Question about White Sewing Speedylock 1600 Mechanical Sewing Machine
Repair? the light comes on when I switch it on, but when I press the pedal, it won't go? What do I do? ThanK You
  • griffinsss3 Aug 29, 2008
Try cleaning the contacts on the foot pedal plug. That worked for me.
Posted on Aug 17, 2009
Foot control on my Juki 2010 sewing machine is not working, as if there's no power reaching it at all. There is power to my machine as indicated by light coming on when main power switch turned on.
Pam, Could be a bad/broken wire, may be repairable, you should take your pedal in to be tested, if diagnosed to be bad you may have to order a new replacement pedal. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Repair the Foot Control on Your Sewing Machine
http://www.sewingmachinesplus.com/foot-control-419451-003.php?gdftrk=gdfV210602_a_7c3285_a_7c15319_a_7cPID513
Sewing Parts Online Search
Juki Sewing Machines
Jun 09, 2016 | Juki Sewing Machines
Foot pedal will not active machine
make sure it's plugged in tightly to machine. Make sure light is on . OH, does the light come on? If the light comes on., it will indicate that you are getting power to the machine
Jun 30, 2015 | Sewing Machines
Janome j3-20 suddenly stopped working
I would suggest taking the machine in to be checked
Jun 07, 2012 | Janome Sewing Machines
Sewing machine does not sew. Finished sewing something, turned it off, then turned it on a few hours later and it will not work. Light is on but nothing happens when the foot pedal is pressed. Took apart...
Call Singer at 1-800-4singer and ask for their advice, you do not want to void your warranty with not going to an authorized repair service if it comes to that. Good luck
Oct 07, 2010 | Singer 5050 Mechanical Sewing Machine
The pedal won't sew when pressed but I can sew using the crank on the side. It doesn't make any sounds at all when pressed and the light still works. Is it a problem with the motor or the pedal? Can I fix...
Check the pins on the machine to make sure none have been pressed in, check the lead for any splits, failing that you need to check inside the foot control in case a wire has come off, make sure it is all switched off first
Jun 17, 2010 | Sewing Machines
My unit has no power to foot pedal. What are possible fixes?
change the power chord of your pedal, if not, open the pedal and look for the connection if that is cut or loose try to tight or connect it.
Oct 17, 2008 | Brother LS-2125 Mechanical Sewing Machine
White Sewing Speedylock 1600 Mechanical Sewing Machine Logo
89 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
