Question about Pioneer PRO-610 58" Rear Projection Television
No picture no Sound with power still on
In the past several months occationally the picture and sound suddenly goes off but the power is still on. If I turn the set off and unplug it and restart the set the picture and sound come back. But today it does not work any more. Any suggestions?
  • 1 more comment
  • Nopicsound Aug 29, 2008
    How could it be the power supply board? The power light is on but just without sound and picture. I called Pioneer service people and they will charge $110 for in-home service to find out the problem and then give me an estimate. If it is indeed the power supply board problem any idea how much it will cost me. Worthwhile to get it fix it?
    All fuses in the power supply appear to be ok. What is next?
    Thanks
  • Nopicsound Aug 30, 2008
    All fuses are ok. What are things I should check?
  • 46 Answers
This condition is brought about by some section of the set that is consuming too much power. The protection circuit is saving the set from further damage.
Unfortunately, there are several possible causes of this dilema; high voltage failure, deflection systems, audio ampifier or power supplies. A tech must look at it to determine the exact cause.
BTW: A full reset takes at least 4 hours of the power cord being disconnected. That will correct a soft code problem, but if the problem is hardware, it will merely shut down again.
It is well worth getting fixed - and will give you many more years of enjoyment. It will likely cost a few dollars to get it repaired unless you have an extended warranty on it. But, it will be worth it.
Let me know if you have further questions.
Thanks
Posted on Aug 30, 2008
    President:
  • 1,263 Answers
Your having a malfunction of a solid state chip on the mother board. depending on how old the set is depends if you feel it's worth repairing provided they have the parts. in most instances it's cheaper to replace than repair. i'm sure your hoping for a quick fix but unfortunately in this case you only have 2 options on this one. good luck please rate this solution.. thanks
    Master:
  • 638 Answers
Its the problem of weak capacitors on the power supply board.the power supply board is perfect ,the components on it are faulty and not letting the circuit to complete.
just replace the capacitors by the proper technician.
this is a common problem.which can be easily solved.
thanks.
please rate the solution.
    Master:
  • 848 Answers
Check whether the fuse are blown in your tv .......
Posted on Aug 29, 2008
    Master:
  • 521 Answers
Its the problem of power supply board.
  • tech expert12 Aug 29, 2008
    do not ---ON--- the tv or it will cause more damage to the tv.take it to the repair center urgently.it would be costly.so please get the reparing estimate first before reparing.
    pls do rate the solution
    thanks.
    regards.
    fixya expert team
How to fix my lcd tv and magic remote?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 29, 2015 | LG 47LW6500 47 3D LCD TV
I have had this TV for about 39 months. All of a sudden I lost the picture; the sound is fine. When I bought the TV, I was told that it has color tubes (red, green & blue) that will need to be replaced...
The tubes are not the problem. I have a somewhat strange question to ask, since you have sound: after the set is on for a few minutes do you see anything anywhere on the screen?
I am wondering if after it is on for several minutes if you see a faint band of noise from top to bottom towards the right side of the set.
Usually if there is a serious failure the set will shut down and then no sound or picture.
SD TECH
Mar 19, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Sharp LCD TV, Screen goes black sound stays on
Capacitors on the power pack are going bad they need to be replaced that should fix the problem.
Apr 07, 2009 | Sharp LC20SH7U Television
Sound but no Picture
Same problem...not solutions so far from what i can see. just a popping type sound...picture GONE...sound still there....had it for 2 years and 3 months....warrenty was for 2 years...eh hem...it figures.
Aug 27, 2008 | LG 42PC3D 42 in. Plasma Television
NO PICTURE HAS SOUND
I had the same problem. Check www.magnavoxhelp.com for instructions on how to fix it.
Jun 23, 2008 | Philips Magnavox 51MP392H Rear Projection...
Toshiba TP50H95 No sound no picture
Sounds like a problem in the deflection circuits either vertical or horizontal. You may also want to check the solder connections in the tuner as they have been known to develop cracks over time. But the prior shrinking tends to say deflection problems.If I can assist you further please let me know.
Feb 03, 2008 | Toshiba 50H81 50" Rear Projection...
SOUND NO PICTURE
Hello, You have a high voltage section problem I would not suggest fixing this set on your own. You will need to take this set to the shop. Because there are no user repairable parts inside of the set.
Sep 10, 2007 | Sony KV-36XBR400 36" TV
Blackout, High Pitch Squeel
Funny to see this because this is exactly what is happening to my 32 inch TV and I was researching to see if some one else had this problem and right away I find this, I've had my set for over a year now, and I have no solution at this time, but I will continue to research this, I figured that Protron would blame the cable company,that's what company's with crappy products usually do. Blame someone else.
Nov 25, 2006 | Protron PLTV-32 Television
Pioneer PRO-610 58" Rear Projection Television Logo
87 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
