Question about Samsung Digimax 360 Digital Camera
Samsung Digimax 360 - Flash Problems
Is there a way to disable the flash on this camera without switching the camera mode? I mean, it would be kinda awkward for a camera to not have such a simple option. I hope there is a solution for that. Thanks.
    Master:
  • 542 Answers
There is no special button for flash control. It is controlled with a menu. Page 36 of the Users Manual. If you don't have a manual, you can download one here: http://www.samsungcamera.com/html2/support/html_support_manual_camera.asp?div_did=STW110&action_fg=pro_division&men_tree=G72&dom_did=STW200&dom_domain=&lang_fg=ENG&pro_pid=&prb_pid=&pro_hnm=
Posted on Sep 08, 2005
SOURCE:
My Samsung S630 Digital Camera doesn't flash after a series of picture taking. Now it fails to flash although I set in Manual mode and selected Flash manuall, but still t doesn't flash. What should I do?...
Hi there remove the memory card and reset the camera. Now turn on the camera with out the memory card and make the camera flash light ON mode and take a snap. If the flash not working after this setting, then you need to replace the flash tube. The flash tube is cut off and thats why its not working.
Feb 19, 2011 | Samsung Digimax S630 Digital Camera
How to take flash off samsung digimax s800
you can change the flash setting by clicking left button..you have a choices there if red eye fix,noflash,autoflash. you need to select the no flash.but more auto mode for you to get convenient than to select the flash into off.
Feb 14, 2011 | Samsung Digimax S800 Digital Camera
My camera was dropped and since then it won't take pictures using the flash. The screen keeps saying "F 2.8 1/45" while the flash is charging, but never takes a picture. The camera takes pictures fine...
This means the flash or flash circuitry broke due to the drop. The camera will take pictures as long as the flash is not required. Only resolution is to have the camera repaired, which unfortunately may cost more than the camera is worth.
Apr 26, 2010 | Samsung Digimax S630 Digital Camera
My S630 Samsung shows a code on the screen evry time I try to take a picture. The code is F2.8 1/45 and the little eye on the left that indicates the flash blinks for a few seconds.
your carera is set on shutter priority,,,
change it to auto
what its telling you is,, its set at a lens opening of F2.8 ( thats wide open ,,,so little or no depth of field in photos) ,(and a shutter speed of 1.45 of a second?) witch means its realy dark were you are??
the little eye flashing tells you to use the flash,,,
i bet you have left it set on flash photos only?
switch it over to auto mode and out of flash mode!
Oct 28, 2009 | Samsung Digimax S630 Digital Camera
Hello. My daughter has had her samsung S73 for 3
The eye flashing is normal when the flash is trying to charge up , if the batteries are healthy the camera won`t take a picture until the flash is charged fully.Try turning the flash off and see if the camera fires, get some higher rated rechargeable batteries (2000mah) or above this may resolve your problem.
Aug 02, 2009 | Samsung Digimax S730 Digital Camera
Camera flash
No worries, I think I can help you with this one.
I believe that if you are using your Samsung Digimax in either "Auto" or "M" mode you will only have the options of "red eye flash" or "no flash". BUT HOWEVER, if you select the "Prog" mode on the dial on top of the camera, you will have 4 flash options - "red eye flash", "auto flash", "slow flash" or "no flash".
I hope that this helps!
Oct 02, 2008 | Samsung Digimax S600 Digital Camera
Flash troubles- timing off or something?
this problem is fixable. set the camera under the fill-in flash mode. do the ff:
-click the flash button, (right button that has broken arrow on it)
-click it for many times until you see the icon of a big crooked arrow without something with it on the screen, that means your camera is nder the fill in flash.
when set under this mode, the flash will work in any instance you're in. because under the red eye function, flash is usually turned off.
Dec 23, 2007 | Samsung Digimax S500 Digital Camera
Flash problems
I assume you mean when ever you switch the flash off. This is because there is not enough light for the particular setting the camera is on and the images are blurred because of the long exposure is causing camera shake. Check the menu and see in you can select a higher ISO figure- Say 400
Jun 01, 2007 | Samsung Digimax U-CA 5 Digital Camera
The flash isn't working
might be obvious, but try replacing the batteries. also during continuous shot mode, flash will be automatically set to off. otherwise contact samsung for repair estimate. Good luck
Mar 13, 2006 | Samsung Digimax A6 Digital Camera
Samsung Digimax 360 Digital Camera Logo
50 people viewed this question
Top Samsung Cameras Experts
Jerry Z
Andy Bale
Andy Bale
Are you a Samsung Camera Expert? Answer questions, earn points and help others
