Question about Magellan RoadMate 2200T GPS Receiver
Change the time on the magellan roadmate 1212?
  • slipdipidis Dec 26, 2008
    I have the same problem with one BIG addition. When my time zone is set correctly, the time is wrong. The time differential is correct for Central Standard Time (-6 hours from GMT) but the time is off by one hour. So what happens now ? I could set the time zone incorrectly to match my actual time but that's just stupid... it should work the way it was designed.
I was in same situation with a magellan roadmate 1212. From what I can tell, the "daylight savings" is not what many of us may be accustomed to... that is, that it means that the location you are at follows daylight savings as happens with Windows or many other devices.
I bet those in Arizona never had a problem becuase they don't follow time zone... let me explain....
The daylight savings seems to state "are we currently under daylight savings time?" if we say yes (as you would normally state in your Windows computer setting (that would determine when daylight starts and stops and adjust pc time accordingly), the magellan 1212 instead will "ADD" one hour to the time stated by the Satellites regardless on whether it is summer ... or not.
So, if you happen to live in a time zone that follows "daylight savings" and you currently are under "daylight savings" time, then set it so in the "time zone".
So, there are two things you have to do:
/menu/user options/system settings/time zone/
1)Set your time zone
2)If currently under Set/unset the daylight savings set button to yes and manually move to no when not on DLS.
The explanation I found in MagellanGPS website is below, but never mentions what is the meaning (I should say effect) of the "daylight savings" button checkmark.
Magellan GPS receivers are not able to set the Time manually. In order to have the correct time set on your Magellan GPS receiver, you must set the proper time zone you are located in (ie Pacific, Central or Eastern). Once the time zone is set the exact hour and minute will display as information is received from the satellites. The following information will assist you on setting the time zone on your Magellan GPS. For Outdoor Triton series 200, 300, 400, 500, 1500 and 2000
  1. From the map screen press Menu and select View
  2. Select profiles and press Enter
  3. Select hiking and press Enter
  4. Press the Page/Go To key once and scroll down to select time zone
  5. Press Enter to select your time zone and Enter again to confirm.
  6. Press ESC repeatedly until you return to the map screen.
Note: Make sure Daylight Savings is adjusted accordingly. For Vehicle Navigation series Maestro and RoadMate 1200-1430
  1. From the map screen select Menu
  2. Select User Options
  3. Select System Settings
  4. Select Time Zone
Posted on Dec 05, 2008
Change my magellan roadmate from canada to usa
This model does not have map coverage of Canada. This model was designed for us only in the US. The models in that series with Canada maps were the RoadMate 1212, 1412, and 1430.
Oct 12, 2014 | Magellan Roadmate 1200 Car GPS Receiver
Broken screen Magellan roadmate 1212
Hi.
It is actually much cheaper to buy a new unit than to repair it.
It cost around $150 and above, depends on how crack it is and what model of magellan you're using.
Jun 09, 2010 | Magellan RoadMate™ 1212 Car GPS Receiver
Magellan 1212
With Magellan? You want free updates? If Magellan doesn't offer them then you are out of luck. At least on the legal software end of things. That's all I'm saying about that
Mar 31, 2010 | Magellan RoadMate™ 1212 Car GPS Receiver
Once region is set how do I change it on the megellan roadmate 1212?
By default, the Magellan RoadMate has the region setting for the lower 48 United States. When the receiver is turned on for the first time it may ask you to assign regions. Select the map region you want to use by tapping on the item from the list.
If you are travelling in other regions you will need to change the map region by using the following steps.
1 From the Main Menu, tap on the right arrow to access the second page of the Main Menu.
2 Tap on User Options.
3 Tap on Region.
4 Tap on the map region desired.
The Region option will display the map regions that are available for the Magellan RoadMate you are using.
Also if you want you can download the user manual from this website
visit website
or
download
Hope this helps
thanks
Oct 01, 2009 | Magellan RoadMate™ 1212 Car GPS Receiver
My magellan roadmate 1212 is in French. I need to change it to English. How do I do this?
your manual here
http://www.magellangps.com/assets/manuals/604-0132-001_A_UM_1212_ENG.pdf
Jun 24, 2009 | Magellan RoadMate™ 1212 Car GPS Receiver
Missing SD Map Card on Magellan Roadmate 1212
Unfortunately even if you do find a card it will not work with your unit because the cards have to be for that unit.If it is from another unit the codes will not allow it to work. The only option I know of is to purchase your map for that unit and put it on a sd card
May 09, 2009 | Magellan RoadMate™ 1212 Car GPS Receiver
I can t find updates for my Magellan Roadmate 1212 car GPS Receiver" . i need an update with all streets and roads in the US
According to the magellan site there are no updates available at this time. I have included a link to the website for you convience.
If you ask at the website they may be able to give you a time frame for the next update.
http://www.magellangps.com/support/product.asp?prodid=2070
I hope this is of some help.
Ed
Apr 19, 2009 | Magellan RoadMate™ 1212 Car GPS Receiver
Magellan Roadmate 1212 won't stay on when unplugged
Man, I DO commiserate with you on that one, but did you specify to them that the battery should be checked?
as that is probably your problem, now that I know the unit has been checked and the worst possible outcome
from your buying an extra battery is that you will HAVE AN EXTRA BATTERY for those times when you need
total portability.
So, make sure you try a brand new battery and if that solves your problem, then buy several.
Apr 17, 2009 | Magellan RoadMate™ 1212 Car GPS Receiver
It came with no instructions could I have them emailed to me???
CLick here to download the manual
You can also right-click on the link above and click on save target as to download it without opening.
Regards,
Sai.
Feb 03, 2009 | Magellan RoadMate™ 1212 Car GPS Receiver
Press MENU then select USER OPTIONS the select SYSTEM SETTINGS then select POWER then select NEVER. This will never let the GPS sleep.
Oct 18, 2008 | Magellan RoadMate™ 1212 Car GPS Receiver
Magellan RoadMate 2200T GPS Receiver Logo
478 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
