thin, flat-head screwdriver to pry the keyboard cover from the laptop. The keyboard cover is the plastic piece situated above the keyboard assembly that houses the power button board.
3.Lift the keyboard cover out of the laptop slightly, and disconnect the cables extending from the power button board to the motherboard. Remove the keyboard cover from the laptop.
4.Place the keyboard cover face down on a flat surface. Remove the Phillips-head screws fastening the power button board to the cover, and remove it. If your speakers are situated inside the keyboard cover, disconnect the speaker cables from the power button board before removing it.
5.Place the new power button board inside the keyboard cover. Align the screw holes on the button board with the holes on the keyboard cover. Replace the Phillips-head screws fastening the button board to the keyboard cover. Reconnect the speaker cables to the button board, if necessary.
6.Reconnect the power button board's main cable to the motherboard. Place the keyboard cover back inside the slot above the keyboard assembly. Press down on the cover until it snaps into place. Replace the battery pack and reconnect all cables.
Sep 06, 2011 | Computers & Internet
After a technician changed the key board of my lap top he said is a problem now with the power button and the machine cant start, so he said he need a replace a power button because is something waste o...
most laptops power button has nothing to do or connection with its keyboard it is not on the same module. it could be that a technician may have accidentally break the power button when he is removing the keyboard panel of your laptop
May 27, 2011 | Computers & Internet
Need to replace the keyboard hwo to do it
usually above and below the keyboard there is a blank panel, those pop off to reveal tiny screws, once you remove the screws, slowly lift keyboard,there will be a cable to unplug.
Mar 19, 2010 | Acer Extensa 5420-5687 Notebook
How to replace the keyborad on Twinhead Durabook R15D
ther are 2-3 smaill projections also availabe at the full so fragile!
Nov 14, 2009 | Computers & Internet
How do I remove the keyboard on my acer aspire 5610 laptop to replace it
First you carefully, very carefully pop off the top plastic strip above the keyboard that has the power button on it. Once that is popped off you will see either 3 or 4 screws holding the top part of the keyboard, unscrew them and the top part of the keyboard will pop up. Be careful not to rip out the cable underneath, there will be a little snap holding in the cable you will have to release, then you are done.
Oct 29, 2009 | Acer Aspire 5610-4648 Notebook
Replacing Keyboard Sony VGN-N130G
Here is the pictures on how to remove the keyboard
May 20, 2008 | Computers & Internet
Medion MD41060 Memory Installation
Hey, as far as my knowledge is concerned, the battery compartment is on the backside of laptop and there is a symbol on that compartment. you just need a screw driver to open two screws and reach the RAM compartment.
Try that you will fixup your problem.
Feb 13, 2008 | Computers & Internet
Acer Aspire 7720 Notebook Logo
656 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
