Question about Olympus Cameras
I have an E410 DSLR and am trying to use a Sandisk Extreme IV CF card of 4GB. I get message stating card full until I try to format it and then get a card error. Can you help ?
    President:
  • 919 Answers
Currently Olympus has successfully tested Sandisk Extreme 3 up to 8gb without any card error messages. It sounds as if it is a card compatibility issue. Try to exchange to an Extreme 3 and you should be able to use that without any issues.
Posted on Dec 16, 2008
Sdhc unable to format write protected
SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Also, make sure the device in which you're trying to format the card is SDHC-compatible.
Jan 28, 2013 | SanDisk Extreme Hd Video Sd Sdhc 4gb...
I just purchased a 4GB SanDisk Extreme lll CompactFlash for my camers but when I try to use it I get the Unable to use card message. What can I do?
I suspect 2GB is the maximum the camera will take. A 2GB Sandisk card works in my 7i. When the DiMAGE 7i was launched, 256mB was about as big as CF cards got!
Sep 06, 2010 | Konica Minolta DiMAGE 7i Digital Camera
SanDisk Extreme III 4GB, unable to retrieve the 500 images on it.
SanDisk Extreme cards are supposed to ship with RecoveryPro software which should help you get the photos back. If the software is not on your card you may be able to get it from their website or another SanDisk card.
Mar 27, 2010 | Cameras
Sandisk extreme III says CF full when the card is empty
If you've tried the usual fixes like reformatting the card and trying it out in other cameras, then there is nothing more you can do to fix this.
Fortunately, Sandisk are very good at replacing faulty memory cards provided they've not suffered physical damage. Just contact the company to find out how to exchange your CF card.
Nov 06, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
Formatting an CF 4GB sandisk ultra II....How to do
The camera uses FAT16 so it won't be able to use cards bigger than 2GB. IF you can format it, you will only have 2GB space available.
Formatting the card: Press Menu/OK, select Setup, Select Format, press OK untill it's done.
Oct 11, 2009 | Fuji FinePix S7000 Digital Camera
Sandisk ext'me IV 8GB cf card states 'card error' in olympus e410
Please format the CF card in your computer with an external cardreader on full format and probly your card is working on an Olympus E410
Mar 08, 2009 | Olympus EVOLT E-410 Digital Camera
Cannot transfer photos to XP from SDHC Ultra II Card
Took it to Jessops by the process of elimination "Integral reader faulty."
What a waste of many hours !
Feb 02, 2009 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Best regards - Michael
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
Can't initialize SanDisk Ultra II for S7000
try formatting it in the computer, then initializing it in the camera.
It's possible that the camera can only handle memory up to 1Gb. Try a 1g CF card.
Jan 01, 2009 | Sony Alpha DSLR-A200K Digital Camera
Cameras Logo
151 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
