Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Same Phillips problem
We too have a philips Television Model Number 43PP920217.  The converge has been fixed once already, and it is 2.5 years later and the same part has gone again.  Last time i paid to have someone fix it.  It cost me nearly 300.00.  The parts cost me 120.00.  When they went the last time, I looked the part cost up on line and found out they as in both, cost each.  $10.00.  How difficult is this to fix our self?  Is there a manual or spec that we could follow to do this?
What do you think?
  • 4,234 Answers
IF you can solder, you should be able to repair this yourself. Can you piost the parts that were replaced, I may have a substitute that will last longer. Also, I'd like to verify that all of the parts that should have been replaced actually were.
Thanks,
Dan
Posted on Aug 29, 2008
Can I have the part # for convergence ICs for Phillips TV Model 51pp9200D/37?
IC convergence number: STK392-120 or STK 392-150 Will work correctly. Any question, please let me know.
Aug 04, 2011 | Philips 51PP9200D Television
How can I find a "convergence circuit" for my 8 year old 60 in Phillips projection TV? Could I install it myself or would I need to hire an expert to do the work?
There are no a whole DLP tv model Philip convergence board out there to buy.U only can buy a convergence kit,came in parts like 2 STK convergence ICS and some or all of it resistors parts for sale.Hire a shop to fix ur DLP tv convergence board.They'll charge u like $300-350 for parts and labors.
Nov 09, 2010 | Philips 60PP9202 60" Rear Projection...
Having i think convegence board problems with my phillips model # 60pp9202/17F called tv repair guy said it was my convergence ..colors are alll orange and bottom of picture kinda bubbles up can i replace...
Replacing the convergence board will require a complete convergence adjustment. A better solution would be the replacing of the defective convergence IC. This would retain the convergence settings for the set. I'll locate the part numbers and costs and update this later.
Dan
Aug 31, 2010 | Philips 60PP9202 60" Rear Projection...
Phillips convergence proplem . red arrow will not align. bowed picture at bottom and double lettering everywhere
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I had was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video,red video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
ML
Aug 05, 2009 | Philips 55PP9401 55" Rear Projection...
Red&Blue covergence cant get them to macth up
heres a link to the repair kit for your model which will repair the convergence. The kit contains the parts and step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Mar 27, 2009 | Philips Magnavox 51MP392H Rear Projection...
PHILIPS 43PP920217 DPTV305 PROJECTION SET
those are 6.8 ohm 1watt metal film resistors 5% tolerance
Jul 22, 2008 | Philips 43PP9202 43" Rear Projection...
42 in. Phillips, model #43pp920217
Yes...Change them both.....use first quality only ...I use the best
and it is an upgrade....STK392-110 sub to STK394-160E = part
# CZ 01341 ( Hitachi made by Sanyo) cost about 30.00 ea.
Be sure to verify your part # before ordering any parts.....
Also,check B+ resistors for damage....located next to IC's......T.
Jan 03, 2008 | Philips 43PP9202 43" Rear Projection...
Convergance adjustment
convergance amp ic bad
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 15, 2007 | Philips Magnavox 9P6034C 60" Rear...
PHILIPS 43PP920217
Either a convergence problem where the 2 stk's need changing and resistors in that area, or the vertical Ic is damaged and needs replaced.
Aug 04, 2007 | Philips 43PP9202 43" Rear Projection...
Help tv comes on and goes right back off
A common problem with this model is the convergence IC's on the small signal module going bad and keeping the set from staying on due to protective shutdown circuits used. If that is your problem, the easiest fix would be to replace the module - Philips Part #313503710091, about $200 or so, or have a technican replace both IC's Stk392-120, Philips Part #932212344682 about $45.00 each plus labor and service charge of course. Other parts could be bad, but this is likely what I would try first.
Feb 09, 2007 | Philips 43PP9202 43" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
85 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
