Question about Sharp 56DR650 56" Rear Projection HDTV
Sharp 56DR650 shows power but wont turn on, Sometimes it turns on
Hi all
I just changed the bulb about 2 weeks ago and now I the TV shoots some codes at me, Power: 3 green blinking lights and 2 reds. Lamp: green light but goes to red i think.
I pulled out the lamp to see if its ok and looked perfect.
For some reason the TV will turn on sometimes... so weird.
Whats the issue here? Thanks in advance!
That's error code 32. Indicates lamp trouble or failure. The system will shut down automatically.
Posted on Sep 07, 2008
Hi, About 3-4 weeks ago I replaced the bulb on my
I am having the same problem as mg2low. I changed the lamp, but my Sony KF60WE610 still will not turn on. It flashes green several times then it begins to flash red. Can you recommend some trouble-shooting for me? Thanks, Richard
Sep 05, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Need a lamp bulb for Sharp 65 inch tv
You could buy it from :-
http://www.purelandsupply.com/56DR650-Bulb-Sharp-TV-Replacement-Bulb.html
Good Luck!!
Thanks!!
Aug 17, 2010 | Sharp 56DR650 56" Rear Projection HDTV
My Sharp 56DR650 LED Blinking
Check the number of time it blinks. that is the error code and compare it with the problem listed in the owners manual. see www.fixurtvs.com. The code 32 means the color wheeel is getting stuck. You can try to clean it and put it back or look for a replacement. Repairs should cost you 350 to 450 at shop and 150-250 at home subject to the availability of parts. Cleaning it just a stop gap measure and not a lasting solution. dont worry if the wheel opens up into two with black dust inside. Just clean it put a drop of light machine oil like sewing machine and put it back. there will be hum but the wheel works for months and maybe a year. it varies from tv to tv and quality of your workmanship.
Jan 24, 2010 | Sharp 56DR650 56" Rear Projection HDTV
Sharp 56DR650 won't turn on
the 32 message indicates lamp issues. Buy a new lamp with new cage and that should fix the problem.
May 30, 2009 | Sharp 56DR650 Television
56" sharp 56dr650 rear projection tv
Hi - wanted to let you know that I have the same problem and I contacted Sharp (800) 237-4277. They offered me a prorated exchange. Select #1 prompt for Operations and then they will create a case number if you don't already have one and then send you over to the Disbatch Dept. They are picking up my 56" TV and are selling me a LC52"D65U for under $450 current retail value of the new TV $1900. Give them a call and see if they can work out a deal for you too. The whole transaction will take 7 - 10 days. Good Luck!
Dec 10, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Sharp TV Flashing Codes
did you purchase just a new bulb? or did you buy the bulb with the cage included?
Oct 21, 2008 | Sharp 56DR650 Television
Sharp 56dr650 Won't turn on, error code>
remove color wheel,seperate from bracket open and lube and clean motor will work fine
Jul 16, 2008 | Sharp 56DR650 Television
My TV loudly hums when I turn it on
Ok, I just picked one of these babies up this past weekend. It was cheap, so I didn't bother with the research once i saw that it powered on and seemed to work.
It was sold very cheap because it was throwing codes, which the previous owner was told was a cooling fan. Due to my computer hardware experience, I decided to trace what the problem was. The 2 accessible fans were working flawlessly and silently, the 3rd fan (going to the input components) was stopped due to dust bunnies. A can of air and a complete cleanout solved all issues with the cooling fan codes. The loud annoying hum is the motor that turns the color wheel. Since I had everything out of the TV anyway, I decided to trace the sound which is actually behind the color wheel and sounds more like a bearing or mis-balance in the spinning motor. The color wheel itself is in perfect condition.
In the meantime....annoying hums are fixed simply by turning the volume on your tv or sound system up - it's barely noticable during normal operation and is only really annoying when initally turning it on.
Hope this helps someone.
May 06, 2007 | Sharp 56DR650 56" Rear Projection HDTV
Sharp 56DR650 56" Rear Projection HDTV Logo
242 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
