Question about Samsung ML 2010 Laser Printer
Loud whine/buzz/wail, nothing prints
I was about 30 sheets into a new toner cartridge. The first pages printed fine. But on the last printed sheet, a few words were grayed on separated lines. It wasn't a blotchy effect, but very neat--in fact at first I thought I'd changed the colors of those words from black to gray by accident.
Nothing has printed since. You know how when you turn the printer on it's silent for a while, then makes a rotating sound as part of its warmup? Well, during the rotating sound part it now makes a loud complaining whine/buzz/wail, then stops doing anything and the red light turns on. Sometimes there are a couple of cracking noises before the wail, like something's coming free and hitting something else inside.
After reading some of the other posts I'm going to try taking as much apart as I can and looking for mini-jams. Any other ideas?
  • 1 more comment
  • Anonymous Sep 02, 2008
    I have recently changed the cartridge and now the printer has ceased to work. It begins OK but seems to have difficulty getting the paper to go through, and stops half way, I then remove the paper and take out the cartridge, there are never any other paper jams, I replace the cartridge and it may then print one page before the same problem occurs. Any suggestions ?
  • hitchbend Sep 03, 2008
    After what you said about the leader, I went home and had
    a look, shining a flashlight through the front opening. There’s a square (in cross-section) metal bar
    going across from left to right under the toner cartridge, which passes through
    a small rubber roller around the center of the printer. I assume this is the leader you
    mentioned. On the left hand side of the
    printer the bar goes into a white gear, only some of which is visible at any
    given rotation angle.
    I experimented with putting the printer through a few
    warmup cycles, while I watched. (Maybe
    it wasn’t the smart thing to do, but that’s what I did.) Each time, after a short wait, the bar
    rotates a few degrees, while making that knocking/cracking sound two or three
    times, then stops turning. While this
    happens, the toner cartridge vibrates and jumps around. I can tell by feeling that the vibration is
    strongest on the left hand (gear) side of the printer. When the bar stops rotating, the knocking
    stops, the toner cartridge stops vibrating, but the wail/hum continues.
    I put the printer through several of these cycles, so
    that I could get the gear to make a full rotation, so I could check it for
    damage. (I forgot that I’d had the cover
    off before, and could see there was no damage.)
    Each time the same thing happened.
    Does that information help?
  • summersover Sep 09, 2008
    I have exactly the same problem as hitchbend. When it warms up I hear a couple thwacks and you can see the toner cartridge jump around like it wants to get out. Nobody has any solutions? Is there a better website to check, where the people know more?
  • 293 Answers
Well your leader (lead head) could be jammed or off of its track. The leader should sit on a steel/aluminum rod and it should run under the front of the cartridge. If its gearings are out of sink you can get the cracking sounds you're describing and the whining probably the motor that powers the leader having no resistance and going way too fast for what it is supposed to do. I'd look for a broken sprocket or gear.
Posted on Sep 01, 2008
My printer will not print correctly.
First thing I would do is take the toner cartridge out and shake it left and right a bit. Hit it 'firmly' on the side with your hand, then put it back. Your manual will probably describe the same procedure. That usually loosens up enough toner powder to print another 20 or 30 sheets. How long have you had that particular toner cartridge? Would you have done a lot of printing using that one? Sounds nearly empty to me. As a test, does anything print normally? I mean write some random stuff in notepad like about twenty lines (just hold a key down on the keyboard) and then try to print from notepad. Does that print normally? If so, the problems likely to be with your application on your PC. Obviously you have restarted both the printer and the PC? As a last resort, you might have to download a newer printer driver, but that's another story. Rgds, Dave.
Mar 04, 2014 | HP DeskJet 3930 InkJet Printer
Duplex feed not working
Check the C6200 Device Settings in the properties and make sure that the Duplex Unit is installed.
Dec 09, 2013 | Brother HL 5250DN Laser Printer
Price of cartridge of samsung ML-1640 mono laser printer
Rs. 2800/- original carteige
Rs. 1200/- compitable cartridge
Nov 09, 2009 | Samsung Laser Multifunction Printer Toner...
The Phaser 7400 starts at $2,799. see models and prices see cost per print Color: up to 36 ppm Black: up to 40 ppm First-page-out time as fast as 12 seconds 800 MHz PowerPC processor Maximum paper size: 12" x 18" All models come standard with 10/100Base-TX Ethernet connectivity Standard paper input capacity: 800 sheets Maximum paper input capacity: 3,000 sheets Finisher/stacker/stapler/hole puncher capable of handling up to 1,000 sheets Maximum duty cycle up to 150,000 pages per month What comes in the box show/hide contents Color toner cartridges (capacity: 9,000 pages each 1 ) Black toner cartridge (capacity: 15,000 pages 1 ) Imaging units (capacity: 30,000 pages per color 2 ) Waste cartridge (capacity: 30,000 pages 2 ) Fuser (capacity: 100,000 pages 2 ) Transfer unit (capacity: 100,000 pages 2 ) Finisher ships with 5,000 staples Power cord Software and documentation.
Aug 13, 2009 | Xerox Phaser 7400/N Printer
Streaking problem on print out
You have a bad drum cleaning blade. There is no way to replace it without buying a new toner cartridge.
Jan 06, 2009 | HP LaserJet 4700 Printer
Older Xerox 5334 printing on 1/2 page on every other sheet.
It is 99% of the time the print cartridge. If it is every other sheet on A4 then it is this.
Dec 31, 2008 | Ricoh Aficio 450 Copier
Xerox 6250dp
I had this problem when I used a generic toner. I installed a xerox cyan toner, then printed many sheets of a large blue rectangle. After about 15 pages the blue started to spread into the shape, after 30 pages the blue was back. Printing a lot of blue was necessary to get the new toner thru the system.
May 29, 2008 | Xerox Phaser 6250 Laser Printer
Blank trace appears on printed copy
replace the toner cartridge, this is a case of low toner.
NOTE: you should never clean the drum on the toner cartridge it is sensitive to light and touch.
Jan 07, 2008 | HP LaserJet 1020 Printer
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Samsung ML 2010 Laser Printer Logo
289 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
