Question about Singer 2517 Mechanical Sewing Machine
Thread bunching on model singer 2157C
I have tried to adjust the tension on my machine to avoid bunching but I have had no luck. It is set on the highest setting and changing the number of stitches doesn't seem to help either. My last attempt at fixing it was a disaster. All the thread from the bobbin is now bunched underneath and is difficult to get out without leaving remnants.
HELP!!
  • twinboys1 Aug 31, 2008
    Thanks for your help. I just found out it will cost me more to service it than to buy a new one. Guess I will be searching for a new machine.
According to everything I've researched, when this happens it's because there is no tension. Check & make sure it's threaded properly. If it's still bunching underneath, then there may be something wrong inside the machine - even though you adjust the tension, it may not really be happening inside. You'll have to take it apart or service it.
Posted on Aug 29, 2008
I have a Singer 2263 which is old but not used often. I am making aprons for Christmas, I made 3 and all the sudden the bobbin started bunching together. What can I do?
hi Sue.
Why does my bobbin thread keep bunching up? Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimes thread bunching can be caused by something as simple as the tension dial being inadvertently turned.
Sewing Machine Thread Bunching Up Here Why .
if you go to this link a little pop up will come up just close this down.
or try this one.
How to Fix that Tangled Nest of Bobbin Thread Under Your Sewing
or read up more at this link.
Why does my bobbin thread keep bunching up Google Search
Dec 13, 2017 | Singer Sewing Machines
I need elp with tension on singer cg550
You didn't explain the symptoms. Is the thread bunching, looping, knotting under the fabric? Is the bobbin thread rising to the top of the fabric?
If it is bunching under the fabric, it is probably what is called thread nesting or bird nesting. There are several fixes, sometimes more than one fix is required to resolve the issue.
Be sure to clean under the needle plate, around the bobbin, and the feed dogs. If the machine has instructions for oiling, follow the directions using a fresh, good quality sewing machine oil and apply only 1-2 drops each spot.
Install a brand new needle. Make sure you are using a needle compatible with the thread and fabric being used. All About Needles
Best practice is to use the same thread in both the upper and bobbin. Also, avoid old or bargain bin thread. Spend an extra couple of dollars to reduce frustration and increase success with your machine. If you wish, you may use two different colors of thread to test so you can easily determine what is happening with the tension.
Remove the thread from the machine. RAISE the presser foot and rethread from the beginning--the thread needs to be seated firmly in the tension disk. Verify that the correct thread path is followed (consult the owner's manual).
Set the upper tension to the midway point between high & low numbers (this is the factory standard and is a good place to start, but every machine is different and may need adjustment).
Confirm that the bobbin is installed in the bobbin case (turning the correct direction) and that the bobbin case is threaded properly.
Before beginning to stitch, hand rotate the handwheel one rotation and pull the bobbin thread to the top of the fabric. Then, gently hold the thread tails in the left hand and slowly begin to stitch.
Test.
If thread is bunching, looping under the fabric, the upper tension is too loose. Tighten it and retest. On most machines, the lower the tension number, the looser the tension.
If the bobbin thread is rising to the top of the fabric, the upper tension is too tight. Loosen the upper tension and retest.
Keep adjusting and testing until it is where you want it. Generally, tension is correct when both threads (upper & bobbin) meet in the middle of the fabric. FWIW, tension is static and should be tested and readjusted every time a new project is begun. The needle, thread, and fabric will affect the tension, so it is important to get comfortable adjusting the tension.
Also found the following reviews. Appears that some users have had tension issues with their CG550.
Amazon com Customer Reviews Singer CG 550 10 Stitch Commercial Grade...
Mar 17, 2016 | Singer CG550 Mechanical Sewing Machine
Have a Singer 11910000A and the bobber thread bunches up and makes a mess in the feet when sewing
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
sewing machine birdnesting
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
8 Tips to Fix Birdnesting in Embroidery
Birds nest under the fabric big loops of thread top side looks good...
http://www.marthastewart.com/1085057/common-sewing-machine-repair-tips
and here's another Hint that may be helpful:
https://www.youtube.com/watch?v=KDERq4I7l-Q
Dec 29, 2015 | Singer Sewing Machines
Spool thread bunches up on bottom on singer 6423
It sounds like the tension for the top thread is too loose. Try re-threading the machine, and then adjusting the tension to make it tighter.
Feb 24, 2013 | Singer 6423 Sewing Machine
How do you adjust the tension
Tension is adjusted with the tension dial on the right side of your machine.You would adjust the tension to your comfort. Use a piece of material to practice on, and tighten or loosen your tension till your threads look just right. If they are to tight your material will bunch up, if they are to loose you will have thread loops or very loose threads. As you get to know your machine this will come to you as easy as driving a Model T Ford. GOOD LUCK.
Jul 24, 2011 | Singer 2732 Mechanical Sewing Machine
I lost my manual for singer model 4525 and am not sure I am threading it right do you have a diagram, also how do I adjust the tension?
found this for a 4526 - it could be very similar to your machine.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_4526_4528_4530_threading.htm
there is also good general machine help on www.sewing.about.com which gives generic threading help, trouble shooting etc.
Tension is usually controlled by a dial on the top thread, and a little screw on the bobbin case on the bottom thread. However, if you adjust either, just small increments is best to avoid making things worse. Top tension usually set to 5 or middle number and bottom tension shouldn't often need touching.
Apr 10, 2011 | Singer Sewing Machines
Top thread bunching under fabric when sewing
tension could be too loose. start with bobbin tension- should allow thread to pass with SLIGHT resistance. then adjust top tension at about 2-3 to start.
Jun 01, 2010 | Singer 8280 Mechanical Sewing Machine
Thread is bunching up and pulling fabric into feed dogs. also breaking top thread. i have cleaned and oiled,adjusted stitch length,changed needle, re-threaded, and adjusted tension. i should note i am a...
If the thread bunches up on the bottom sometimes it is the bobbin tension. You can remove the bobbin housing and may notice a screw. This screw "tensions" the tab where the thread goes through, creating tension on the thread. Another thing to check if the machine is on a "loose/stretch" stitch setting, this will allow the elastic to freely expand and contract. You may need to also adjust the "speed" of the feed teeth, to compensate for the slack. Often there is "stray thread" in or around the bobbin, which can cause problems, One of these may be the solution, Im being general in my information.
Mar 21, 2010 | Singer 7442 Mechanical Sewing Machine
I have a Singer Sewing Machine 5817C, the thread bunches under the fabric while sewing. I have tried adjusting all the switches so that I just get a standard straight stitch, but it bunches up on the...
Make sure that there is tension on the thread when you have passed it through the tension unit, by making sure the presser foot is down, and then gently pulling the thread to feel tension. If there is no tension, as seems to be the case, check the tension discs inside the unit to make sure that there is no debris stopping them from closing.
Oct 14, 2009 | Singer Sewing Machines
Singer 2517 Mechanical Sewing Machine Logo
529 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
