I have 2000 mercedes benz c 230 power windos and sun roof there are not working i have checked power and ground to the pwer windo switch are ok i want to know is it a comen problem is there a madual or a realy some where or a fuse that i have not cheked thank you
    Scholar:
  • 113 Answers
May I suggest that you post this in the correct area of the website and not under PC problems :-)
Posted on Aug 29, 2008
1998 slk 230 can the boots central locking alignment interfere with the operation of the roof closing
your windows move first , check fuses and clean your window may be sticking due to dirt.
Jan 20, 2015 | 1998-2004 MERCEDES SLK230 SLK 230 CARBON...
Brake lights will not work
Check that you have power to the rear of vehicle and check to see if you have power at that brake light switch. If you do then you might check all your grounds.
Jan 12, 2015 | Bosch 2000 00 Mercedes Benz E320...
What to check when a SLK 230 1999 Convertible top will not open?
dont know much about convertible mercs but there should be a relay which would send power to the motors if this has blown the lid would not lower or fuse or the terminals in the switch its self are still wet
Sep 08, 2014 | Mercedes slk 230 kompressor fuse. lock. ....
Radio want power on
either the fuse in the fuse box which if memory serves should run sun roof or cigaret lighter if fuse there is ok there is usually another inline one behind radio which means removing radio if this is ok radio goosed
Nov 11, 2013 | 2006 Mercedes-Benz Mercedes Benz CLS500
2000 s430 battery was drained flat, after recharge battery, everythings work fine except sun roof won't operate, does it require reprogram ? how ?
To the best of my knowledge it should not need to, consulting your dealer or a call to a local Mercedes repair shop would give you the best answer. I would say co-incidence that switch went bad at same time of dead battery
Oct 01, 2010 | 2000 Mercedes-Benz S-Class
Why dont my lights work in my 2000 mecedes s 500
You most likely have another fuse box either in the glove box or under the dasy. It sounds like a blown fuse.
Jul 08, 2009 | 2004 Mercedes-Benz Mercedes Benz S Class
Can't open a 2002 Mercedes c230 kompressor sun roof
It's typically the motors or the special drive tubes that it uses. If you here a clicking noise then the sunroof became to tight and ruined the motor gears. You can actually switch the two motors, one is for the shades and needs less power then the other motor. They are identical, switch them. Nex make sure they are very tight to the 3 mounting bolts, there is a rubber washer bushing that wears out and alloys the motor to flex too much, causing the gear mis-alignment and gear grinding. This works great I do it all the time.
Apr 11, 2009 | 2002 Mercedes-Benz C-Class
Where is the fuse for the power windows on my 2000 Dodge Durango?
i pretty shore they do not have a power relay .see fi you have power to your windo switch . if you do and your windo still duse not work then its your switch ok have a great day
Mar 29, 2009 | 2000 Dodge Durango
Power Windows and Sun Roof no function
A class merc,sunroof slightly opens then stops, semi auto clutch wont gear down into 3rd gear, can any one tell me what the problem could be???
Steve
Mar 16, 2009 | 1999 Mercedes-Benz E-Class
2000 MERCEDES SLK ELECTRIC ROOF PROBLEM
hi,seem only adjustment of micro switch,to detect which switch are need to adj.you need to send to dealer.
Jan 18, 2009 | 1999 Mercedes-Benz SLK
Computers & Internet Logo
David Payne
David Payne
