Question about Bosch Nexxt WTMC3521UC Gas Dryer
Gas dryer with gas smell and no heat
I went to dry clothes this evening and notice that it was taking much longer than usual.  I tried resetting the dryer and to no avail.  The drum is working but there is no heat and a strong gas smell.  The gas valve has been turned off.
  • Anonymous Mar 28, 2014
    DRYER WOMT HEAT HAS A GAS SMELL
    Novelist:
  • 158 Answers
It sounds like your GLOW BAR gas igniter is bad. This is an electric powered heater coil that , when it glows red hot, ignites the gas burner. This part normally fails at least once during a dryers normal service life. If you are handy, you may be able to replace the part yourself. Otherwise, have a technician look at it. If you want to DIY, go to an appliance parts store . Remove and observe the GLOW BAR from your gas dryer. If one of the metal element appears to be burned open,replacement is necessary.. Show the part, along with your dryer maker, model, and serial number, to the store employee. This person can give you helpful info along with a new part. If the GLOW BAR is NOT burned out, seek out a technician.
Posted on Aug 29, 2008
Gas dryer
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
Aug 18, 2014 | Jenn-Air Jenn Air Clothes Dryer LSG2700W,...
I have a kenmore 70 series gas dryer. the dryer works pretty normal except the clothes take a little while longer to dry and they all smell badly of natural gas. i opened it up and and i can see the...
Check the vent hose for kinks . Also check the exhaust at the outside to make sure it has good air flow to the outside . A dryer either heats or not . Due to it heats , the only possible problem is vent hose blockage .
Sep 23, 2010 | Kenmore Dryers
Smell after drying
Try drying your clothes without the dryer sheet and see if the smell is still there. If it is not, then the problem is the dryer sheet.
If it is, then you need to describe the smell better. Different people handle smells differently. What smells musty to you may smell fragrant to others.
You need to determine if the smell you don't like is really a musty smell, or is it a fragrance you don't like. Have some friends (not family members) smell the clothes and verify if what you are smelling is musty or fragrant.
It could also be that even though the clothes smell OK out of the washer, that the detergent you are using is the cause.
Dec 16, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Amana les60aw gets hot in dryer but clothes wont dry. cleaned out vent, shortend exhaust hose. noticed an orange glow coming from back vents when i turned it back on???
The orange glow is the heating element working. It mush have good air flow or the coil will burn out and stop heating. Also the thermal limit will stop the heat if to great. If you went all through the vent and the tubing is not smashed or flat check the outside vent for air circulation, if good try to dry a load of clothes. Are you sure your washer is spinning out well? Wet clothes take longer to dry.
Oct 20, 2009 | Dryers
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
If you have'nt done it yet, my first suggestion would be to have the vent on the dryer (inside the dryer all the way to the fan chamber) and the dryer vent pipe to the outside thoroughly cleaned.
That is leading cause for dryers not drying completely.
Also, has the dryer always been a bit slow to dry cloths? If so, try leaving a window open the next time and see if it makes a difference. Some houses are sealed so tight, the dryer can't get enough air. A typical dryer will use up to 200 cu/ft of air per minute when drying. If there is not sufficient air, the cloths take longer to dry.
Good luck, let me know.
Regards,
May 12, 2009 | Maytag PYG2300A Gas Dryer
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
Clothes dryer not getting hot enough to dry in a good time frame
I have the same issue with my DLG3788W dryer. It seem to have only one setting for heat, rather than multiple heat settings. What can I do or do I have to call someone to repair this.
Oct 03, 2007 | LG DLE0332 Gas Dryer
Gas smell from dryer
your igniter needs to be replaced.
Jan 26, 2007 | Kenmore 74842 Gas Dryer
Bosch Nexxt WTMC3521UC Gas Dryer Logo
621 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
