Question about HP OfficeJet 6110 All-In-One InkJet Printer
DOCUMENT PRINTING Cannot get document to print from computer. Fax and copying feature are good. Should there be some communications area I should be checking?
  • Anonymous Sep 02, 2008
    printing from the computer to the printer doesnt dwork
    Problem Solver:
  • 9 Answers
This problem can be that the printer port is not properly configured .As well could be the printer's driver is inoperative.
Posted on Aug 31, 2008
    Master:
    Sergeant:
  • 398 Answers
Uninstall it from your computer, then reinstall it with your cd or if you don't have this, go to the manufacturer's web site and download what you need.
Posted on Aug 29, 2008
I have an HP Officejet 6500A plus. Sometimes when I attempt to print a document, instead of printing, the Send Fax window opens. What causes this and how can I fix it?
This is the PC fax facility, unless until you entered the fax number job wont go any ware,,.PC fax facility is very good feature that with out document you can type and send the faxes through this facility as well as your files..Better to rename the drivers as "fax" to avoid confusion...
Dec 23, 2011 | Office Equipment & Supplies
What button to press to copy a document ?
If you are putting a document into the printer and want to make a copy of it, press the key that says "copy" on the printers keyboard. Then choose the number of copies you want to make and press the "ok" or "enter" key on the keyboard of the printer.
If the document you wish to make a copy of is located in your computer and you dont have a copy of it to place in your printer - then you need to print the document. Not copy the document. Copy means make another one. You can't copy something that you dont have in your hands. Understand? To print a document that you dont have in your hands, find it on your computer. When you find the document you want to print on the computer, click on "file" in the upper left side corner of your computer screen and slide down to "print" and click on it. Then click on "ok" on the next screen to start printing your document.
If there is no "file" command in the upper left corner of your computer screen when you have the document that you want to print open on the computer - try right clicking with the button on the right side of your mouse in the center of the document and find the "print" command on the drop down list and click on it. Then click on "ok" on the next screen and this will start the printing of your document.
Hope this helps? Good luck!
Jul 07, 2011 | Office Equipment & Supplies
How to recover fax in memory
Your fax can print a list of documents stored in memory, along with the transaction number (TX/RX NO.) of each document. Once you know the transaction number of a document in memory, you can print it or delete it.
1 Press [Menu].
2 Use [up] or [down] to select , then press [Start/Copy].
3 Use [up] or [down] to select , then press [Start/Copy].
? Printing a Document in Memory
1 Press [Menu].
4 Use [up] or [down] to select the transaction number (TX/RX NO.) of the document you want to print, then press [Start/Copy]. The LCD toggles between and .
If you are unsure of the transaction number (TX/RX NO.), print a list of documents in memory (see page 34).
5 Press [*] to print the first page only, or press [#] to print all pages of the document.
The fax prints the document.
Jan 18, 2011 | Canon FAX-JX200
Can i make copies witht he brother hp 2040 printer
A printer would produce print outs of documents in versions known as hardcopies(paper). However, multifucntion devices usually would have an area on the printer that allows to feed in an aready printered document to be reproduced several times into several hardcopies(paper copies). Unless that, the printer has multifunction capabilities, in which instance would be in writing specified as capable of performing printing, copying and several feature functions, it would be unlikely to perform copies from an already existing document.
Jan 11, 2011 | Brother HL 2140 Laser Printer
Pages are printing, but part of the page has really light, some unreadable printing while rest of page is fine. What do I need to do/change?
If the colors on printed and copied documents are too light, blurry or not as bright as expected follow the steps listed below:
1. Verify the toner save mode is turned Off. When you set the toner save feature to On, print appears lighter.
a. Press Menu, 1 (General Setup), 6 (Ecology), 1 (Toner Save).
b. Press the up or down arrow key to select OFF and then press OK.
c. Press Stop/Exit.
2. Print a document from your computer or print a demo page by pressingthe FAX and COPY keys at the same time.
Oct 26, 2010 | Brother MFC-9840CDW Laser Printer
Multiple printing
go to the main menu and go to the printing settings.adjust it to single printing...
May 20, 2010 | Panasonic KX-FM131 Fax
I CAN`T SEND A FAX
Fax machines are sorta like printers, sorta like scanners, and sorta like dial up modems all wrapped into one expensive box.
1. First thing to make sure of is that you are hooked to a phone line. most fax machines have a phone handset that you can make calls from. Call someone and make sure that works. If So, you are able to connect to phone networks, and should have no trouble sending or receiving data. If you have a dead line or no sound, check the line and check the power. (its always the easy stuff that is overlooked, just check it and make sure).
2. If this fax machine has computer interface, (usb port or parallel cable port), see if you can scan with it. Drop a document into the scan area and see if the computer can scan an image from the scanner. If the scanner works, you can scan images into the fax machine to be sent to the fax number. (If your fax machine does not have a scan to computer feature, skip this.)
3. if your fax machine has a print from pc feature, try to print a document to it from your computer. If you can print, then the printer works, and you can receive faxes. (if your fax machine does not have a pc printing feature, skip this)
4. Here is how a typical fax machine works. You place the document or image into the scanner feed area. You press a big button that usually says "fax" and then, a screen pops up saying to dial the number. You dial the number and press SEND. once you press Send, the machine will scan the document, dial the number and sing a little dial up modem song awaiting a response from the receiving machine. the receiving machine acknowledges the fax, and the singing is no longer audible (but it continues because the modem song is actually data transmission/reception). after about 20-60 seconds, the fax completes and the call ends. As for the particular model you have, the functions should be about the same, though the buttons and arrangements may be different. FYI, you can send a fax straight from the PC too, if you have a dial-up fax/modem card.
Jul 03, 2009 | Brother Multi-Function Center MFC-665CW...
Ricoh Aficio 2015
Does your machine have a document feeder on it? If so, turn off and unplug the machine from the wall, and check in back of the machine to see if the feeder is plugged into the unit properly. Try reseating the document feeder plug to ensure good contact. Plug the machine back into the wall and turn it on. If it detects the document feeder, fax and scan functions should be restored.
Jun 16, 2008 | Ricoh Aficio 2015 Copier
Canon jx200 fax machine
The fax automatically turns off Auto Print and stores faxes in memory when either ink or paper is low. The memory will store up to 30 transmissions or 60 pages maximum, so it is important not to leave this too long if you have heavy transmission volume.
Faxes can be retrieved as follows.
If you want to choose only certain faxes to print:
1. Print a list of documents in memory for reference:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Doc Memory List, and again press Start/Copy.
2. Print a document from memory (using the list printed in #1):
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print Document, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to print, and press Start/Copy. The LCD will then toggle between "1st page only?" and "Yes=(*) No=(#)". Press * to print only the first page, or # to print all pages.
3. Delete selected document(s) from memory:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Doc, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to delete, and press Start/Copy. [Note - if the arrows do not result in another number displaying, there is only one document in memory.] The LCD will show "Yes=(*) No=(#)". Press * to delete the document. Continue to select documents until each document you want to delete has been handled.
If you want to print all unprinted documents in memory:
1. If you want to have a list of documents in memory for reference before performing this procedure, to be sure you have them all, follow step 1 from the above procedure for printing selected documents.]
2. Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print All New RX, and again press Start/Copy.
3. Delete all printed docs from memory:
Immediately after printing all documents, you will have the choice of deleting all documents. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory.
To delete all documents at a later time:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Printed RX, and again press Start/Copy. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory. To finish then, press Stop.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 06, 2008 | Canon FAX-JX200
HP OfficeJet 6110 All-In-One InkJet Printer Logo
21 people viewed this question
Ben Johnson
