Question about Brother MFC-5840CN All-In-One InkJet Printer
Printer Jam - when i put a sheet of Avery labels, printer jams
Hope that someone can help me with this problem. I have previously been able to print standard avery labels by putting a sheet in the top paper tray. Lately when I put a sheet of labels in and send a job to print, it will jam, and show a message saying open back cover. When I do, I can see that the labels have stopped feeding (printer jam but not scrunched up), and label sheet is just sitting there half way through. When I take it out, and close the back cover, it doesn't re-set the message. I have to turn printer off and on again to be able to clear the message. This only happens with labels. Printing on paper is fine. Any ideas where to start?
I had the same problem and was able to get around it by changing my paper setting within the Printer Properties page from "Plain Paper" to "Inkjet Paper."  Hope this helps!
Posted on Feb 12, 2009
Thanks for your response.  I was referring to the top paper tray.  The printer used to take labels, but has only just recently stopped.
Posted on Sep 03, 2008
    Novelist:
  • 158 Answers
When you say TOP TRAY, do you mean a paper drawer, or the BYPASS TRAY? If the labels won't feed into the bypass but bond paper does, check to see if your labels are made for inkjet printers. Go to www.avery.com and contact Avery customer support to see what product they recommend for your MFC. Labels made for plain paper printers sometimes do not work for inkjets, and vice-a-versa.
Posted on Sep 02, 2008
When printing labels (Avery 5160) the labels start being shredded half way through and then the printer jams.
Have you setted up in the printer driver to print on label? the printer will automatically adjust the internal parts for printing on a higher density paper!
If you done it gently remove the Duplexer unit from the behind of the printer and chech for pieces of paper or everything could cause the paper jam!
Hope you found it useful, for futher questions i'm here :)
Dec 07, 2015 | HP Officejet Pro 8610 Inkjet Multifunction...
How to print only one sheet at a time not all sheets
This can be a little tricky. If you haven't used any of the labels yet, simply put the address in the first label and simply print. The printer will print the address on the first label and all you have to do is remove it and put it in place. Next time you need to make another label, set up the program that you are going to use to print the label and once the "Avery 8168 Inkjet" label is on your screen just move the cursor to the second label (With Corel WordPerfect just hold the ctrl key and hit the Enter key) and print your return label. Using this procedure you can use one sheet of labels without having to print all labels at once or using a new sheet.
Oct 15, 2014 | Avery 8168 Inkjet Labels Shipping...
Why does hp officejet Pro 8600 crashes when printing avery labels?
Avery labels may be blocked on your computer so check your security settings. Other wise you may need to refresh the page, your computer or the printer. If that doesn't help you may need to double check your ink cartridges are full and correctly placed, also that the wires connecting the printer to your computer are all in properly.
Mar 01, 2014 | HP OfficeJet Pro K8600 Printer
When I go to print Avery labels 5160 i get the error code load ssf 024-0969. I can print all other documents
Hi, Brad;
the label with the adhesive on the back when it go through the heating unit it goint melt will coming off and stick on paper path it cause paper jam, sugest print label use inkjet printer.
Oct 31, 2013 | Dell 2155cn and 2155cdn Color Laser...
I got a Paper Jam message while trying to print on Avery business card paper. Pulled back the jammed paper by reaching into the tray. Tried printing again, Jammed again. Removed the Jam Clear Cover in...
First off, NEVER EVER turn a componant upside down and shake it. Second, open the printer up and search for any additional paper. A lot of time a paper jam isn't just one sheet, especially if you have a faster printer. I would also try using some rubber rejuvinator on the printer so that it picks the paper up better so it goes through the printing cycle better.
Jul 17, 2009 | Brother MFC 210C All-In-One InkJet Printer
Paper jam in hp deskjet 5900 series. how do i correct?
 Follow these steps to remove a paper jam:
1. Press the Resume button.
  If the paper jam does not clear, then go to the next step.
2. Turn off the printer.
3. Remove the rear access door. Press the handle to the right, and then pull out the door.
4. Remove any paper that is inside the printer by pulling it out from the back of the printer.
  If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
5. Replace the rear access door securely.
6. If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover. Caution Remove the paper jam carefully as it is possible to damage the
  printer when removing paper from the front.
7. Turn on the printer, and then press the Resume button.
8. Reprint the document. Note If paper jams occur frequently, try using a heavier paper. See the reference guide for paper weight specifications.
Jan 29, 2009 | Office Equipment & Supplies
Paper Jam
You may have left some debris in the printer, or there could be a piece of debris blocking one of the sensors. Try to reinspect printer and clean it out throuroughly. If it still isn't printing, try removing toner and replacing again. If neither of those work buy a used laser printer on craigslist and save yourself the trouble.
sorry if this isn't great news. service may be worth it, try a small computer store rather than a larger store.
Dec 09, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP PSC 2355 All in One When printing Avery address labels, the clear sickum attached itself to the inside of the printer. The sheet was printed correctly on the proper side directly on the paper after...
I tried to remove the tape from one of the rollers which was the only evidence of tape remaining but could not. There was no evidence of a paper jam but still the air message appeared that there was one.
I have recently paid $109 for advice about the printer which still was not working properly. I went to Costco and bought a Cannon printer. I intend to get one at a later date that prints on both sides but it wont be an HP.
May 30, 2008 | Office Equipment & Supplies
Making labels
there are software templates on the avery website. Maybe you can find the specific product you bought on the website and download a template that will help you print labels.
Mar 21, 2008 | Lexmark Z1300 InkJet Photo Printer
Postcards causing printer jam
I think the card is too heavy or too thick for the machine as when it prints it has to turn the paper. If the card is too rigid it is unable to bend causing a paper jam. Suggestion is to try a less grade of card.
Thanks J
Dec 15, 2007 | HP DeskJet 5650 InkJet Printer
Brother MFC-5840CN All-In-One InkJet Printer Logo
831 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
